Short answer: when I am convinced I have stopped creating breaking changes.
FYI: There will be no updates for 0.18.x, nor 0.19.x and unless you have HVAC, 0.20.x offers only a little extra in terms of day-to-day use (although Zone/DHW schedules are coming soon).
Mind you, if you are using ramses_cc for CH/DHW (evohome), then you are better off leaping now, rather than waiting fro next Winter.
You can enable the ability to download pre-releases in the HACS UI.
Alright. Iâll migrate this week to the latest beta release.
I was kind of hoping that perhaps a newer version would increase stability, but I guess this is not the case?
Every couple of days the integration crashes and I lose all entities. Only a system restart resolves it, until the next crash a couple days later.
Nothing interesting in the logs really other than occasional warning about expired packages and once in a while an error that looks like this:
I havenât really had regular reports of persistent instability - anyone else?
It is the case that the 0.20.x version will have made much of the 0.18.x / 0.19.x codebase much more reliable - but I have reduced the safetyâs in response to that, and it it a significant refactor - YMMV - worth a go, I feel (I will address / have addressed any bugs ASAP).
hi all,
could somebody have a look at my configuration for the 0.20.11 release?
it is probably something simple with the spacing,but i do not see my error. even with my reading glasses on.
i recieve the following error: voluptuous.error.MultipleInvalid: extra keys not allowed @ data[âsystemâ][âzonesâ]
my configuration (i used the minimal schema example):
Iâve started migration. Iâm stuck at step 4. Iâve changed the configuration.yaml but when I restart HA I get an error:
This error originated from a custom integration.
Logger: homeassistant.setup
Source: custom_components/ramses_cc/__init__.py:92
Integration: ramses_cc (documentation, issues)
First occurred: 9:41:36 AM (1 occurrences)
Last logged: 9:41:36 AM
Error during setup of component ramses_cc
File "/usr/src/homeassistant/homeassistant/setup.py", line 235, in _async_setup_component
result = await task
File "/config/custom_components/ramses_cc/__init__.py", line 92, in async_setup
client = ramses_rf.Gateway(serial_port, loop=hass.loop, **config, **schema)
File "/usr/local/lib/python3.10/site-packages/ramses_rf/gateway.py", line 329, in __init__
load_schema(self, **self._schema)
File "/usr/local/lib/python3.10/site-packages/ramses_rf/schema.py", line 369, in load_schema
File "/usr/local/lib/python3.10/site-packages/ramses_rf/schema.py", line 370, in <listcomp>
load_system(gwy, ctl_id, schema)
File "/usr/local/lib/python3.10/site-packages/ramses_rf/schema.py", line 390, in load_system
ctl.tcs._update_schema(**schema) # TODO
File "/usr/local/lib/python3.10/site-packages/ramses_rf/systems.py", line 211, in _update_schema
schema = shrink(SCH_SYS(schema))
File "/usr/local/lib/python3.10/site-packages/voluptuous/schema_builder.py", line 272, in __call__
return self._compiled([], data)
File "/usr/local/lib/python3.10/site-packages/voluptuous/schema_builder.py", line 595, in validate_dict
return base_validate(path, iteritems(data), out)
File "/usr/local/lib/python3.10/site-packages/voluptuous/schema_builder.py", line 433, in validate_mapping
raise er.MultipleInvalid(errors)
voluptuous.error.MultipleInvalid: extra keys not allowed @ data['system']['zones']
Not fully sure on the known list because it doesnât say anything about that on the breaking changes page in the example schema. I also find it weird that I have to list all the IDâs twice. Once in the schema and once in the known list (canât that known list be taken from the schema automatically?).
I tried to put the fake sensor stuff in the sensor tag in the zone but it wouldnât take that either.
PS: I know I skipped zone 03. And started from 00. No idea, I took this schema from the controller attribute before I started the migration. If you want to see it, here it is:
Sorry, no: I donât have time to go over it, but it is a bad idea. Instead:
a) have a completeknown_list
b) have the smallest schema you can get away with, usually:
BTW, if I understand correctly, youâre asking why it goes 00-02, then 04-06, and not (say):
00 to 05, or
01 to 06
The answer is: these are not ordinals, but slot numbers (starting from slot 0x00). If you create a zone, it always uses the lowest available slot, 03 in your case, then 07 after that.
If I had created 7 zones (00 to 06), then deleted the 4th zone (03), I would see what you are seeing.
Thanks for all the help.
I did try putting the zone number between " " as per the previous post but that didnât help me.
I just removed the entire âsystemâ piece since you said:
Looks like everything is working fine
Only thing I noticed is that when I call ramses_cc.put_zone_temp it immediately triggers an error in the log:
Logger: ramses_rf.protocol.transport
Source: /usr/local/lib/python3.10/site-packages/ramses_rf/protocol/transport.py:915
First occurred: 1:06:50 PM (3 occurrences)
Last logged: 1:06:51 PM
have seen tx_rcvd( I --- 18:205572 63:262142 --:------ 7FFF 023 00110181F73D79DA33304339204930333A323536303134), rx_rcvd=None
have seen tx_rcvd( I --- 03:256014 --:------ 03:256014 30C9 003 0007D0), rx_rcvd=None
It does work fine, however, the temperature is correctly updated.
And thatâs one example why having a minimal schema is good practice.
Many of these are for my benefit only - I lose track of what is in the Dev version & what is in the Production version (sorry) - they can usually be ignored.
i am not sure. my heating system contains of evohome (8x HR91, 1x evohome touch 1x open therm R881) and my boiler which is a Nefit/Bosch system. they use the EMS bus to communicate. to connect the open therm module to the boiler, i had to place a open therm/EMS converter inbetween. so i suppose this might be it.
i doubt it is mine. we do have a fan (Brink Renovent) and a wireless remote in the bathroom. but this is a very basic system. the remote receiver at the fan, consists of simply 2 relays and a receiver in a box. i looked in the log at the time of the messages. we would usually operate the fan around 19:30, when it is time to hose the kids down. but i see no messages around that time
