updated to 0.17.10 and all is fine. My ventilation is reporting fan speed and indoor humidity now and the values seems valid. This is an improvement over 0.17.7a
The rest seems to work as before.
Thanks a lot for the hard work
Generally seems good for me - although the below appears to still be broken:
Seems not just for me:
This is the latest I get, when I try:
2022-01-16 08:04:46 ERROR (SyncWorker_2) [ramses_rf.protocol.command] set_zone_mode('01:050858', 0, 'temporary_override', None, None, {}): Invalid args: For temporary_override, setpoint/active cant be None
File "/usr/local/lib/python3.9/site-packages/ramses_rf/protocol/command.py", line 174, in _wrapper
return fcn(cls, *args, **kwargs)
File "/usr/local/lib/python3.9/site-packages/ramses_rf/protocol/command.py", line 762, in set_zone_mode
mode = _normalise_mode(mode, setpoint, until, duration)
File "/usr/local/lib/python3.9/site-packages/ramses_rf/protocol/command.py", line 247, in _normalise_mode
raise ValueError(
ValueError: Invalid args: For temporary_override, setpoint/active cant be None
2022-01-16 08:04:46 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [139629013814912] 'NoneType' object has no attribute '_source_entity'
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 185, in handle_call_service
await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 1495, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1530, in _execute_service
await handler.job.target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 209, in handle_service
await self.hass.helpers.service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 663, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 896, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 700, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/components/climate/__init__.py", line 486, in async_set_preset_mode
await self.hass.async_add_executor_job(self.set_preset_mode, preset_mode)
File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 52, in run
File "/config/custom_components/evohome_cc/climate.py", line 258, in set_preset_mode
self.svc_set_zone_mode(mode=ZoneMode.TEMPORARY)
File "/config/custom_components/evohome_cc/climate.py", line 287, in svc_set_zone_mode
self._call_client_api(
File "/config/custom_components/evohome_cc/__init__.py", line 396, in _call_client_api
func(*args, **kwargs)
File "/usr/local/lib/python3.9/site-packages/ramses_rf/zones.py", line 844, in set_mode
return self._send_cmd(cmd)
File "/usr/local/lib/python3.9/site-packages/ramses_rf/entities.py", line 225, in _send_cmd
cmd._source_entity = self
AttributeError: 'NoneType' object has no attribute '_source_entity'
Sensor binary_sensor.18_141846_config seems to be unavailable, not sure if I need to try restore_cache: false, whether itās supposed to be like this on my system, etc.
I manually disable these in the UI, it then hides them easily enough - I donāt seem to have āflame_activeā I assume thatās for OpenTherm etc which I donāt have.
Yes, this bug has been around for years. It is because I have been focussed upon sensors, and not Climate - there are other bugs too - I will look at Climate presently (when I also hope to add HVAC).
Until then, simply use the official evohome TCC integration.
dev_el_ops is a special case - his system is not evohome (so perhaps he could PM me with these conscerns, so to not excite others too much).
Correct: OpenTherm is very variable - it depends upon the specifics of the make/model of your boiler - I cannot get too involved in this (is too much work) - just disable the entities.
I will warn OpenTherm users - you have two of many sensorsā¦ in future it will be only one of everything.
It will be permanently unavailable. Delete/remove it from HA.
It has been replaced by a new binary sensor, in your case: binary_sensor.18_141846_status
, which contains the same extra state attributes , and is much more usefulā¦
When that binary sensor is true, it will be because there is a problem with your HGI80 compatible (evofw3) dongle.
Anyone here running on a raspberry pi? I seem to have a problem where it keeps restarting and just want to see if there are any other people out there who is on the latest version.
