I “believed” I had installed the Evofw3 correctly when I originally did it. But following your suggestion (I am not familiar with using Ardinho) followed the same process and get an error “Include config.h instead of this file” Heres a screenshot. No idea if this where my issue is though.
You need to import the whole project and files in one folder, otherwise, Arduino can not find the necessary files.
Hi, Thank you a lot for your reply now I know what I can and cannot do. Ramses_cc manual led me to confuse.
EDIT: You are a star: finally made it work by doing, checking and comparing configs and with your forum colleague’s response it made it happen
Hi, big thank you for your reply. Now checking.
EDIT: You are a star: finally made it working doing this way rather thank sposed to do way
Having spent far too many hours on this I’m getting nowhere - have re flashed the Nano cul on another Win PC (fresh install) Changed to old bootloader (which seemed to be the issue of not compiling) and then was able to verify/compile then did upload to device with no errors.
Plug it back in to HA machine, restart but still nothing. I’m running a Nuc with a Proxmox VM - In Proxmox when plugged in I get this:
In HA System I get this:
So have my config as follows:
ramses_cc:
serial_port: /dev/serial/by-id/usb-SHK_NANO_CUL_868-if00-port0
packet_log:
file_name: packet.log
rotate_backups: 28
ramses_rf:
enforce_known_list: true
Am pulling hair out now and getting to the point of giving up. Any further advice appreciated.
I would like to announce ramses_cc alpha release 0.30.0.
Please install, test & report bugs here (there will be many bugs).
Please backup your HA before installing this version.
You should be able to roll back to your previous version of ramses_cc without resorting to restoring a backup, but you never know.
It is a pre-release, and you will not see it in HACS, unless you enable beta versions.
Please post your config in this format:
ramses_cc:
packet_log:
rotate_backups: 28
ramses_rf:
enforce_known_list: false
You use three back-quotes (`), followed by ‘yaml’: (```yaml), then paste your lines after that, then three more back quotes.
ALso, please set enforce_known_list: false
for now.
Also please look at:
cat home-assistant.log | grep ramses
And finally:
the baud rate you used to flash evofw3 on a nano (recommended 57600) should be the same used in HA.
Please let us know how to improve the docs.
In general, the manual is fantastic, explaining all the bits and pieces which I found useful. Truly, I do not want to be disrespectful because a lot of work is done to cover this manual. The only thing is some parts are not related to HVAC and vice versa.
I would suggest something like a “quick start guide.” and a sample full config for the quick start guide, for example, NAUAIRE PIV and common issues to date. Like the above full sample config and tip that In need to use remotely from service sorted a lot with the newest ramses cc version 22.40
No offense taken.
It woudl be reasonable for someone to add a section:
- How to fake a HVAC switch
FYI (all): because 0.30.x is so different to all previous versions, I will not be fixing any bugs in previous versions.
Many thanks.
The correctly formatted version is as follows:
ramses_cc:
packet_log:
rotate_backups: 28
ramses_rf:
Have set enforce_known_list to false
I have also added:
logger:
logs:
custom_components.ramses_cc: info # show ramses_cc/ramses_rf state
ramses_rf.dispatcher: info # show packet payloads
I’m using HA OS so not sure I can or even know how to use:
I flashed at 115200 and my revised config is as follows:
ramses_cc:
baudrate: 115200
packet_log:
rotate_backups: 28
ramses_rf:
logger:
logs:
Appreciate your help.
These are the mistakes I can see:
ramses_cc:
serial_port:
port_name: /dev/serial/by-id/usb-SHK_NANO_CUL_868-if00-port0
baudrate: 115200
packet_log:
rotate_backups: 28
ramses_rf:
enforce_known_list: false # set true only if you have a good known_list
logger:
logs:
NOTE: I have edited the above several times.
So to be clear my port name is wrong? Where do I find correct is it maybe /dev/ttyUSB0 which is device path?
I have the following identified in System Hardware for the device:
ttyUSB0
Subsystem:
tty
Device path:
/dev/ttyUSB0
ID:
Attributes:
DEVLINKS: >-
/dev/serial/by-path/pci-0000:01:1b.0-usb-0:4.1:1.0-port0
DEVNAME: /dev/ttyUSB0
DEVPATH: >-
/devices/pci0000:00/0000:00:1e.0/0000:01:1b.0/usb2/2-4/2-4.1/2-4.1:1.0/ttyUSB0/tty/ttyUSB0
Also my file name: packet.log is incorrect? I believe that was from the Wiki.
