Home assistant with Raspbian stretch + Docker + DuckDNS
Are you sure you’re not behind a carrier grade NAT?
Does your wan IP on your router match when you go to ipchicken.com?
Does your router support hairpin NAT? Are you testing from outside your network or inside?
