Honeywell CH/DHW via RF - evohome, sundial, hometronics, chronotherm
I have done this probably 5-6 time previously, when the issue was noticed originally - with the result always being the same.
Just to make sure, the below:
Should resolve this?
Yes, there is a fix to specifically address your 000C packets: that are a little odd, as described before.
As you’d expect, I do test these fixes against the logs you’ve already provided, but I also ask people to send up-to-date logs whenever there is an issue - even though I have the latest parser, the old logs were made with an old version of the engine, after all.
The truth is, experience has shown that debugging issues using logs made with older versions of the engine is incredible inefficient, and often ineffective…
In any case, IIRC, your issue isn’t exactly the same? That is, for some of your zones, all the actuators were missing, and now only some are missing for those zones?
That’s why I suggested:
Please rebind it to the zone. Please remove all hints for that zone. Reboot HA with no cache / no eavesdropping & see what happens.
This is from a previous post:
… and now: loook at actuators:
Having review your latest logs - I stand by my diagnosis: rebind the missing TRV to the zone (do both if you can’t recall which is which), and let me know if that doesn’t fix the problem.
To be clear: before ramses_rf wasn’t decoding certain 000C packets (those which were ‘strange’, and had more than one TRV/actuator), but now it is. Your zone 00 appears to have only one TRV bound.
If you wish, send the packet log of that process.
Some feedback after running 0.17.4 for a numer of days:
First, I have two HR92s (04:044933 and 04:256402) that have become orphans - there is no change to my evohome configuration and previous versions have correctly identified them with their respective zone. Restarting with restore_state: false does not help.
These HR92s each belong to zones with multiple HR92s, but they are not in the same zone as each other. I think what’s happening is that for zones with multiple HR92s, the packet parser is dropping the last one from the 000C RP.
Here are examples from my log for what looks like incorrect decoding:
2022-01-08 12:16:37 INFO (MainThread) [ramses_rf.protocol.protocol] rcvd: RP --- 01:225826 18:204306 --:------ 000C 018 00000010AF8700000010AF8100000010AF85
2022-01-08 12:16:37 INFO (MainThread) [ramses_rf.message] || CTL:225826 | HGI:204306 | RP | zone_devices     | 0000 || {'zone_idx': '00', '_device_class': '00', 'device_class': 'zone_actuators', 'devices': ['04:044935', '04:044929']}
and
2022-01-08 12:16:40 INFO (MainThread) [ramses_rf.protocol.protocol] rcvd: RP --- 01:225826 18:204306 --:------ 000C 012 06000013E99406000013E992
2022-01-08 12:16:40 INFO (MainThread) [ramses_rf.message] || CTL:225826 | HGI:204306 | RP | zone_devices     | 0600 || {'zone_idx': '06', '_device_class': '00', 'device_class': 'zone_actuators', 'devices': ['04:256404']}
It looks like the raw RP for zone 00 correctly contains three actuators but it gets decoded as two: the AF85 corresponding to the orphan 04:044933. Similarly the RP for zone 6 appears to correctly contain two actuators, but the 3E992 (corresponding to orphan 04:256402) gets dropped,
The second thing I’ve seen with 0.17.4 is a big increase in expired messages for a number of message types. Having said that, I’ve just done another restart (with restore_state: false) and they seem to have settled. I’ll keep my eyes on this and report back with details if it continues.
If it helps, here’s a packet log from today:
This contains two restarts: the first at 10:52 was with restore_state: true and the one at 12:16 was with restore_state:false.
(Edit: apologies I missed the last post which said there were some issues with multiple-actuator zones, however the log snippets above are from 0.17.4.)
Thank you for your very useful post - I have identified, and corrected this regression.
