Sorry, missed it, it lacks of protocol, please add http://,
In the post above it was written correctly
Sorry, I had it the other way at first with âthe sameâ result (page loaded but no graph) so I switched to be without it.
However, I hadnât checked the browser console for errors. Iâve added the http back to the docker command and that gave me âthe sameâ results (no graph) but then there was a different error in the browser:
I thought I had the http section configured correctly but I forgot I had to set the port to a different one because the default was in use.
Itâs all straightened up now and working.
Thanks for your help
Problem : TypeError: Cannot read property âindexOfâ of undefined
Sorry, no more info or log in the container.
If you click on that ânetworkvieer.js:356â link, it will show you the line of code it is failing in. Mine up above for example is unable to find the primary controller (which appears to be a problem with my Z-Wave install, Iâm trhing to figure out how I lost the pirmary).
Released new version with the following changed:
Added support SSL
Exposed new endpoint /states.json to reterive the states JSON from Home Assistant (server to server)
As result of the above - no need to define the URL in
cors_allowed_origins
Added logs when environment variables are not defined as it should (missing
HA_TOKEN
orHA_URL
FYI, currently the new OZW doesnât put the neighbors into an attribute, you can pull them from the MQTT topics for the devices however.
@bar Iâve done a bunch of work on my Z-Wave network today (by resetting it and completely rebuilding it), so I now have a primary. I also grabbed the new image and am giving that a try.
However, itâs crashing when itâs parsing the neighbors:
TypeError: Cannot read property 'hop' of undefined
at networkViewer.js:366
at Array.filter (<anonymous>)
at setItemHop (networkViewer.js:366)
at networkViewer.js:377
at Array.forEach (<anonymous>)
at setItemsHop (networkViewer.js:377)
at loadNetworkItems (networkViewer.js:421)
at initialize (networkViewer.js:504)
at (index):55
I have a hunch this may be because my Z-Stick is having issues talking to one of my switches. It shows up in the neighbor list, but not in my Z-Wave devices. Here are the zwave devices from the HA states list, notice there is no device with node id 18 in the list. However it does show up in the logs and it works just fine from my primary controller (an ISY994).
Entity | State | Attributes |
zwave.aeon_labs_zw090_z_stick_gen5_us | ready | node_id: 2 node_name: AEON Labs ZW090 Z-Stick Gen5 US neighbors: 1, 6, 8, 9, 10, 18, 19 |
zwave.fountain_light_smart_energy_switch | ready | node_id: 9 node_name: AEON Labs DSC06106 Smart Energy Switch neighbors: 2, 6, 10, 16, 19 |
zwave.front_sidewalk_multisensor_6 | ready | node_id: 6 node_name: AEON Labs ZW100 MultiSensor 6 neighbors: 2, 8, 9, 10, 19 |
zwave.garage_smart_switch_6 | ready | node_id: 8 node_name: AEON Labs ZW096 Smart Switch 6 neighbors: 2, 10, 6 |
zwave.inovelli_unknown_type_ff00_id_ff05 | ready | node_id: 20 node_name: Inovelli Unknown: type=ff00, id=ff05 neighbors: 10 |
zwave.master_bathroom_multisensor_6 | ready | node_id: 16 node_name: Unknown Node 16 neighbors: 19, 9, 10, 18 |
zwave.photo_frame_smart_energy_switch_2 | ready | node_id: 10 node_name: AEON Labs DSC06106 Smart Energy Switch neighbors: 1, 2, 6, 8, 9, 16, 19 |
zwave.piano_room_table_lamp | ready | node_id: 19 node_name: Inovelli LZW42 Multi-Color Bulb neighbors: 2, 6, 9, 10, 16 |
zwave.universal_devices_isy994i | ready | node_id: 1 node_name: Universal Devices Unknown: type=0001, id=0001 neighbors: 18, 2, 10 |
- Fixed relation to zombie nodes (will ignore it)
- When a node has no neighbors, it will display a connection to the hub, but will display no neighbors in the sidebar
- Fixed relation to hub when the node is not connected - happens during startup or in case there is an issues with node (dead)
- Switched docker image to python-alpine (10% of size compared to previous one)
- Installed within the image
nano
editor
Is there a feature request to support it?
