Is it not because you are using the newer config YAML on 20.15a instead of 20.18 and above?
@stevieb12345 20.15a seems to be the latest ramses_cc
release. (I has ramses_rf 20.14
in its manifest.json
so that is actually all right). Iâll try to edit that and see if that fixes this. EDIT: It doesnât. It just breaks more stuffâŚ
EDIT2: OUCH. ouch. ouch. For some reason HACS is not showing beta versions. Although I did enable the âshow beta versionsâ checkbox. I just tried downloading 20.19 again (20.20 is on github but not in my HACS list) and it happily installed 20.15 again⌠???
@tomkooij If youâve seen my message on gitterâŚ
You might be better off just running the latest master. It includes the new remote entity, with learning.
Iâll give it a try.
Sadly, HACS installs 0.20.15
when I selected master
from the drop downâŚ
Iâll try to remove some stuff and install it one-by-one.
So I finally managed to convince HACS to actually install master (bc76233
). I checked and it actually installed that version into custom_components/ramses_cc
But that fails when restarting HA:
Logger: homeassistant.loader
Source: custom_components/ramses_cc/__init__.py:482
Integration: RAMSES RF (documentation, issues)
First occurred: 13:22:16 (1 occurrences)
Last logged: 13:22:16
Unexpected exception importing component custom_components.ramses_cc
File "/usr/src/homeassistant/homeassistant/loader.py", line 599, in get_component
cache[self.domain] = importlib.import_module(self.pkg_path)
File "/usr/local/lib/python3.9/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1030, in _gcd_import
File "<frozen importlib._bootstrap>", line 1007, in _find_and_load
File "<frozen importlib._bootstrap>", line 986, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 680, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 850, in exec_module
File "<frozen importlib._bootstrap>", line 228, in _call_with_frames_removed
File "/config/custom_components/ramses_cc/__init__.py", line 467, in <module>
class RamsesEntity(Entity):
File "/config/custom_components/ramses_cc/__init__.py", line 482, in RamsesEntity
_attr_icon: str | None
TypeError: unsupported operand type(s) for |: 'type' and 'NoneType'
Oh. I think Iâm running Python 3.10.x ⌠You must be on 3.9.x!
Can someone submit a PR to masterâŚ
Add the following immediately after the docstring, at the beginning of each *.py file:
from __future__ import annotations
(I would do it but Iâm not near a PC for the next week)
Indeed, my HA container runs python 3.9.12.
Merged! Just update via HACS⌠You will have to refresh/redownload.
Did it work?
I left my PC just after I submitted the PR. Will try to install master later tonight.
@zxdavb : Yes, works! thanks a lot!
Then Iâd like to see how you get on with the new remote entity!
(Which is undocumented, except in gitter)
Sorry here i am again with the the next error:
File "/usr/src/homeassistant/homeassistant/setup.py", line 235, in _async_setup_component
result = await task
File "/config/custom_components/ramses_cc/__init__.py", line 92, in async_setup
await broker.create_client() # start with a merged/cached, config, null schema
File "/config/custom_components/ramses_cc/__init__.py", line 252, in create_client
self.client = Gateway(
TypeError: ramses_rf.gateway.Gateway() got multiple values for keyword argument '01:087939'
My config:
ramses_cc:
serial_port: /dev/ttyUSB-EVOHOME
packet_log:
file_name: /config/ramses_cc.log
rotate_backups: 28
ramses_rf:
enforce_known_list: true
01:087939:
system:
appliance_control: 10:078099
orphans_hvac: [02:153425, 20:007902]
known_list:
- 01:087939 # Controller
- 02:017205 # Woonkamer (UFH controller)
- 04:023992 # Kastenkamer
- 04:024000 # Slaapkamer Nova
- 04:059569 # Slaapkamer
- 04:225657 # Toilet
- 04:225661 # Badkamer
- 04:225663 # Slaapkamer Evi
- 10:078099 # Heating control
- 18:073736 # Gateway (HGI80-compatible)
- 02:153425: {"class": REM, _note: "Itho CVE RF Switch"}
- 20:007902: {"class": FAN, _note: "Itho CVE Fan"}
Ah, this one I recognize: the known_list
is no longer a list but a dict. You need to remove the -
in front of each entry and instead add a :
as the last character. Example:
known_list:
01:087939: # Controller
02:017205: # Woonkamer (UFH controller)
etc.
Thx for the tip but it doesnât fix the problem:
i have removed the - and add a : at the last posistion of each rule. i get now the next error:
Invalid config for [ramses_cc]: expected a list for dictionary value @ data['ramses_cc']['known_list']. Got OrderedDict([('01:087939', None), ('02:017205', None), ('04:023992', None), ('04:024000', None), ('04:059569', None), ('04:225657', None), ('04:225661', None), ('04:225663', None), ('10:078099', None), ('18:073736', None), ('02:153425', OrderedDict([('class', 'REM'), ('_note', 'Itho CVE RF Switch')])), ('20:007902', OrderedDict([('class', 'FAN'), ('_note', 'Itho CVE Fan')]))]). (See ?, line ?).
What version are you using?
Version 0.20.15a, also tested the master version but both gaves the same error.
@Kars is right: the known_list is definitely a dict (no -) of dicts (trailing :).
I think you have HVAC? If so: I suggest trying the master branch, but otherwise 0.20.15a
I think it is merging your cached (but dated) schema with your configuration schema, so start with:
ramses_cc:
restore_cache:
restore_state: true
restore_schema: false
Note with master, the schema changed a little more:
ramses_cc:
01:123456:
system:
Invalid config for [ramses_cc]: expected a list for dictionary value @ data['ramses_cc']['known_list']. Got OrderedDict([('01:087939', None), ('02:017205', None), ('04:023992', None), ('04:024000', None), ('04:059569', None), ('04:225657', None), ('04:225661', None), ('04:225663', None), ('10:078099', None), ('18:073736', None), ('02:153425', OrderedDict([('class', 'REM'), ('_note', 'Itho CVE RF Switch')])), ('20:007902', OrderedDict([('class', 'FAN'), ('_note', 'Itho CVE Fan')]))]). (See ?, line ?). Please check the docs at https://github.com/zxdavb/ramses_cc
my config:
ramses_cc:
restore_cache:
restore_state: true
packet_log:
rotate_backups: 28
ramses_rf:
01:087939:
system:
known_list:
04:023992: # Kastenkamer
04:024000: # Slaapkamer Nova
04:059569: # Slaapkamer
04:225657: # Toilet
04:225661: # Badkamer
04:225663: # Slaapkamer Evi
10:078099: # Heating control
18:073736: # Gateway (HGI80-compatible)
