Home Assistant Virtual machine installation, log error
log:(I deleted some.)
22-09-15 02:17:24 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4
22-09-15 02:17:24 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2022.9.4.
22-09-15 02:17:28 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.9.4&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp 20.205.243.164:443: connect: no route to host")
22-09-15 02:17:28 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-09-15 02:17:58 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4
22-09-15 02:17:58 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2022.9.4.
22-09-15 02:17:59 ERROR (SyncWorker_1) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.9.4&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp 20.205.243.164:443: connect: no route to host")
22-09-15 02:17:59 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-09-15 02:18:29 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4
22-09-15 02:18:29 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2022.9.4.
22-09-15 02:18:29 ERROR (SyncWorker_1) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.9.4&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp 20.205.243.164:443: connect: no route to host")
22-09-15 02:18:29 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-09-15 02:18:59 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4
22-09-15 02:18:59 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2022.9.4.
22-09-15 02:19:03 ERROR (SyncWorker_1) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.9.4&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp 20.205.243.164:443: connect: no route to host")
22-09-15 02:19:03 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-09-15 02:19:33 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4
22-09-15 02:19:33 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2022.9.4.
22-09-15 02:19:37 ERROR (SyncWorker_1) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.9.4&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp 20.205.243.164:443: connect: no route to host")
22-09-15 02:19:37 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-09-15 02:20:07 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4
22-09-15 02:20:07 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2022.9.4.
22-09-15 02:20:14 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.9.4&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp 20.205.243.164:443: connect: no route to host")
22-09-15 02:20:14 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-09-15 02:20:44 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4
22-09-15 02:20:44 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2022.9.4.
22-09-15 02:20:48 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.9.4&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp 20.205.243.164:443: connect: no route to host")
22-09-15 02:20:48 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-09-15 02:21:18 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4
22-09-15 02:21:18 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2022.9.4.
22-09-15 02:21:18 ERROR (SyncWorker_1) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.9.4&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp 20.205.243.164:443: connect: no route to host")
22-09-15 02:21:18 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-09-15 02:21:48 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4
22-09-15 02:21:48 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2022.9.4.
22-09-15 02:21:52 ERROR (SyncWorker_1) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.9.4&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp 20.205.243.164:443: connect: no route to host")
22-09-15 02:21:52 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-09-15 02:22:22 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4
22-09-15 02:22:22 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2022.9.4.
22-09-15 02:22:37 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.9.4&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)")
22-09-15 02:22:37 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-09-15 02:23:07 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4
22-09-15 02:23:07 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2022.9.4.
22-09-15 02:23:12 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.9.4&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp 20.205.243.164:443: connect: no route to host")
22-09-15 02:23:12 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-09-15 02:23:42 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4
22-09-15 02:23:42 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2022.9.4.
22-09-15 02:23:49 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.9.4&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp 20.205.243.164:443: connect: no route to host")
22-09-15 02:23:49 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-09-15 02:24:19 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4
22-09-15 02:24:19 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2022.9.4.
22-09-15 02:24:23 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.9.4&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp 20.205.243.164:443: connect: no route to host")
22-09-15 02:24:23 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-09-15 02:24:53 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4
22-09-15 02:24:53 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2022.9.4.
22-09-15 02:24:56 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.9.4&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp 20.205.243.164:443: connect: no route to host")
22-09-15 02:24:56 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-09-15 02:25:26 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4
22-09-15 02:25:26 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2022.9.4.
22-09-15 02:25:30 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.9.4&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp 20.205.243.164:443: connect: no route to host")
22-09-15 02:25:30 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-09-15 02:26:00 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4
22-09-15 02:26:00 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2022.9.4.
22-09-15 02:26:04 ERROR (SyncWorker_1) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.9.4&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp 20.205.243.164:443: connect: no route to host")
22-09-15 02:26:04 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-09-15 02:26:34 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4
22-09-15 02:26:34 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2022.9.4.
22-09-15 02:26:44 ERROR (SyncWorker_1) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.9.4&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp 20.205.243.164:443: connect: no route to host")
22-09-15 02:26:44 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-09-15 02:27:14 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4
22-09-15 02:27:14 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2022.9.4.
22-09-15 02:27:15 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.9.4&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp 20.205.243.164:443: connect: no route to host")
22-09-15 02:27:15 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-09-15 02:27:45 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4
22-09-15 02:27:45 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2022.9.4.