Your Pi keeps restarting?
yup, supervisor keeps restarting
an example from last nights logs
22-01-15 17:43:23 ERROR (MainThread) [supervisor.homeassistant.api] Error on call http://172.30.32.1:8123/api/config:
22-01-15 17:43:28 ERROR (MainThread) [supervisor.homeassistant.api] Error on call http://172.30.32.1:8123/api/config:
22-01-15 17:43:28 WARNING (MainThread) [supervisor.misc.tasks] Watchdog miss API response from Home Assistant
22-01-15 17:45:04 ERROR (MainThread) [supervisor.homeassistant.api] Error on call http://172.30.32.1:8123/api/config:
22-01-15 17:45:59 ERROR (MainThread) [supervisor.homeassistant.api] Error on call http://172.30.32.1:8123/api/config:
22-01-15 17:45:59 ERROR (MainThread) [supervisor.misc.tasks] Watchdog found a problem with Home Assistant API!
22-01-15 17:45:59 INFO (SyncWorker_4) [supervisor.docker.interface] Restarting ghcr.io/home-assistant/raspberrypi4-64-homeassistant
22-01-15 17:47:45 ERROR (MainThread) [supervisor.homeassistant.api] Error on call http://172.30.32.1:8123/api/config:
22-01-15 17:48:30 ERROR (MainThread) [supervisor.homeassistant.api] Error on call http://172.30.32.1:8123/api/config:
22-01-15 17:49:39 WARNING (MainThread) [supervisor.homeassistant.websocket] Connection is closed
Its happening to both my Pis that are running evohome_cc, as soon as I upgrade past v0.17.6 it starts going into this restart cycle.
Iāve now disabled everything apart from evohome_cc on one of them, lets see how that goes
Iāve got the same problem on my Nuc. Rolling back to 17.6 solves the issue. Iāve messaged David about it and heās going to look in to it.
22-01-16 11:03:39 ERROR (MainThread) [supervisor.homeassistant.api] Error on call http://172.30.32.1:8123/api/config:
22-01-16 11:03:39 WARNING (MainThread) [supervisor.misc.tasks] Watchdog miss API response from Home Assistant
22-01-16 11:04:24 ERROR (MainThread) [supervisor.homeassistant.api] Error on call http://172.30.32.1:8123/api/config:
22-01-16 11:06:10 ERROR (MainThread) [supervisor.homeassistant.api] Error on call http://172.30.32.1:8123/api/config:
22-01-16 11:06:10 ERROR (MainThread) [supervisor.misc.tasks] Watchdog found a problem with Home Assistant API!
ah, nice to know that Iām not going mad.
Do you have any other integrations and plugins running?
I have a few running, itās took me over a week to narrow it down to when I updated evohome.
Anything above 17.6 and the problems start within 15 minutes.
same symptoms here. Canāt get it stable on anything after that. Thanks
have you replaced restore_state: true
with restore_cache: true
as explained in the release notes?
Yes, it wonāt start otherwise, the problem is that it starts fine but then supervisor starts restarting itself
So, I am back from the kidsā soccerā¦
I understand two people are having issues running anything >0.17.6 on a Pi. I understand issues occur fairly reliably after about 15 minutes.
Can anyone running 0.17.10 without any issue let us know - let us know if it is on a Pi.
For those with issues, please run 0.17.7 with with this logging:
logger:
default: warn
logs:
homeassistant.core: debug
homeassistant.helpers.entity: info
ramses_rf.message: info
Restart HA, wait for it to crash, and send me the HA log, home-assistant.log
If that fails, weāll try:
logger:
default: info
In the meantime, I will do a code review between 0.17.6 and 0.17.7.
Running HA core on a pi, no issue here with 0.17.10 and HA 2021.12.9. I guess itās only occurring on supervised instances?
There are a lot of changes between 0.16.6 and 0.17.10, but relatively few between it at 0.17.7 - I have just had a look at them allā¦ I canāt see where there would be an issueā¦
Even with a memory leak, 15 mins isnāt enough for it to take an effect?
Thanks for looking into this, Iāve enabled those logs and will get them over to you soon.
The bug looks related to ssd drives connected via usb, Iām using a sd card.
It does seem to be a supervisor problem and not the core.
My point is as above.
stupid question here, does the sd card use usb?