@iMiMx It appears I owe you an apology - my mistake was to rely upon the parser, without reviewing the underlying packet:
> cat .secrets/imimx/2022-01-05b.log | grep ' 000C 011 ' | python client.py -ns parse
09:43:21.506 || CTL:050858 | HGI:141846 | RP | zone_devices     | 0000 || {'zone_idx': '00', '_device_class': '00', 'device_class': 'zone_actuators', 'devices': ['04:055514', '04:055594']}
09:43:21.967 || CTL:050858 | HGI:141846 | RP | zone_devices     | 0008 || {'zone_idx': '00', '_device_class': '08', 'device_class': 'rad_actuators', 'devices': ['04:055514', '04:055594']}
A new drop will be coming later today - I will squeeze this fix in.
OK, version 0.17.6 released as a beta.
Adds some stuff for OTB, HVAC, and bugfixes.
Unfortunately I still see the same - 1 actuator, 1 missing device:
  zones:
    '00':
      _name: Living Room
      zone_type: radiator_valve
      zone_sensor: '22:245508'
      sensor_alt: '22:245508'
      devices:
        - '04:055514'
        - '22:245508'
      actuators:
        - '04:055514'
evohome_cc:
  serial_port:
    port_name: /dev/serial/by-id/usb-SHK_NANO_CUL_868-if00-port0
    baudrate: 57600
  packet_log:
    file_name: /config/packet.log
    rotate_backups: 3
  ramses_rf:
   enforce_known_list: true
   max_zones: 8
  schema:
    controller: 01:050858
    # zones:
    #   '00':
    #     devices:
    #       - '04:055594'
    #       - '04:055514'
  known_list:
    - 01:050858 # Controller
I restarted with restore_state: false - unfortunately my ‘patch Sunday’ early morning maintenance window has had to end early, the house is waking up.
I shall try rebinding it, if you consider this to still be a good thing to rule out, tomorrow and will ping over a packet log for this latest version if it is of any use?
EDIT: Even though I selected beta and 0.17.6 from the down down, the version.py shows as:
__version__ = "0.17.4" # revision 0
So for a reason as yet unknown, it looks like it still installed 0.17.4 - will investigate this further and/or install manually.
EDIT 2: Not sure if this is a HACs bug, but it seems to show 0.17.6 out-of-order in the list (HACs did update as well, recently)
Reinstalling again and I have 0.17.6 - although perhaps related to the ‘out of order’ listing, it seems to think that 0.17.6 is an older version to 0.17.4:
Again, not sure if this is a HACs bug, but it seems to change between showing the plugin as ‘RAMSES RF’ and ‘Evohome Cc’, maybe this changes between restarts, or as HA is starting up etc.
When correctly running 0.17.6 it does indeed seem to resolve the problem - much obliged:
  zones:
    '00':
      _name: Living Room
      devices:
        - '04:055514'
        - '04:055594'
        - '22:245508'
      actuators:
        - '04:055514'
        - '04:055594'
My TRVs are also now back in the correct place using 0.17.6. Thanks.
@stevieb12345 I would love to see you run 0.17.6, and send me a packet log after you’ve fiddled with all your HVAC (PIV) switches. Please go through all the modes (fan speed/fan off/heater on/boost/whatever)
Sorry - will be 0.17.7, or higher. your CO2 sensor should show up now, though.
I have deleted all the old releases - only two now - stable (older version) & pre-release (newer version).
i have got the next error in my log:
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 382, in async_add_entities
    await asyncio.gather(*tasks)
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 520, in _async_add_entity
    original_icon=entity.icon,
  File "/config/custom_components/evohome_cc/sensor.py", line 141, in icon
    return "mdi:radiator-off" if self.state == 0 else "mdi:radiator"
  File "/config/custom_components/evohome_cc/sensor.py", line 124, in state
    return state * 100 if state is not None else None
TypeError: unsupported operand type(s) for *: 'Message' and 'int'
There’s something unfortunate about the word ‘next’ - sorry!
Help me a little:
  • did this happen during startup (if it didn’t, and now it does, don’t restore_state for the next restart & see if that helps)
  • what version - does it happen with both versions
  • did you change you evohome configuration
This is a heat_demand - the most complicated sensor, by far - may be difficult to get to the bottom off.
Anyone else have this issue?