Since that information can be pulled via MQTT, Iâm doubtful.
Why? It was part of zwave, it suppose to replace it, instead of creating additional sensor that will listen to mqtt, the component that listens to ozw messages will add one more entity (equivalent to zwave component) with neighbors
Thereâs also no zwave.DEVICE
so Iâm not sure how youâd cope with that as well.
(ARGH, this didnât post last night⌠Iâll give the new image a try and see of that makes a difference)
I just got device 18 showing up (by excluding and including it yet again) and that was the issue. It looks like it crashes if it canât find one of the neighbors.
That said, it looks like it isnât picking up topology changes. I paired node 21, and it shows neighbors of nodes 10 and 20 in the device list. However, itâs showing as disconnected in the diagram.
This is a great tool though, thanks for writing it and putting it out there!
Do I understand this graph zwave toolvis usable togehter witht the openzwave addon?
Will release new version later that will allow to extract the json of just zwave entities and import it for debug purposes,
So basically if you would like, you will be able to send me the json and I will run it at my system with your configuration
@bar I noticed one other thing â there are links missing. Is this intentional or just an attempt to keep the graph cleaner? It would be nice if it always showed all the! links for the selected node (or if there was a way to change the tiering to focus on the selected node, but that could be difficult).
Notice in the screenshot below that node 9 is missing the links to nodes 10 and 6. Itâs even more obvious when I select node 16, as it only shows a single link, but the details show it with neighbors of 9, 10, 19, and 21.
Screen Shot 2020-07-27 at 16.23.07|690x399
New version released:
- Moved all logic of build the JSON for presentation to server side code
- Changed the layout to be an icon with label
- Changed the color scheme of sidebar
- Select a node will color it in blue
- Changed the labelâs color to white
- Web API - new endpoint - states.json - HA full states
- Web API - new endpoint - zwave.json - HA states filtered by zwave domain
- Web API - new endpoint - nodes.json - Nodes JSON for debugging
- Added button to download nodes JSON from viewer
please pull latest version and use the JSON button at the top right corner to download the generated JSON and post it so Iâll be able to debug
thanks
Hereâs an example with the new version. Node 1 for example should have two connections but was only showing one.
And the json:
"id": 2,
"name": "AEON Labs ZW090 Z-Stick Gen5 US",
"hop": 0,
"neighbors": [
9,
10,
20,
6
"isPrimary": true,
"edges": [
"id": 2,
"toNodeId": 9,
"type": "parent"
"id": 2,
"toNodeId": 10,
"type": "parent"
"id": 2,
"toNodeId": 20,
"type": "parent"
"id": 2,
"toNodeId": 6,
"type": "parent"
"entity": {
"attributes": {
"averageRequestRTT": 0,
