@zxdavb
- config
ramses_cc:
serial_port: /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A50285BI-if00-port0
ramses_rf:
# disable_discovery: true
# disable_sending: true
# enable_eavesdrop: true
enforce_known_list: true
scan_interval: 60
restore_cache: false
01:xxxxxx:
zones:
"00": {sensor: 01:xxxxxx}
01:yyyyyy:
zones:
"01": {sensor: 01:yyyyyy}
known_list:
01:xxxxxx: # CONTROLLER Jedilnica
01:yyyyyy: # CONTROLLER Ucilnica
18:dddddd: # USB NanoCUL
13:zzzzzz: # BDR91
# 00 HR92 Jedilnica (Jedilnica
04:kkkkkk: # 01 HR92 Kuhinja (Jedilnica)
34:kkkkkk: # 01 T87RF Kuhinja (Jedilnica)
04:kkkkkk: # 02 HR92 Sp Kopalnica (Jedilnica)
04:kkkkkk: # 03 HR92 Likalnica (Jedilnica)
04:kkkkkk: # 04 HR92 Plava (Jedilnica)
34:kkkkkk: # 04 T87RF Plava (Jedilnica)
04:kkkkkk: # 05 HR92 Zg Kopalnica (Jedilnica)
04:kkkkkk: # 06 HR92 Miha Ucilnica (Jedilnica)
34:kkkkkk: # 06 T87RF Miha Ucilnica (Jedilnica)
04:kkkkkk: # 07 HR92 Veranda (Jedilnica)
04:kkkk74: # 08 HR92 Pralnica (Jedilnica)
04:kkkk94: # 08 HR92 Pralnica (Jedilnica)
# 09 HR92 Veza (Jedilnica)
04:kkkkkk: # 0A/10 HR92 Luka Pisarna (Jedilnica)
04:kkkkkk: # 0B/11 HR92 Dnevna (Jedilnica)
04:kkkkkk: # 00 HR92 Mama Spalnica (Ucilnica)
34:kkkkkk: # 00 T87RF Mama Spalnica (Ucilnica)
04:kkkkkk: # 01 HR92 Ucilnica_1 (Ucilnica)
04:kkkkkk: # 01 HR92 Ucilnica_2 (Ucilnica)
04:kkkkkk: # 02 HR92 Pisarna (Ucilnica)
04:kkkk14: # 03 HR92 Kopalnica (Ucilnica)
04:kkkk22: # 03 HR92 Kopalnica (Ucilnica)
# 04 HR92 Kuhinja (Ucilnica)
04:kkkkkk: # 05 HR92 Vhod (Ucilnica)
04:kkkkkk: # 06 HR92 Miha Spalnica (Ucilnica)
04:kkkkkk: # 07 HR92 Luka Spalnica (Ucilnica)
04:kkkkkk: # 08 HR92 Miha Predsoba (Ucilnica)
04:kkkkkk: # 09 HR92 Miha WC (Ucilnica)
- xxxxxx schema (Jedilnica)
Schema
system:
appliance_control: '13:zzzzzz'
orphans: []
stored_hotwater: {}
underfloor_heating: {}
zones:
'00':
_name: Jedilnica
class: radiator_valve
sensor: '01:xxxxxx'
actuators: [] <--- missing
'01':
_name: Kuhinja
sensor: '34:kkkkkk'
actuators:
- '04:kkkkkk'
'02':
_name: Sp Kopalnica
sensor: '04:kkkkkk'
actuators:
- '04:kkkkkk'
'03':
_name: Likalnica
sensor: '04:kkkkkk'
actuators:
- '04:kkkkkk'
'04':
_name: Plava
sensor: '34:kkkkkk'
actuators:
- '04:kkkkkk'
'05':
_name: Zg Kopalnica
sensor: '04:kkkkkk'
actuators:
- '04:kkkkkk'
'06':
_name: Miha Ucilnica
sensor: '34:kkkkkk'
actuators:
- '04:kkkkkk'
'07':
_name: Veranda
sensor: '04:kkkkkk'
actuators:
- '04:kkkkkk'
'08':
_name: Pralnica
sensor: '04:kkkk74'
actuators:
- '04:kkkk74' <--- one is fake/missing
