okay this topic confused me a little…
so far i understand the source selector is working but volume not…
does anyone have a working copy for harmony hub (dont need explanation, just the config) edit: from my understanding i have to create a universal player and that should work in Homekit?
Creating a universal media and following @anthonygillet’s code further up in the thread will get it working. Feel free to message me if you are having trouble setting it up.
Once setup correctly working you will have a TV device displaying in the Apple Homekit app, representing your Harmony Hub. It includes and on/off button and source selection:
Though I am unsure how we can specify what the arrows, centre button, play/pause button, back button and info button can do. If anyone does know I’m interested if there is a way.
Update It looks like the guys working on the Homekit integration are discussing this issue of the iOS remote widget controls, and I think a method is on the horizon.
strangely, i have set up two universal media players for two different televisions, they both show up in homekit and can be turned on and off, but only one of them shows in the control center remote control app.
This is a known limitation. There can only be one television per HomeKit bridge. There has been some groundwork laid that enables multiple bridges inside of HomeAssistant via config flow, but I haven’t been able to test it out yet.
back on this topic.
looks like there is some progress.
I freshly installed installed home-assistant and was impressed that harmonyhub got easily installed, more impressed was I when I activated HomeKit and see that source selecting work out of the box.
but I notice that the D-Pad didn’t work … is this intended? I could maybe link the volume buttons manually to my receiver… but how do I link the left, right, top, left and ok buttons to it and change it dynamically per activity.
Backlog is better than completely off the radar. I’ll take it! I’m just reeeaaally hoping to ditch Homebridge. The Harmony plugin is the last one I am using.
Is this maybe what you are looking for. In my case I’ve used RestApi integration instead of pure adb commands to control my android tv. But remapping of remote widget buttons works. Using this as a reference to pint you to the right direction.
Not sure if there was a change since November, but you can at least react on events bwhen the buttons are pressed.
I just tested it, the events are showing up in the developer tools.