"averageResponseRTT": 0,
"capabilities": [
"primaryController",
"beaming",
"listening",
"staticUpdateController"
"friendly_name": "AEON Labs ZW090 Z-Stick Gen5 US",
"is_awake": true,
"is_failed": false,
"is_info_received": true,
"is_ready": true,
"is_zwave_plus": false,
"lastRequestRTT": 0,
"lastResponseRTT": 0,
"manufacturer_name": "AEON Labs",
"max_baud_rate": 40000,
"neighbors": [
9,
10,
20,
6
"node_id": 2,
"node_name": "AEON Labs ZW090 Z-Stick Gen5 US",
"product_name": "ZW090 Z-Stick Gen5 US",
"query_stage": "Complete",
"receivedCnt": 0,
"receivedDups": 0,
"receivedTS": "2020-07-26 19:51:12:716 ",
"receivedUnsolicited": 0,
"retries": 0,
"sentCnt": 1,
"sentFailed": 0,
"sentTS": "2020-07-26 19:51:15:265 "
"context": {
"id": "b1146a15a7ba4224813123a17c131404",
"parent_id": null,
"user_id": null
"entity_id": "zwave.aeon_labs_zw090_z_stick_gen5_us",
"last_changed": "2020-07-27T02:51:25.864261+00:00",
"last_updated": "2020-07-27T02:51:25.864261+00:00",
"state": "ready"
"id": 1,
"name": "ISY994i",
"hop": 2,
"neighbors": [
10,
19
"isPrimary": false,
"edges": [
"id": 1,
"toNodeId": 10,
"type": "child"
"id": 1,
"toNodeId": 19,
"type": "sibling"
"entity": {
"attributes": {
"averageRequestRTT": 23,
"capabilities": [
"routing",
"beaming",
"listening"
"friendly_name": "ISY994i",
"is_awake": true,
"is_failed": false,
"is_ready": true,
"lastRequestRTT": 23,
"manufacturer_name": "Universal Devices",
"neighbors": [
10,
19
"node_id": 1,
"node_name": "Universal Devices Unknown: type=0001, id=0001",
"product_name": "Unknown: type=0001, id=0001",
"receivedCnt": 0,
"receivedDups": 0,
"receivedTS": "2020-07-26 19:51:12:715 ",
"retries": 0,
"sentCnt": 2,
"sentFailed": 0,
"sentTS": "2020-07-26 19:51:25:687 "
"context": {
"id": "d43038e9689b4578af8f690a4a26bff3",
"parent_id": null,
"user_id": null
"entity_id": "zwave.universal_devices_isy994i",
"last_changed": "2020-07-27T02:52:08.606240+00:00",
"last_updated": "2020-07-27T02:52:08.606240+00:00",
"state": "ready"
"id": 19,
"name": "Piano Room Table Lamp",
"hop": 2,
"neighbors": [
1,
6,
9,
10,
16,
20
"isPrimary": false,
"edges": [
"id": 19,
"toNodeId": 1,
"type": "sibling"
"id": 19,
"toNodeId": 6,
"type": "child"
"id": 19,
"toNodeId": 9,
"type": "child"
"id": 19,
"toNodeId": 10,
"type": "child"
"id": 19,
"toNodeId": 16,
"type": "parent"
"id": 19,
"toNodeId": 20,
"type": "child"
"entity": {
"attributes": {
"application_version": "2.28",
"averageRequestRTT": 1359,
"averageResponseRTT": 1297,
"capabilities": [
"routing",
"beaming",
"listening",
"zwave_plus"
"friendly_name": "Piano Room Table Lamp",
"is_awake": true,
"is_failed": false,
"is_ready": true,
"is_zwave_plus": true,
"lastRequestRTT": 1726,
"lastResponseRTT": 1890,
"manufacturer_name": "Inovelli",
"neighbors": [
1,
6,
9,
10,
16,
20
"node_id": 19,
"node_name": "Inovelli LZW42 Multi-Color Bulb",
"product_name": "LZW42 Multi-Color Bulb",
"receivedCnt": 10,
"receivedDups": 0,