- '04:kkkk94' <--- one is fake/missing, probably this one because it isnt in sensor
'09':
_name: Veza
sensor: null <--- missing
0A:
_name: Luka Pisarna
sensor: '04:kkkkkk'
actuators:
- '04:kkkkkk'
0B:
_name: Dnevna
sensor: '04:kkkkkk'
actuators:
- '04:kkkkkk'
- yyyyyy schema (Ucilnica)
Schema
system:
appliance_control: null <--- missing BDR (check under 5. Errors)
orphans: []
stored_hotwater: {}
zones:
'00':
_name: Mama Spalnica
sensor: '34:kkkkkk'
actuators:
- '04:kkkkkk'
'01':
_name: Ucilnica
sensor: '01:yyyyyy'
actuators:
- '04:kkkkkk'
- '04:kkkkkk'
'02':
_name: Pisarna
sensor: '04:kkkkkk'
actuators:
- '04:kkkkkk'
'03':
_name: Kopalnica
sensor: '04:kkkk22'
actuators:
- '04:kkkk14' <--- one is fake/missing, probably this one because it isnt in sensor
- '04:kkkk22' <--- one is fake/missing
'04':
_name: Kuhinja
'05':
_name: Vhod
sensor: '04:kkkkkk'
actuators:
- '04:kkkkkk'
'06':
_name: Miha Spalnica
sensor: '04:kkkkkk'
actuators:
- '04:kkkkkk'
'07':
_name: Luka Spalnica
sensor: '04:kkkkkk'
actuators:
- '04:kkkkkk'
'08':
_name: Miha Predsoba
sensor: '04:kkkkkk'
actuators:
- '04:kkkkkk'
'09':
_name: Miha WC
sensor: '04:kkkkkk'
actuators:
- '04:kkkkkk'
- status
Schema <--- missing yyyyyy controller (Ucilnica)
'01:xxxxxx':
zones:
'00':
sensor: '01:xxxxxx'
Config
Known list
- '01:xxxxxx':
class: controller
- '01:yyyyyy': <--- here it is listed, maybe not needed above?
class: controller
- '18:dddddd':
class: gateway_interface
- '13:zzzzzz':
class: electrical_relay
- '04:kkkkkk':
- '04:kkkkkk':
- '34:kkkkkk':
class: thermostat
- '04:kkkkkk':
- '04:kkkkkk':
- '04:kkkkkk':
- '34:kkkkkk':
class: thermostat
- '04:kkkkkk':
- '04:kkkkkk':
- '34:kkkkkk':
class: thermostat
- '04:kkkkkk':
- '04:kkkkkk':
- '04:kkkkkk':
- '04:kkkkkk':
- '04:kkkkkk':
- '04:kkkkkk':
- '34:kkkkkk':
class: thermostat
- '04:kkkkkk':
- '04:kkkkkk':
- '04:kkkkkk':
- '04:kkkkkk':
- '04:kkkkkk':
- '04:kkkkkk':
- '04:kkkkkk':
- '04:kkkkkk':
- '04:kkkkkk':
Block list
Other list
is evofw3
true
- So the system is working from the side of Evohome. There are no bugs in it, im 99,99% certain.
What I observe in Ramses:
4.1. yyyyyy Controller (Ucilnica) has missing appliance_control: in schema
4.2. zone 04 in yyyyyy has missing sensor: + actuators: + unavailable heat_demand (it has only 1x HR92 for both sensor+actuator)
4.3. zone 02 in yyyyyy has unavailable heat_demand entity (forget this one for now, because I removed HR92 and its battery, maybe thats why.)
