@bruin we have to find common denominator between us.
Setup: Rpi4 with SSD, always latest updates and sqlite. Wired lan connection to google nest wifi network
EDIT: this is not happening always
Also noticed just now, that around time it happens my binary _ping router sensor is Disconnected for 5 minutes:
binary_sensor:
- platform: ping
host: 192.168.1.1
count: 5 #Default value
scan_interval: 300 #Default value 5mins. The ping binary sensor will poll the devices every 30 seconds.
Edit: had two stops in 12 hours :-(. This time ping binary sensor was not disconnected
I have same problem. I have rpi 4 with ssd and maria db. It started with rpi3+ and ssd. I upgraded pi to 4 as i thought the ethernet was broken. I reinstalled it and i have the problem. I tried ethernet, wifi, static IP. It reoccurs twice a day. It seems like disk disconnects, coz i can access everything whatās kept in memory, but i canāt access anything which needs access to the disk. Iāll try to find a ram log add-on to see whats going on.
O.k. so searching for whatās been common between all of us having this issue:
RPI 4 with SSD (DB could be sqlite or maria)
Also I am booting from SSD. meaning: I am NOT using SD+SSD where /data has been moved to SSD. As @cogneato suggested in discord booting from SSD has more issues.
More information about my setup and problem. @tLuQo@bruin@Enforcerke@Daniel_Lim@DaHai Can you find anything, that matches?
All it started after newest updates on June 13.
From hardware perspective: I have RPI4 model B 4GB ram (official power supply) with SSD and a first generation Conbee.
Always installing latest stable OS and Core versions
My addons:
AppDaemon 4,Duck DNS,File editor,Mosquitto broker,Plex Media Server,Portainer,SQLite Web,SSH & Web Terminal (Itās not running),Samba share,Terminal & SSH,deCONZ
Especialy interested if anyone else having Plex Media Server, as another suggestion from @cogneato in Discord was that Plex may be an issue in there
Same at my setup: RPi4 8GB RAM, Booting HassOS from SSD
Addons: File editor, ESPHome, FluxDB, SSH & Web Terminal
When it freezes at first some sensors stay unchanged then some web doesnāt respond anymore and later I lose connection to the complete home assistant server.
I disabled ble tracking in home assistant as well as i upgraded the core to latest version and itās still running since then (1 and half day so far). I also disabled ma xmas timer since the switch is off. Iāll see how it goes further.
Iām getting similar problems. Every now and then, sometimes daily, sometimes every few days. I cant canāt access HA via the ip address. Out of curiosity, next time this happens to someone else, rather than turning the Pi off and on again, can you try restarting your router instead and let me know if you are able to get back in. While still really annoying this works for me.
Im using a pi 4 and its connected directly to the router via lan
Got the same issue here.
PI3B+, latest version of HA + HAOS.
Until about 1 month it was happening daily; then I updated the system and all the addons, removed InfluxDB which I though it may lead to instabilities and it seems it solved.
It was not totally solved because I had the system stuck in this situation about 3 times during this last month, however the occurrencies were reduced.
Still when it happens itās really uncomfortable since there is no clue on what it caused.
I have the same problem. I have the latest version of HA + HAOS on PI3B+.
It goes offline whenever Iām compiling a new ESPHome device.
I then have to cut the power and cool it down then power it and wait about 15 minutes for it to boot.
An SSD and a UPS is a must for a Raspberry Pi based Home Assistant OS server.
Also, does anyone know how to shut down the Raspberry Pi running the Home Assistant OS from ssh?
I would like to try to gracefully shut it down from ssh to avoid corruption when the front end becomes unresponsive but I can not find this information anywhere. I think the whole docker thing is a complication when trying to shut the system down with ssh. I should be able to do this because when the system becomes unresponsive, the gui still shows the HAOS logo and displays an error message like connection problem or something.
Since my last message, I tried to compile again 2 more times. Both time it crashed and became unresponsive for about 15~20 minutes.
Which made me think that it might be an over-heating issue. So I tried another time using a handheld blower to blow air towards the cpu to keep it cool when compiling and it didnāt crash this time.
I will now use the systemmonitor add-on/platform to have a better understanding of whatās going on. However, I believe there is something else with the OS that causes high cpu usage or temperatures. Iām not used to the docker environment but I will try to find out what causes high cpu/temperature so it might take some time.
Maybe pi3B+ simply isnāt enough for a server like this.
This āHA just stops workingā issue is happening to me as well. It began a couple of months ago I think, and HA stops working about once a week - usually between midnight and 6 am. Because the log starts afresh on a reboot, is there any way of capturing the log so that I can see what might be causing this?
I have a 4GB RPi4 with an SSD (booting from the SSD).
Iāve noticed that on a couple of occasions at least, Iāve had to reboot twice to get a fully working system. After the first reboot, the system at first starts working, but will then lock up after an hour or two (and the RPi4 becomes very warm). A second reboot, and itās OK (for the next week or so).
I recommend this to anyone having stability issues with their setup.
The package comes with two fans.
A transparent fan with color-cycling RGB LEDs but it is a bit noisy and uses about 40mA @5V. This comes installed on the cooler. There is an additional fan in the package which is black but it is noiseless and uses 20mA @ 5V. I replaced the transparent one with the better black one as you can see in the photo.
I solved my HA from constantly going off. I felt mine was more network based. Noticed that if i reset the router rather than the pi4, it would come back on. I thought because my ethernet was plugged in, that my pi would automatically be using it, but it wasnāt. It was till using the wifi.
So under Supervisor> System> Host> IPAdress> Change Make sure your eth0 ipv4 has a static ip and my ipv6 is set to DHCP.
Your static ip canāt be the same as your wifi one. Then connect to this one. Since doing that my HA has stayed up. 5 days and counting. (If you want your ip the same, just take care when swapping them over. Probably test a new ethernet ip before hand)
I have the same problem with random freezes of the system. There is some temperature spike but not significant, from 35 celcius to 44 celcius before it freezes, last time it happened at around 23:00 hours, close to midnight, times before that I didnāt check. This is the third time now in almost two months.
My setup is RPI 4 8GB with boot from SSD, no SD card installed. Iāve noticed that my KNMI integration was the last thing in the logs that gave errors. Iāve uninstalled the KNMI integration, letās see if that fixes my freezes.
Network connection is done through cable, not WiFi. I have a case for my RPI 4 with heatsink and small fan that got supplied with it.
The random freezes suck because I want to move my password vault from the Google browser to my HA local instance and connect through VPN to avoid port forward. But for the password vault the be hosted on my RPI I need 99,999% uptime of the system to be able to rely on it.
I was able to capture a CLI trace at the time of a crash. My configuration: Raspberry Pi 4B 4GB, 120GB Intenso SSD with Home Assistant (external), Raspberry Pi 4 Case, USB-C Power Supply 5V 3A.
See graph: power and memory consumption as well as temperature look normal. The temperature actually got down at the crash time:
Here is the picture from the CLI screen; it shows ārebooting in 5 secondsā at the end, but this doesnāt happen. Iām unable to inteprete the CLI log, but maybe you can see some meaningful things to identify the reason of crashing, which happens almost daily.