"receivedTS": "2020-07-26 19:52:43:462 ",
"retries": 0,
"sentCnt": 13,
"sentFailed": 3,
"sentTS": "2020-07-26 19:52:41:573 "
"context": {
"id": "b1cb97ec162c43bca4db7d9c7b233544",
"parent_id": null,
"user_id": null
"entity_id": "zwave.piano_room_table_lamp",
"last_changed": "2020-07-27T02:52:54.933751+00:00",
"last_updated": "2020-07-27T02:52:54.933751+00:00",
"state": "ready"
"id": 16,
"name": "Master Bathroom MultiSensor 6",
"hop": 3,
"neighbors": [
9,
10
"isPrimary": false,
"edges": [
"id": 16,
"toNodeId": 9,
"type": "child"
"id": 16,
"toNodeId": 10,
"type": "child"
"entity": {
"attributes": {
"averageRequestRTT": 2443,
"averageResponseRTT": 7309,
"capabilities": [
"routing",
"beaming",
"listening"
"friendly_name": "Master Bathroom MultiSensor 6",
"is_awake": true,
"is_failed": false,
"is_ready": true,
"lastRequestRTT": 68,
"lastResponseRTT": 9492,
"manufacturer_name": "",
"neighbors": [
9,
10
"node_id": 16,
"node_name": "Unknown Node 16",
"product_name": "",
"receivedCnt": 3,
"receivedDups": 0,
"receivedTS": "2020-07-27 19:42:35:261 ",
"retries": 0,
"sentCnt": 12,
"sentFailed": 0,
"sentTS": "2020-07-27 19:47:14:790 "
"context": {
"id": "d77e701aa48846d5a1a99673c9e812a8",
"parent_id": null,
"user_id": null
"entity_id": "zwave.master_bathroom_multisensor_6",
"last_changed": "2020-07-28T02:42:35.873074+00:00",
"last_updated": "2020-07-28T02:47:14.962313+00:00",
"state": "ready"
"id": 6,
"name": "Front Sidewalk MultiSensor 6",
"hop": 1,
"neighbors": [
19,
9,
2,
10
"isPrimary": false,
"edges": [
"id": 6,
"toNodeId": 19,
"type": "parent"
"id": 6,
"toNodeId": 9,
"type": "sibling"
"id": 6,
"toNodeId": 2,
"type": "child"
"id": 6,
"toNodeId": 10,
"type": "sibling"
"entity": {
"attributes": {
"application_version": "1.13",
"averageRequestRTT": 312,
"averageResponseRTT": 353,
"battery_level": 100,
"capabilities": [
"routing",
"beaming",
"listening",
"zwave_plus"
"friendly_name": "Front Sidewalk MultiSensor 6",
"is_awake": true,
"is_failed": false,
"is_ready": true,
"lastRequestRTT": 369,
"lastResponseRTT": 388,
"neighbors": [
19,
9,
2,
10
"node_id": 6,
"node_name": "AEON Labs ZW100 MultiSensor 6",
"product_name": "ZW100 MultiSensor 6",
"receivedCnt": 249,
"receivedDups": 7,
"receivedTS": "2020-07-28 15:30:58:478 ",
"receivedUnsolicited": 240,
"retries": 0,
"sentCnt": 28,
"sentFailed": 1,
"sentTS": "2020-07-28 11:31:22:351 ",
"wake_up_interval": 3600
"context": {
"id": "b9ba605cf6a1467b9bfc3a2fd0f73b68",
"parent_id": null,
"user_id": null
"entity_id": "zwave.front_sidewalk_multisensor_6",
"last_changed": "2020-07-27T02:52:54.166918+00:00",
"last_updated": "2020-07-28T22:30:58.598910+00:00",
"state": "ready"
"id": 9,
"name": "Fountain Light Smart Energy Switch",
"hop": 1,
"neighbors": [
2,
6,
8,
10,
19
"isPrimary": false,
"edges": [
"id": 9,
"toNodeId": 2,
"type": "child"
"id": 9,
"toNodeId": 6,
"type": "sibling"
"id": 9,
"toNodeId": 8,
"type": "parent"
"id": 9,
"toNodeId": 10,
"type": "sibling"
