HA running on 2021.1.5
Homewizard running on 0.4.2
But it’s fixed now, everything works again. I went into custom_components and deleted the folder and inside HA i deleted the intergration. After a re-boot i installed it again and not it works.
I am waiting for this PR to be accepted or this issue to be solved. At this moment this integration will show up as ‘new’ for every HACS user, even when dismissing. This should be solved when the PR is merged. Then I will release v0.5.0 to everyone
So because of the new metering system in Belgium I want an electric socket to activate as soon as my solar panels start injecting (or are injecting at least 1000W).
This to charge my car.
Tried as a test to have the socket react when production goes over 800W (since no injection at this time), but it is not reacting to the change.
Is the 800 a wrong unit to check?
It looks like you have it right. I have tested it (with a different action) and that works. But you can check a few things:
Check if your return is really at line 1(L1). You can also use sensor.p1_meter_active_power
Test is your problem is not the trigger, but the action. If you create this automation from the UI, you can press the ‘execute’ button at the top (below ‘name’ and ‘mode’). See if your action actually works.
got a question, I’m unable to connect to the device, even the link via the ip address doesn’t work. I get connection refused even thou i opened up the port 80 to the device. I’m hoping you had any ideas cause the info around it is poor
Please check in your app that you have firmware version 2.11 or higher. This should be automatically updated within an hour after connecting. If not, please send me the serial number of your device via a direct message.
