As the number you need to specify the same string you used for the dial command. If this is not working please set the log level in the add-ons configuration to 2 and post the log here where you tried to hang-up the call.
I have tried multiple times but I cant find a way to create a sub menu using the config file. I have users authenticate with pin after the welcome message and this works but is there a way to give them a menu after the ‘PIN menu’? (a sub menu of sorts) so I could, say, press 1 to unlock door etc… but AFTER the first menu where I ask for pin
I hope this was clear enough for you to understand.
Thanks much for this add-on. I am using it to make emergency calls. I tell my Google Assistant “I need help”, which triggers a HASS script to call my children and play a message.
Three things:
It took a while but I figured out how to use Nabu Casa’s TTS. The configuration in the tts: section of ha-sip is
Question: iIs there a way to make it repeat the message until the other side hangs up?
In case it helps someone, here is the script:
alias: Call phone for help
description: Call a phone number for help
sequence:
- service: hassio.addon_stdin
addon: c7744bff_ha-sip
input:
command: dial
number: sip:{{ number }}@sipgate.co.uk
ring_timeout: 30
sip_account: 1
menu:
message: >-
Your message here. Repeat:
Your message here.
post_action: hangup
mode: single
max: 10
thanks for the input on how to use Nabu Casa’s TTS and the feedback on your SIP provider!
There was no way to repeat the message, but now there is in version 2.5.
You can specify repeat_message as your post_action and it will re-read it until the timeout is reached. So if you are fine with 5 minutes of repeating you can leave the default time-out, or change it to fit your use-case. The new post_action is also described in the docs.
I recently switched from “DSS VoIP Notifier” to your addon. It works with the Nabucasa TTS and doesn‘t start to play the message immediately, regardless of the other site takes the call or not, which is the most important feature for me.
Actually I just want to say: thank you for your hard and excellent work.
hello, i just begin with SIP, so i’m noob even with the parameter.
So start with your add-on i need some help to understand what i need to change in the config to match the SIP account i have with IPPI
where do i enter
id ?
domain ?
proxy ?
password ?
sip number ?
i see that all info are SIP:xxxx
may i have to enter SIP:my_info or just my_info ?
the goal of the SIP is to get some incoming call from my Doorbird doorstation when the ring is pressed and people speak.
thank you for your help and i apologize for basic asking
ok added that in my config, start the addon and get a long journal
do you want i post this journal ? to see if there is problem ?
now how could i test the right function ?
If there is lots of logging it’s mostly because the authentication did not work. You could try sip_number for user_name, or sip:id@domin for the id_uri. I don’t have an IPPI account, so I can’t help with that.
sip flag SIP ebonnet
sip flag SIP 8xx 7xx 975
Identifiant SIP ebonnet
Mot de passe •••••••
Domaine/Realm sip.ippi.com
Proxy & Registrar SIP sip.ippi.com
and i got this log
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
Python 3.9.2
| 10:48:27.781087 [1] No file name for incoming call config specified.
| 10:48:27.781453 [2] No file name for incoming call config specified.
10:48:27.784 os_core_unix.c !pjlib 2.13 for POSIX initialized
10:48:27.787 sip_endpoint.c .Creating endpoint instance...
10:48:27.788 pjlib .select() I/O Queue created (0x12ecf50)
10:48:27.788 sip_endpoint.c .Module "mod-msg-print" registered
10:48:27.788 sip_transport. .Transport manager created.
10:48:27.788 pjsua_core.c .PJSUA state changed: NULL --> CREATED
10:48:27.788 sip_endpoint.c .Module "mod-pjsua-log" registered
10:48:27.788 sip_endpoint.c .Module "mod-tsx-layer" registered
10:48:27.788 sip_endpoint.c .Module "mod-stateful-util" registered
10:48:27.789 sip_endpoint.c .Module "mod-ua" registered
10:48:27.789 sip_endpoint.c .Module "mod-100rel" registered
10:48:27.789 sip_endpoint.c .Module "mod-pjsua" registered
10:48:27.789 sip_endpoint.c .Module "mod-invite" registered
10:48:27.789 pjlib ..select() I/O Queue created (0x12be804)
10:48:27.794 sip_endpoint.c .Module "mod-evsub" registered
10:48:27.794 sip_endpoint.c .Module "mod-presence" registered
10:48:27.794 sip_endpoint.c .Module "mod-mwi" registered
10:48:27.794 sip_endpoint.c .Module "mod-refer" registered
10:48:27.794 sip_endpoint.c .Module "mod-pjsua-pres" registered
10:48:27.794 sip_endpoint.c .Module "mod-pjsua-im" registered
10:48:27.795 sip_endpoint.c .Module "mod-pjsua-options" registered
10:48:27.795 pjsua_core.c .No SIP worker threads created
10:48:27.795 pjsua_core.c .pjsua version 2.13 for Linux-5.15.84/armv7l/glibc-2.31 initialized
10:48:27.795 pjsua_core.c .PJSUA state changed: CREATED --> INIT
10:48:27.795 pjsua_aud.c Setting null sound device..