"id": 9,
"toNodeId": 19,
"type": "parent"
"entity": {
"attributes": {
"application_version": "1.43",
"averageRequestRTT": 29,
"averageResponseRTT": 108,
"capabilities": [
"routing",
"beaming",
"listening"
"friendly_name": "Fountain Light Smart Energy Switch",
"is_awake": true,
"is_failed": false,
"is_ready": true,
"lastRequestRTT": 25,
"lastResponseRTT": 71,
"neighbors": [
2,
6,
8,
10,
19
"node_id": 9,
"node_name": "AEON Labs DSC06106 Smart Energy Switch",
"product_name": "DSC06106 Smart Energy Switch",
"receivedCnt": 21,
"receivedDups": 2,
"receivedTS": "2020-07-28 03:01:54:371 ",
"receivedUnsolicited": 8,
"retries": 0,
"sentCnt": 22,
"sentFailed": 0,
"sentTS": "2020-07-28 00:00:55:953 "
"context": {
"id": "9f3892a02df04ac19535dd74b0600b33",
"parent_id": null,
"user_id": null
"entity_id": "zwave.fountain_light_smart_energy_switch",
"last_changed": "2020-07-27T02:52:54.932807+00:00",
"last_updated": "2020-07-28T10:01:54.485077+00:00",
"state": "ready"
"id": 21,
"name": "Master Bathroom Light",
"hop": -1,
"neighbors": [
1,
2,
6,
8,
16,
19,
20
"isPrimary": false,
"edges": [
"id": 21,
"toNodeId": 1,
"type": "parent"
"id": 21,
"toNodeId": 2,
"type": "parent"
"id": 21,
"toNodeId": 6,
"type": "parent"
"id": 21,
"toNodeId": 8,
"type": "parent"
"id": 21,
"toNodeId": 16,
"type": "parent"
"id": 21,
"toNodeId": 19,
"type": "parent"
"id": 21,
"toNodeId": 20,
"type": "parent"
"entity": {
"attributes": {
"application_version": "1.47",
"averageRequestRTT": 425,
"averageResponseRTT": 1077,
"capabilities": [
"routing",
"beaming",
"listening",
"zwave_plus"
"friendly_name": "Master Bathroom Light",
"is_awake": true,
"is_failed": false,
"is_ready": true,
"lastRequestRTT": 541,
"lastResponseRTT": 626,
"neighbors": [
1,
2,
6,
8,
16,
19,
20
"node_id": 21,
"node_name": "Inovelli LZW31-SN Dimmer Red Series",
"product_name": "LZW31-SN Dimmer Red Series",
"receivedCnt": 1542,
"receivedDups": 178,
"receivedTS": "2020-07-28 16:06:25:497 ",
"receivedUnsolicited": 326,
"retries": 5,
"sentCnt": 2018,
"sentFailed": 747,
"sentTS": "2020-07-28 16:06:24:871 "
"context": {
"id": "80c07c85cbfa4b629c4dbe623a2297be",
"parent_id": null,
"user_id": null
"entity_id": "zwave.master_bathroom_light_working",
"last_changed": "2020-07-28T15:05:42.511450+00:00",
"last_updated": "2020-07-28T23:06:25.621188+00:00",
"state": "ready"
"id": 10,
"name": "Dan Desk Smart Energy Switch",
"hop": 1,
"neighbors": [
1,
2,
6,
8,
9,
19,
20
"isPrimary": false,
"edges": [
"id": 10,
"toNodeId": 1,
"type": "parent"
"id": 10,
"toNodeId": 2,
"type": "child"
"id": 10,
"toNodeId": 6,
"type": "sibling"
"id": 10,
"toNodeId": 8,
"type": "parent"
"id": 10,
"toNodeId": 9,
"type": "sibling"
"id": 10,
"toNodeId": 19,
"type": "parent"
"id": 10,
"toNodeId": 20,
"type": "sibling"
"entity": {
"attributes": {
"averageRequestRTT": 161,
"averageResponseRTT": 187,
"capabilities": [
"routing",
"beaming",
"listening"
"friendly_name": "Dan Desk Smart Energy Switch",
