Same problem, I have a .homeconnect-token-cache file in my config dir.
After a restart the plugin works again.
Iāve had some problems lately, but I havenāt inspected muchā¦
It seems it suddenly loses connection because right now HA thinks the dishwasher is still running at 38% done and 2 hours left. Itās been like that for a few days. Ran it again today but nothing updated.
does this component work offline? I have a setting on my home connect app to only work locally and not use the cloud, so they support working without internet connection.
Here you can see the option for offline working.
Since Iām segregating the networks with the goal of removing internet access to my IOT lan, local connection is not working.
This integration is based in the API through the home connect server so offline is not going to work.
too bad we should avoid relying on cloud services.
Iāll inspect my network packages to see what can I find.
Thatās the whole idea of Home Assistant, donāt rely on other parties right? āYour system should run at home, not in the cloud.ā and āReclaim your privacyā.
But keep up the good work with Home Connect, but connect locally
I just set everything up but I get the following error when trying to register the integration:
"error": "unauthorized_client",
"error_description": "request rejected by client authorization authority (developer portal)",
"state": "XXXXXXXXXXXXX"
any idea on what Iām doing wrong?
Are you using the most up-to-date version? I have changed many things in the past few days, also the redirect URI must be changed. The new version only works under HA 0.102.
Yes, I just installed everything fresh today:
Home Assistant 0.102
Home connect component via HACS: 0.2.1
DuckDNS HASSIO plugin:
"lets_encrypt": {
"accept_terms": true,
"certfile": "fullchain.pem",
"keyfile": "privkey.pem"
"token": "XXXXXXXXXXXX",
"domains": ["AAABBBCCC.duckdns.org"
"seconds": 300
to test that this is working I even forwarded the port 8123 in my router to 8123 of my HA which made my HA accessible from the internet via the DuckDNS adress:
The configuration.yaml looks like this:
http:
base_url: https://AAABBBCCC.duckdns.org:8123
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
homeconnect:
client_id: !secret homeconnect_username
client_secret: !secret homeconnect_password
And in the developer account is set up like this:
Access: Private
OAuth Flow: Authorization Code Grant Flow
Redirect URIs: https://AAABBBCCC.duckdns.org:8123/auth/external/callback
One Time Token Mode: Disabled
Proof Key for Code Exchange: Disabled
That all looks correct, strange ā¦
Can you please try the following script using directly the Python module to make sure it is unrelated to Home Assistant:
from homeconnect import HomeConnect
import webbrowser
client_id = "..."
client_secret = "..."
redirect_uri = "https://..."
hc = HomeConnect(client_id, client_secret, redirect_uri)
webbrowser.open(hc.get_authurl())
auth_result = input("Paste authentication URL")
hc.get_token(auth_result)
appl = hc.get_appliances()
print(appl)
@Kugelfang note that client_id
and client_secret
are not your HomeConnect username and password (as indicated by your !secret homeconnect_username
, !secret homeconnect_password
settings)
ok but what are they? I was providing my actual user login credentials (so not the dev ones)
Go to https://developer.home-connect.com/applications and click on āDetailsā for your application. It should show āClient IDā and āClient Secret (required)ā.
well that did the trick!!! thanks a lot
Hi, I think I fix it. I can now start the oven, but not start any program. Someone has a better Oven look I can useā¦ This is my first post hereā¦
Unfortunately, starting oven programs is not allowed by the API at present. It requires a separate approval of a client application, which they will not grant for private developer applications I guess.
Once the component becomes an official part of Home Assistant, thanks to the new OAuth2 account linking feature described in the 0.102 release notes, this might however become possible at some point.
This stopped working some time ago and I havenāt looked at it until now. Reinstalled via HACS and cannot make it work. edited the redirect url and even made a new app - no luck. I get nothing in the logs.
This worked at least a few months back. And from what I can see here I only should need to edit the redirect url?
āNothing in the logsā cannot really be unless you somehow didnāt enable the componnent. There would be at least an error. After installing via HACS, did you
- Add the necessary entries to
configuration.yaml
? - Add the integration on the āIntegrationsā panel in Home Assistant?
Thanks! I hadnt done anything in the integrations panelā¦ Shame on me seems to work now