@zxdavb I am sorry! I don’t mean anything wrong with it. In Dutch we use “next” to indicate something in Dutch written language.
It happens after an update to version 17.6.
After a restart with restore_state: false, it doesn’t popup anymore.
Can i support you with the itho fan part?
No, to be clear: I’m not upset at all - it was irony - a joke I was making at myself. I think ‘next’ was about right after what I did to @imimx & co.!
And it is now OK with restore_state: true - I wonder if it was a corrupt packet? The code should handle that, though…
Do you use (or have you recently added) a known_list - do you have UFH or a Zone Valve zone?
The next drop has a lot of HVAC refactoring - switches, sensors, etc. So I will need help with that.
It also has a super special new feature!
When i set restore_state: true i get the old error again. I use UFH and valves.
I use as config:
evohome_cc:
  serial_port: /dev/ttyUSB-EVOHOME
  scan_interval: 60
  packet_log:
    file_name: /config/evohome_cc.log
    rotate_backups: 3
  restore_state: true
  ramses_rf:
    max_zones: 10
  schema:
    controller: 01:087939
    system:
      heating_control: 10:078099
  known_list:
    - 01:087939 # Controller
    - 04:225661 # Badkamer
    - 04:225663 # Slaapkamer Evi
    - 02:017205 # Woonkamer
    - 04:023992 # Kastenkamer
    - 04:059569 # Slaapkamer
    - 04:225657 # Toilet
    - 04:024000 # Slaapkamer Nova
    - 10:078099 # Heating control
    - 18:073736 # Vloerverwarming (UFH)
  advanced_features:
    send_packet: false
    message_events: true
Could you also take a look about the log config? it doesn’t stop at 3 days. i have still the logs from 14 days and older.
This is a known bug. I had a quick look, and it needs a long look.
  known_list:
    - 02:017205 # Woonkamer (UFH controller)
    - 18:073736 # Gateway (HGI80-compatible)
    - 20:007902: {"class": "FAN"},
    - 20:032436: {"class": "FAN"},
    - 44:072017: {"class": "SWI"}
Please provide me with your latest packet logs (24-48h) - and a copy of the schema from the HA UI - look for 01:087939 (schema)
There will be a couple of restarts in my log files. Is that a problem?
No - I want all that. Also, I am just about you update your known_list, above, again.
Please let me know your Itho make/models.
log today: https://file.io/09XEyb0AeXXy
log 09-01-22: https://file.io/ysSjHNa7WxnX
log 08-01-22: https://file.io/0Xizd0ffuj9I
schema:
system:
  heating_control: '10:078099'
orphans: []
stored_hotwater: {}
underfloor_heating: {}
zones:
  '00':
    _name: Woonkamer
    zone_type: underfloor_heating
    zone_sensor: null
    sensor_alt: null
    devices: []
    actuators: []
  '01':
    _name: Badkamer
    zone_sensor: '04:225661'
    sensor_alt: '04:225661'
    devices:
      - '04:225661'
    actuators:
      - '04:225661'
  '02':
    _name: Slaapkamer Evi
    zone_sensor: '04:225663'
    sensor_alt: '04:225663'
    devices:
      - '04:225663'
    actuators:
      - '04:225663'
  '03':
    _name: Kastenkamer
    zone_sensor: '04:023992'
    sensor_alt: '04:023992'
    devices:
      - '04:023992'
    actuators: []
  '04':
    _name: Toilet
    zone_sensor: '04:225657'
    sensor_alt: '04:225657'
    devices:
      - '04:225657'
    actuators:
      - '04:225657'
  '05':
    _name: Slaapkamer Nova
    zone_sensor: '04:024000'
    sensor_alt: '04:024000'
    devices:
      - '04:024000'
    actuators:
      - '04:024000'
  '07':
    _name: Slaapkamer
    zone_sensor: '04:059569'
    sensor_alt: '04:059569'
    devices:
      - '04:059569'
    actuators:
      - '04:059569'
friendly_name: 01:087939 (schema)
Do i also have to add this:
to my known_list?