"is_awake": true,
"is_failed": false,
"is_ready": true,
"lastRequestRTT": 206,
"lastResponseRTT": 262,
"neighbors": [
1,
2,
6,
8,
9,
19,
20
"node_id": 10,
"receivedCnt": 38,
"receivedDups": 2,
"receivedTS": "2020-07-28 09:21:29:419 ",
"receivedUnsolicited": 31,
"retries": 0,
"sentCnt": 14,
"sentFailed": 0,
"sentTS": "2020-07-28 00:00:22:621 "
"context": {
"id": "700c36e1821742de85f6b3b460a69807",
"parent_id": null,
"user_id": null
"entity_id": "zwave.dan_desk_smart_energy_switch",
"last_changed": "2020-07-27T02:52:54.933272+00:00",
"last_updated": "2020-07-28T16:21:29.527009+00:00",
"state": "ready"
"id": 8,
"name": "Master Bedroom Smart Switch 6",
"hop": 2,
"neighbors": [
20
"isPrimary": false,
"edges": [
"id": 8,
"toNodeId": 20,
"type": "child"
"entity": {
"attributes": {
"application_version": "1.03",
"averageRequestRTT": 381,
"averageResponseRTT": 612,
"capabilities": [
"routing",
"beaming",
"listening",
"zwave_plus"
"friendly_name": "Master Bedroom Smart Switch 6",
"is_awake": true,
"is_failed": false,
"is_ready": true,
"lastRequestRTT": 525,
"lastResponseRTT": 614,
"neighbors": [
20
"node_id": 8,
"node_name": "AEON Labs ZW096 Smart Switch 6",
"product_name": "ZW096 Smart Switch 6",
"receivedCnt": 37,
"receivedDups": 0,
"receivedTS": "2020-07-27 21:27:57:619 ",
"receivedUnsolicited": 1,
"retries": 0,
"sentCnt": 70,
"sentFailed": 6,
"sentTS": "2020-07-27 21:27:57:005 "
"context": {
"id": "cc3a9b21733f4a3ca5cdd262e85e72a2",
"parent_id": null,
"user_id": null
"entity_id": "zwave.master_bedroom_smart_switch_6",
"last_changed": "2020-07-27T02:52:54.932277+00:00",
"last_updated": "2020-07-28T04:27:57.728398+00:00",
"state": "ready"
"id": 20,
"name": "Hall Dual Smart Switch",
"hop": 1,
"neighbors": [
8,
19,
2,
10
"isPrimary": false,
"edges": [
"id": 20,
"toNodeId": 8,
"type": "parent"
"id": 20,
"toNodeId": 19,
"type": "parent"
"id": 20,
"toNodeId": 2,
"type": "child"
"id": 20,
"toNodeId": 10,
"type": "sibling"
"entity": {
"attributes": {
"application_version": "1.01",
"averageRequestRTT": 34,
"averageResponseRTT": 60,
"capabilities": [
"routing",
"beaming",
"listening",
"zwave_plus"
"friendly_name": "Hall Dual Smart Switch",
"is_awake": true,
"is_failed": false,
"is_ready": true,
"lastRequestRTT": 26,
"lastResponseRTT": 43,
"neighbors": [
8,
19,
2,
10
"node_id": 20,
"node_name": "Inovelli Unknown: type=ff00, id=ff05",
"product_name": "Unknown: type=ff00, id=ff05",
"receivedCnt": 14,
"receivedDups": 1,
"receivedTS": "2020-07-28 06:10:52:050 ",
"retries": 0,
"sentCnt": 28,
"sentFailed": 0,
"sentTS": "2020-07-28 06:10:52:007 "
"context": {
"id": "b2500106985e4078824e536753f71c8b",
"parent_id": null,
"user_id": null
"entity_id": "zwave.hall_dual_smart_switch",
"last_changed": "2020-07-27T02:52:54.934222+00:00",
"last_updated": "2020-07-28T13:10:52.159916+00:00",
"state": "ready"
Hereâs an example of some node data you can get from the ozwd in the new version.
