Hi everyone, have there been any updates to not block the live camera? I have 4 and after a few seconds the live freezes
Freezing live video is different to crashing HA altogether.
Have you guys had any luck with this? Iāve had 4 Hikvision cameras in my config for quite some time, with stream:
enabled, but Iāve rarely actually used the live stream (just for a few seconds here or there) and never had an issue, even with pre-load stream enabled for my front door camera.
Last night I enabled camera live-feed notifications for my wifeās iPhone and HA crashed each time a few minutes after a test notification was sent. All front-ends that were open (apps, tablets, and Chrome on my laptop) disconnected and wouldnāt reconnect, and all back-end logs stopped (normally at least a couple log messages/min) with no errors. Had to restart the container manually to get it running again. Couldnāt find anything else, but was led to this old thread, which looks like my issue may be related to.
tl;dr: have you had any luck finding out what was causing the hang?
Nope. I just stopped using streaming.
Dang. OK. Well I swapped the sub-streams of two of my cameras to MJPEG and added them using the MJPEG component instead of generic
, seems OK for the momentā¦
Just noticed this behavior when trying to switch several camera to live mode vs auto. CPU seems fine, but HA just ends up getting really slow and hanging after a period of time. The more streaming cameras, the quicker it hangs.
Just have to keep them on auto and if you want a stream on a single camera, just click on them one at a time individually.
I know this is an old post but I have tried everything. Even tried a PI 4 and a PC - if I use the camera platform for even something simple like a local image my HA is slow and then eventually I cant load anything in the front end - completely kills the front end. Not even the supervisor will load. It starts off with some images/cameras not loading then about 2 mins after HA front end is dead
I have the same issue so Iām removing the live line from the configs and now cameras are back to refreshing every 10 seconds.
Known stream bug. Thereās a live issue on the stream component on GitHub