22-09-15 02:27:48 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.9.4&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp 20.205.243.164:443: connect: no route to host")
22-09-15 02:27:48 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-09-15 02:28:18 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4
22-09-15 02:28:18 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2022.9.4.
22-09-15 02:28:22 ERROR (SyncWorker_1) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.9.4&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp 20.205.243.164:443: connect: no route to host")
22-09-15 02:28:22 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-09-15 02:28:52 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4
22-09-15 02:28:52 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2022.9.4.
22-09-15 02:28:56 ERROR (SyncWorker_1) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.9.4&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp 20.205.243.164:443: connect: no route to host")
22-09-15 02:28:56 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-09-15 02:29:26 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4
22-09-15 02:29:26 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2022.9.4.
22-09-15 02:29:30 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.9.4&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp 20.205.243.164:443: connect: no route to host")
22-09-15 02:29:30 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-09-15 02:30:00 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4
22-09-15 02:30:00 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2022.9.4.
22-09-15 02:30:04 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.9.4&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp 20.205.243.164:443: connect: no route to host")
22-09-15 02:30:04 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-09-15 02:30:34 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4
22-09-15 02:30:34 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2022.9.4.
22-09-15 02:30:34 ERROR (SyncWorker_1) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.9.4&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp 20.205.243.164:443: connect: no route to host")
22-09-15 02:30:34 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-09-15 02:31:04 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4
22-09-15 02:31:04 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2022.9.4.
22-09-15 02:31:08 ERROR (SyncWorker_1) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.9.4&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp 20.205.243.164:443: connect: no route to host")
22-09-15 02:31:08 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-09-15 02:31:38 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4
22-09-15 02:31:38 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2022.9.4.
22-09-15 02:31:39 ERROR (SyncWorker_1) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.9.4&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp 20.205.243.164:443: connect: no route to host")
22-09-15 02:31:39 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-09-15 02:32:09 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4
22-09-15 02:32:09 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2022.9.4.
22-09-15 02:32:10 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.9.4&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp 20.205.243.164:443: connect: no route to host")
22-09-15 02:32:10 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-09-15 02:32:40 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4
22-09-15 02:32:40 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2022.9.4.
22-09-15 02:32:43 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.9.4&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp 20.205.243.164:443: connect: no route to host")
22-09-15 02:32:43 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-09-15 02:33:13 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4
22-09-15 02:33:13 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2022.9.4.
22-09-15 02:33:17 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.9.4&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp 20.205.243.164:443: connect: no route to host")
22-09-15 02:33:17 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-09-15 02:33:47 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4
22-09-15 02:33:47 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2022.9.4.
22-09-15 02:33:48 ERROR (SyncWorker_1) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.9.4&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp 20.205.243.164:443: connect: no route to host")
22-09-15 02:33:48 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-09-15 02:34:18 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4
22-09-15 02:34:18 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2022.9.4.
22-09-15 02:34:25 ERROR (SyncWorker_1) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.9.4&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp 20.205.243.164:443: connect: no route to host")
22-09-15 02:34:25 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-09-15 02:34:55 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4
22-09-15 02:34:55 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2022.9.4.
22-09-15 02:35:02 ERROR (SyncWorker_1) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.9.4&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp 20.205.243.164:443: connect: no route to host")
22-09-15 02:35:02 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-09-15 02:35:32 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4
22-09-15 02:35:32 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2022.9.4.
22-09-15 02:35:35 ERROR (SyncWorker_1) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.9.4&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp 20.205.243.164:443: connect: no route to host")
22-09-15 02:35:35 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-09-15 02:36:05 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4
22-09-15 02:36:05 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2022.9.4.
22-09-15 02:36:12 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.9.4&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp 20.205.243.164:443: connect: no route to host")
22-09-15 02:36:12 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-09-15 02:36:42 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4
22-09-15 02:36:42 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2022.9.4.
22-09-15 02:36:43 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.9.4&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp 20.205.243.164:443: connect: no route to host")
22-09-15 02:36:43 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-09-15 02:37:13 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4
22-09-15 02:37:13 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2022.9.4.
22-09-15 02:37:17 ERROR (SyncWorker_1) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.9.4&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp 20.205.243.164:443: connect: no route to host")
22-09-15 02:37:17 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
What should I do?
What virtualisation are you using? And what networking setup have you given it?
Vmware Workstation
Bridging mode
does this help?
Oh, I installed it on the Windows virtual machine.
I’m new to the command line, but I have to thank you, aceindy.