This is directly from the MQTT server:
"NodeID": 10,
"NodeQueryStage": "Complete",
"isListening": true,
"isFlirs": false,
"isBeaming": true,
"isRouting": true,
"isSecurityv1": false,
"isZWavePlus": true,
"isNIFRecieved": true,
"isAwake": true,
"isFailed": false,
"MetaData": {
"OZWInfoURL": "",
"ZWAProductURL": "",
"ProductPic": "",
"Description": "",
"ProductManualURL": "",
"ProductPageURL": "",
"InclusionHelp": "",
"ExclusionHelp": "",
"ResetHelp": "",
"WakeupHelp": "",
"ProductSupportURL": "",
"Frequency": "",
"Name": "",
"ProductPicBase64": ""
"Event": "nodeQueriesComplete",
"TimeStamp": 1595709552,
"NodeManufacturerName": "Linear (Nortek Security Control LLC)",
"NodeProductName": "GC-TBZ48 Battery Powered Z-Wave Thermostat",
"NodeBasicString": "Routing Slave",
"NodeBasic": 4,
"NodeGenericString": "Thermostat",
"NodeGeneric": 8,
"NodeSpecificString": "General Thermostat V2",
"NodeSpecific": 6,
"NodeManufacturerID": "0x014f",
"NodeProductType": "0x5442",
"NodeProductID": "0x5436",
"NodeBaudRate": 100000,
"NodeVersion": 4,
"NodeGroups": 3,
"NodeName": "",
"NodeLocation": "",
"NodeDeviceTypeString": "Thermostat HVAC",
"NodeDeviceType": 4608,
"NodeRole": 5,
"NodeRoleString": "Always On Slave",
"NodePlusType": 0,
"NodePlusTypeString": "Z-Wave+ node",
"Neighbors": [
1,
2,
6,
8,
9,
11,
14,
15,
16,
17,
18,
19,
20,
21,
22,
23,
26,
27,
28,
29,
30,
32,
33,
37,
38,
39,
41
"NodeID": 1,
"isFlirs": false,
"isBeaming": true,
"isRouting": false,
"isZWavePlus": false,
"isAwake": true,
"isFailed": false,
"MetaData": {
"OZWInfoURL": "http://www.openzwave.com/device-database/0086:005A:0101",
"ProductPic": "images/aeotec/zw090.png",
"Description": "Aeotec Z-Stick Gen5 is a USB controller. When connected to a host controller via USB, it enables the host controller to take part in the Z-Wave network. Products that are Z-Wave certified can be used and communicate with other Z-Wave certified devices.",
"ProductManualURL": "https://Products.Z-WaveAlliance.org/ProductManual/File?folder=&filename=Manuals/1355/Z Stick Gen5 manual 1.pdf",
"InclusionHelp": "Plug the Z-Stick into USB port of your host Controller and then click the âInclusionâ button on your PC/host Controller application.",
"ExclusionHelp": "Plug the Z-Stick into USB port of your host Controller and then click the âExclusionâ button on your PC/host Controller application.",
"ResetHelp": "Use this procedure only in the event that the primary controller is missing or otherwise inoperable. Press and hold the Action Button on Z-Stick for 20 seconds and then release.",
"WakeupHelp": "N/A",
"Frequency": "",
"Name": "Z-Stick Gen5",
"ProductPicBase64": "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"
"TimeStamp": 1595709344,
"NodeManufacturerName": "AEON Labs",
"NodeProductName": "ZW090 Z-Stick Gen5 US",
"NodeBasicString": "Static Controller",
"NodeBasic": 2,
"NodeGenericString": "Static Controller",
"NodeGeneric": 2,
"NodeSpecificString": "Static PC Controller",
"NodeSpecific": 1,
"NodeManufacturerID": "0x0086",
"NodeProductType": "0x0101",
"NodeProductID": "0x005a",
"NodeVersion": 4,
"NodeGroups": 0,
"NodeName": "",
"NodeLocation": "",
"NodeDeviceTypeString": "Unknown Type (0x0000)",
"NodeDeviceType": 0,
"NodeRole": 0,
"NodeRoleString": "Central Controller",
"NodePlusType": 0,
"Neighbors": [
2,
6,
8,
9,
10,
11,
14,
15,
16,
17,
19,
20,
21,
22,
23,
26,
27,
28,
29,
30,
32,
33,
36,
38,
39,
41,
42
