I have always felt a fair amount of the documentation on the website is from an advanced user’s perspective. I would suspect it’s intimidating for a new user.
I guess what I was saying i I don’t know how the docs are set-up or the hierarchy really. It has never made a lot of sense to me. I just google everything picking out integration keywords or describe some thing I want to do (or the customer wants to do) and find it that way.
When I’m looking a template Jinja2 thing, I pull up the page and word search it because it’s one document. I don’t get that one either. But this is me.
I don’t think a post would have me doing something different to see if there is an integration, for instance. Maybe others, don’t know.
You are not alone, I do the same thing. Although, I start with the forum then move to Google if I am running in circles. My thought process being, someone else most likely asked the same question at some point.
Then I have my own notes because as I have gotten older I forget a lot.
It took me quite some time to find that out until Tom made me aware of this.
My idea was that integrations were 3rd party services, devices and didn’t think I would find something like the basic media player info amongst the integrations - now I do.
For newcomers, it’s not that obvious where to look for information.
Things have gotten better, but maybe that’s also my perception* because of being a regular.
Having more ‘upfront’ guidance in what do to, where to search, what to post when asking a question can be helpful.
It took me while to figure this out too. I only clicked it when I developed my own integration.
I think a cookbook is a good idea.
What I’m also thinking is whether one could reach out to the dev team to make a bigger change to the docs by creating a new top bar menu item called domains (for example). All these building blocks can then be put there.
I too find it odd that it’s under integrations when it’s not something you can directly use or configure. I know those pages typically call it out and that specific integrations will often link back to these building block pages, but the penny may not drop immediately.
@123
Just added this to the cookbook. It would be awesome if you did an edit to that to pull in your version of how to do this like you did in How do I create a unique name for scene within a blueprint? - #2 by 123. or however you want to present it. I did a header on my section in anticipation that you would add your section.
It’s true, but it requires a script or automation that has a trace and you can easily figure the context. Sometimes a random name/word is needed in just a template so yours can be a useful option. I would love to see it there but it is your choice.
( that template would make a useful custom_template as well…)
That said, if you want to persue that I’m hands off, but if you don’t, I would be happy to credit you on the code and share a custom template doing that in HACS, then post that as an alternative.
However I am pulling from your code, so you have to tell me it’s OK or I won’t.
Given a choice of having a function versus a macro, I would choose a function for its convenience (no installation required and no “import” directive wherever it needs to be used).
Anyways, I added the following method, of creating a unique string, to the cookbook:
