Are there any known issues with reset_system_mode? I’m getting an error when I use it, even from the developer tools. Version 22.1
Automation:
- id: '1607967971509'
alias: Reset schedule on Sunday
description: Resets the heating system to follow schedule at 13:30 each Sunday
- platform: time
at: '13:20'
condition:
- condition: time
weekday:
- sun
- condition: state
entity_id: climate.controller
attribute: system_mode
state: Auto
- service: ramses_cc.reset_system_mode
mode: single
Error Log:
2022-11-14 15:52:58.790 ERROR (MainThread) [homeassistant.components.automation.reset_schedule_on_sunday] Reset schedule on Sunday: Error executing script. Unexpected error for call_service at pos 1: '06'
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 451, in _async_step
await getattr(self, handler)()
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 684, in _async_call_service_step
await service_task
File "/usr/src/homeassistant/homeassistant/core.py", line 1744, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1781, in _execute_service
await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 770, in handle_service
await service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 678, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 943, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 709, in _handle_entity_call
result = hass.async_run_job(partial(getattr(entity, func), **data)) # type: ignore[arg-type]
File "/usr/src/homeassistant/homeassistant/core.py", line 621, in async_run_job
return self.async_run_hass_job(HassJob(target), *args)
File "/usr/src/homeassistant/homeassistant/core.py", line 573, in async_run_hass_job
hassjob.target(*args)
File "/config/custom_components/ramses_cc/climate_heat.py", line 215, in svc_reset_system_mode
self._call_client_api(self._device.reset_mode)
File "/config/custom_components/ramses_cc/__init__.py", line 216, in _call_client_api
func(*args, **kwargs)
File "/usr/local/lib/python3.10/site-packages/ramses_rf/system/heat.py", line 944, in reset_mode
return self.set_mode(SYS_MODE_MAP.AUTO_WITH_RESET)
File "/usr/local/lib/python3.10/site-packages/ramses_rf/system/heat.py", line 935, in set_mode
Command.set_system_mode(self.id, system_mode, until=until)
File "/usr/local/lib/python3.10/site-packages/ramses_rf/protocol/helpers.py", line 27, in wrapper
return fnc(*args, **kwargs)
File "/usr/local/lib/python3.10/site-packages/ramses_rf/protocol/command.py", line 186, in wrapper
return _wrapper(fcn, cls, dst_id, *args, **kwargs)
File "/usr/local/lib/python3.10/site-packages/ramses_rf/protocol/command.py", line 163, in _wrapper
return fcn(cls, *args, **kwargs)
File "/usr/local/lib/python3.10/site-packages/ramses_rf/protocol/command.py", line 900, in set_system_mode
system_mode = SYS_MODE_MAP._hex(
File "/usr/local/lib/python3.10/site-packages/ramses_rf/protocol/const.py", line 172, in _hex
raise KeyError(key)
KeyError: '06'
2022-11-14 15:52:58.809 ERROR (MainThread) [homeassistant.components.automation.reset_schedule_on_sunday] While executing automation automation.reset_schedule_on_sunday
File "/usr/src/homeassistant/homeassistant/components/automation/__init__.py", line 551, in async_trigger
await self.action_script.async_run(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1524, in async_run
await asyncio.shield(run.async_run())
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 409, in async_run
await self._async_step(log_exceptions=False)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 453, in _async_step
self._handle_exception(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 476, in _handle_exception
raise exception
await service_task
task.result()
await coro
raise KeyError(key)
KeyError: '06'