4.4. zone 03 in yyyyyy has two actuators: and both are unique IDs (it should have only 1x HR92 for both sensor+actuator)
4.5. zone 00 in xxxxxx has missing actuator: + unavaiable heat_demand, when in reality this is the main room of the house and its HR92 is working flawlessly (Controller is sensor)
4.6. zone 09 in xxxxxx has missing sensor: + actuators: + unavailable heat_demand (it has only 1x HR92 for both sensor+actuator)
4.7. zone 08 in xxxxxx has two actuators: and both are unique IDs (it should have only 1x HR92 for both sensor+actuator)
This is logical: So I believe, whenever it is missing an actuator in schema, heat_demand is missing.
2 years ago, actuator in zone 09 in xxxxxx was double binded to 07 (something very weird). I fixed it then by unbinding both zones on both sides, removing zones, recreating zones and binding both HR92 again.
Maybe this procedure of unbinding HR92 and recreating zones would fix all missing stuff in schema?
- Error logs (right after boot):
2022-10-02 05:46:50.083 WARNING (MainThread) [ramses_rf.dispatcher] RP --- 01:yyyyyy 18:dddddd --:------ 000C 006 000F0037D388 < CorruptStateError(Inconsistent schema: 13:zzzzzz (BDR): None cant change parent (01:xxxxxx (evohome)_FC to 01:yyyyyy (evohome)_FC)(try restarting the client library))
^^ I believe this one is a bug: need to allow duplication of BDR91 between two controllers
2022-10-02 05:48:24.436 WARNING (MainThread) [ramses_rf.dispatcher] RP --- 01:xxxxxx 18:dddddd --:------ 000C 006 09080010BF62 < CorruptStateError(Inconsistent schema: ***04:kkkk94*** (TRV): 0.0 cant change parent (01:xxxxxx_08 (RAD)_08 to 01:xxxxxx_09 (RAD)_09)(try restarting the client library))
2022-10-02 05:48:24.844 WARNING (MainThread) [ramses_rf.dispatcher] RP --- 01:xxxxxx 18:dddddd --:------ 000C 006 09040010BF62 < CorruptStateError(Inconsistent schema: ***04:kkkk94*** (TRV): 0.0 cant change parent (01:xxxxxx_08 (RAD)_08 to 01:xxxxxx_09 (RAD)_09)(try restarting the client library))
^^ maybe 4.7. - 04:kkkk94 is the 2nd in actuators, which is not in sensor
2022-10-02 05:48:26.658 WARNING (MainThread) [ramses_rf.dispatcher] RP --- 01:yyyyyy 18:dddddd --:------ 000C 012 04080011BBD604080011BBCE < CorruptStateError(Inconsistent schema: ***04:kkkk22*** (TRV): None cant change parent (01:yyyyyy_03 (RAD)_03 to 01:yyyyyy_04 (RAD)_04)(try restarting the client library))
^^ maybe 4.4. - 04:kkkk22 is the 2nd in actuators, which it is in sensor
2022-10-02 05:48:27.089 WARNING (MainThread) [ramses_rf.dispatcher] RP --- 01:yyyyyy 18:dddddd --:------ 000C 006 04040011BBCE < CorruptStateError(Inconsistent schema: ***04:kkkk14*** (TRV): None cant change parent (01:yyyyyy_03 (RAD)_03 to 01:yyyyyy_04 (RAD)_04)(try restarting the client library))
^^ maybe 4.4. - 04:kkkk14 is the 1st in actuators, which is not in sensor
2022-10-02 05:50:17.962 WARNING (MainThread) [ramses_rf.entity_base] No response for task(0008|RP|13:zzzzzz): throttling to 1/24h
2022-10-02 05:50:23.209 WARNING (MainThread) [ramses_rf.entity_base] No response for task(1100|RP|13:zzzzzz): throttling to 1/24h
2022-10-02 05:50:36.117 WARNING (MainThread) [ramses_rf.entity_base] No response for task(3EF1|RP|13:zzzzzz): throttling to 1/24h
^^ Ignore this, BDR91 is off power atm, probably thats why.