10:48:27.795 pjsua_aud.c .Opening null sound device..
10:48:27.797 pjsua_core.c SIP UDP socket reachable at HAIP:5060
10:48:27.797 udp0x1303c40 SIP UDP transport started, published address is HAIP:5060
10:48:27.797 pjsua_core.c PJSUA state changed: INIT --> STARTING
10:48:27.797 sip_endpoint.c .Module "mod-unsolicited-mwi" registered
10:48:27.797 pjsua_core.c .PJSUA state changed: STARTING --> RUNNING
10:48:27.798 pjsua_acc.c Adding account: id=sip:[email protected]
10:48:27.798 pjsua_acc.c .Account sip:[email protected] added with id 0
10:48:27.798 pjsua_acc.c .Acc 0: setting registration..
10:48:27.798 pjsua_acc.c ..Contact for acc 0 updated: <sip:ebonnet@HAIP:5060;ob>;+sip.ice
10:48:27.809 pjsua_core.c ...TX 500 bytes Request msg REGISTER/cseq=27807 (tdta0x130843c) to UDP 194.169.214.30:5060:
REGISTER sip:sip.ippi.com SIP/2.0
Via: SIP/2.0/UDP 192.168.0.56:5060;rport;branch=z9hG4bKPjMcQ26tbwucRQX0qvufP8VTTEjihLdMEw
Max-Forwards: 70
From: <sip:[email protected]>;tag=Zm3y6uVCOV4P3eoLcIjhvhGl73j8cDI9
To: <sip:[email protected]>
Call-ID: vmG8xeUQOVeLvHUKK7iXDrMTFJDVZA6p
CSeq: 27807 REGISTER
Contact: <sip:ebonnet@IP_HA:5060;ob>;+sip.ice
Expires: 300
Allow: PRACK, INVITE, ACK, BYE, CANCEL, UPDATE, INFO, SUBSCRIBE, NOTIFY, REFER, MESSAGE, OPTIONS
Content-Length: 0
--end msg-
10:48:27.809 pjsua_acc.c ..Acc 0: Registration sent
10:48:27.833 pjsua_core.c .RX 513 bytes Response msg 401/REGISTER/cseq=27807 (rdata0x1305274) from UDP 194.169.214.30:5060:
SIP/2.0 401 Unauthorized
Via: SIP/2.0/UDP 192.168.0.56:5060;received=EXT_IP;rport=5060;branch=z9hG4bKPjMcQ26tbwucRQX0qvufP8VTTEjihLdMEw
To: <sip:[email protected]>;tag=de5ec607ac420ca7ba13a950717a2ed1.2cea
WWW-Authenticate: Digest realm="ippi.fr", nonce="6435200739f335d1ca988a36f4dbd4041e5d4794"
Server: OpenSIPS (1.8.2-tls (i386/linux))
Content-Length: 0
--end msg--
10:48:27.833 pjsua_acc.c ....IP address change detected for account 0 (IPHA:5060 --> 109.208.231.232:5060). Updating registration (using method 4)
10:48:27.833 pjsua_acc.c ....Contact for acc 0 updated: <sip:ebonnet@EXT_IP:5060;ob>;+sip.ice
10:48:27.833 sip_auth_clien ...Unable to set auth for tdta0x130843c: can not find credential for ippi.fr/Digest
10:48:27.833 pjsua_acc.c ....SIP registration error: No suitable credential (PJSIP_ENOCREDENTIAL) [status=171101]
| 10:48:27.833500 [1] OnRegState: 401 Unauthorized
10:48:28.797 pjsua_aud.c Closing sound device after idle for 1 second(s)
10:48:28.797 pjsua_aud.c .Closing null sound device..
where
HAIP = ip of my HA
EXT_IP = external IP of my provider connexion
