Arrrg… i’ve forgott /bin/bash at the end of the command.
docker exec -it addon_441b9bcc_homegear /bin/bash
did but same error, will try now to rebuild, and then to uninstall and reinstall
I am happy to tell you that i have fixed the problem. In version 0.70.4 you can connect directly after start without any modification!
Hi, thanks now it installs. I do not have any devices yet, although when (in Homegear RPC Server menu) I press “ADMINISTRTATION”
I receive
Not Found
The requested URL admin/ was not found on this server.
Homegear 0.8.0-2378 at Port 2001
Mmhhhh… it seems to be the admin ui is not installed correctly. I will have a deeper look at this on sunday.
the addon doesn’t install on my hassio instance
18-11-26 10:37:28 INFO (SyncWorker_5) [hassio.docker.addon] Start build 89330960/armhf-addon-rpi-homegear:0.2
18-11-26 10:46:07 ERROR (SyncWorker_5) [hassio.docker.addon] Can’t build 89330960/armhf-addon-rpi-homegear:0.2: The command ‘/bin/sh -c apt-get update && apt-get -y install ntp tzdata homegear homegear-nodes-core homegear-nodes-extra homegear-homematicbidcos homegear-homematicwired homegear-insteon homegear-max homegear-philipshue homegear-sonos homegear-kodi homegear-ipcam homegear-beckhoff homegear-knx homegear-enocean homegear-intertechno homegear-influxdb vim less htop’ returned a non-zero code: 100
Hostname | hassio |
System | HassOS 1.12 |
Deployment | production |
Can anyobody help me out if that should work with HM-MOD-RPI-PCB? I am able to receive my device values like switch states and climate temperature/mode, but cannot send anything. I got:
12/26/18 14:42:49.855 Failed to set GPIO with index "1": Device not open.
Hi, any updates on this? Wishing to install it for next weekend, trying to have all up and running by then. Still do not know how to create a user in the server, from hassio
I’m so sorry for that. I have some trouble in my live that’s why i currently can’t spend enough time fixing the issue. When everything got sorted, i like to work again on this problem.
Hi all,
I’ve installed the Homegear Add-on from @kreativmonkey’s repository. I have a MAX Cube, flased with a-culfw that I want to integrate with Homeassistant.
I’m stuck after the installation. According to the supervisor, the add-on is installed and running. When I log into my homeassistant via SSH, I can read the homegear logs in /root/share/homegear/log
. It looks like it is running fine.
However, I can’t get to see the RPC UI, I tried all of the following:
http://homeassistant.local:2001
.The first two give me a blank page within the HA UI. The third gives a timeout. What should I do to get to this page?
I just downloaded Homematic Manager, and with that tool I’m able to connect to Homegear. Still, I’d love to know how to get to the Web UI of Homegear…
Another question: I am following this guide and I need to use the homegear CLI for that. I assume this lives inside the add-on’s docker container. How do I access that one?
Looks like this add-on is not working anymore.
I get these error messages in the HA add-on:
homegear | id: ‘homegear’: no such user
This is because homegear was not installed during docker image creation, as the uri in the Dockerfile for homegear is not valid anymore.
This line would be better:
echo 'deb https://homegear.eu/packages/Raspbian/ stretch/'
@kreativmonkey: could you please update your repository?