- Error logs (few hours later):
2022-10-02 06:58:57.343 WARNING (MainThread) [ramses_rf.protocol.transport] *** sync cycle stats: 0.012, avg: 0.012, lower: 0.012, upper: 0.012, times: ['0.012']```
2022-10-02 09:18:52.039 WARNING (MainThread) [ramses_rf.protocol.message] RQ --- 18:dddddd 01:xxxxxx --:------ 2349 002 0040 < Corrupt payload: Payload doesn't match '^0[0-9A-F](00|[0-9A-F]{12})?$': 0040
2022-10-02 10:18:54.170 WARNING (MainThread) [ramses_rf.protocol.transport] *** sync cycle stats: 0.065, avg: 0.038, lower: 0.012, upper: 0.065, times: ['0.012', '0.065']
- Error logs (alot of hours later):
2022-10-02 16:54:03.186 WARNING (MainThread) [ramses_rf.protocol.message] RQ --- 18:dddddd 01:xxxxxx --:------ 2349 002 00B0 < Corrupt payload: Payload doesn't match '^0[0-9A-F](00|[0-9A-F]{12})?$': 00B0
2022-10-02 17:34:27.030 WARNING (MainThread) [ramses_rf.protocol.message] RQ --- 18:dddddd 01:xxxxxx --:------ 2349 002 4000 < Corrupt payload: Payload doesn't match '^0[0-9A-F](00|[0-9A-F]{12})?$': 4000
2022-10-02 17:34:27.042 WARNING (MainThread) [ramses_rf.protocol.message] RP --- 01:xxxxxx 18:dddddd --:------ 2349 007 407FFF02FFFFFF < Corrupt payload: Payload doesn't match '^0[0-9A-F]{5}0[0-4][0-9A-F]{6}([0-9A-F]{12})?$': 407FFF02FFFFFF
2022-10-02 18:48:04.220 WARNING (MainThread) [ramses_rf.protocol.transport] *** sync cycle stats: 0.088, avg: 0.055, lower: 0.012, upper: 0.088, times: ['0.012', '0.065', '0.088']
2022-10-02 20:09:42.833 WARNING (MainThread) [ramses_rf.protocol.message] RQ --- 18:dddddd 01:yyyyyy --:------ 2394 002 0200 < Corrupt packet: Unknown code: 2394
2022-10-02 23:34:42.354 WARNING (MainThread) [ramses_rf.protocol.transport] *** sync cycle stats: 0.045, avg: 0.052, lower: 0.012, upper: 0.088, times: ['0.012', '0.065', '0.088', '0.045']
2022-10-02 23:59:36.948 WARNING (MainThread) [ramses_rf.protocol.transport] *** sync cycle stats: 0.011, avg: 0.044, lower: 0.011, upper: 0.088, times: ['0.012', '0.065', '0.088', '0.045', '0.011']
2022-10-03 00:48:37.354 WARNING (MainThread) [ramses_rf.protocol.message] RQ --- 18:dddddd 01:yyyyyy --:------ 2E40 001 FF < Corrupt packet: Unknown code: 2E40
2022-10-03 01:53:32.352 WARNING (MainThread) [ramses_rf.protocol.transport] *** sync cycle stats: 0.087, avg: 0.051, lower: 0.011, upper: 0.088, times: ['0.012', '0.065', '0.088', '0.045', '0.011', '0.087']
EDIT:
While rereading everything, under 4.5ā¦
I have āJedilnica heat_demandā unavailable, but ā01:xxxxxx heat_demandā is available (controller is sensor). Is that the same?
While āUcilnica heat_demandā and ā01:yyyyyy heat_demandā are both available (controller is sensor)
Soā¦
sensor.04_kkkkkk_heat_demand (available)
sensor.01_yyyyyy_01_heat_demand (available)
sensor.01_yyyyyy_heat_demand (available)
sensor.04_kkkkkk_heat_demand (skip this, missing also in schema)
sensor.01_xxxxxx_00_heat_demand (unavailable)
sensor.01_xxxxxx_heat_demand (available)
I believe its unavailable because also actuator is missing?