I’ll have to read up on how the logger works.
Where did you get your USB device from?
Has it ever received (picked up) packets.
Do you have access to a Linux CLI?
The logger is a separate piece of software, separate from ramses_cc.
I have asked you to cat home-assistant.log | grep ramses
, and you have not provided that information.
Hi all
Installed 00.30 to test.
Config changed as logs warned about options that not supported
Commented Out:
- enforce_known_list: true
- disable_sending: false
Tried to run a command via system remote command ( previously worked with 0.22). Now, no response.
Logs are
2023-11-11 17:06:19.958 INFO (MainThread) [custom_components.ramses_cc.sensor] Found a Sensor for 30:071287: supply_fan_speed
2023-11-11 17:06:19.959 INFO (MainThread) [custom_components.ramses_cc.sensor] Found a Sensor for 30:071287: supply_flow
2023-11-11 17:06:19.965 INFO (MainThread) [custom_components.ramses_cc.climate_hvac] Found a HVAC system: 30:071287 (FAN)
2023-11-11 17:06:19.971 INFO (MainThread) [custom_components.ramses_cc.remote] Found a Remote: 32:205847 (REM)
2023-11-11 17:06:26.862 INFO (MainThread) [ramses_rf.dispatcher] RQ --- 18:004628 30:071287 --:------ 22F2 001 00 < Invalid code for 30:071287 (FAN) to Rx/Tx: 22F2
2023-11-11 17:06:26.862 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 30:071287 | RQ | unknown_22f2 | || {}
2023-11-11 17:06:27.092 INFO (MainThread) [ramses_rf.dispatcher] RQ --- 18:004628 30:071287 --:------ 22F2 001 00 < Invalid code for 30:071287 (FAN) to Rx/Tx: 22F2
2023-11-11 17:06:27.092 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 30:071287 | RQ | unknown_22f2 | || {}
2023-11-11 17:06:27.520 INFO (MainThread) [ramses_rf.dispatcher] RQ --- 18:004628 30:071287 --:------ 22F2 001 00 < Invalid code for 30:071287 (FAN) to Rx/Tx: 22F2
2023-11-11 17:06:27.520 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 30:071287 | RQ | unknown_22f2 | || {}
2023-11-11 17:06:28.149 INFO (MainThread) [ramses_rf.dispatcher] RQ --- 18:004628 30:071287 --:------ 22F2 001 00 < Invalid code for 30:071287 (FAN) to Rx/Tx: 22F2
2023-11-11 17:06:28.149 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 30:071287 | RQ | unknown_22f2 | || {}
2023-11-11 17:06:28.950 ERROR (MainThread) [ramses_rf.gateway] Failed to send 22F2|RQ|30:071287: 22F2|RQ|30:071287: Other error
Similar lines repeated along
2023-11-11 17:06:54.419 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 30:071287 | RQ | unknown_313e | || {}
2023-11-11 17:06:55.220 ERROR (MainThread) [ramses_rf.gateway] Failed to send 313E|RQ|30:071287: 313E|RQ|30:071287: Other error
2023-11-11 17:06:55.245 INFO (MainThread) [ramses_rf.dispatcher] RQ --- 18:004628 30:071287 --:------ 3222 001 00 < Invalid code for 30:071287 (FAN) to Rx/Tx: 3222
2023-11-11 17:06:55.245 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 30:071287 | RQ | unknown_3222 | || {}
2023-11-11 17:06:55.472 INFO (MainThread) [ramses_rf.dispatcher] RQ --- 18:004628 30:071287 --:------ 3222 001 00 < Invalid code for 30:071287 (FAN) to Rx/Tx: 3222
2023-11-11 17:06:55.472 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 30:071287 | RQ | unknown_3222 | || {}
2023-11-11 17:06:55.809 INFO (MainThread) [ramses_rf.dispatcher] || 30:071287 | | I | system_sync | || {'remaining_seconds': 123.5, '_next_sync': '17:08:59'}
2023-11-11 17:06:55.904 INFO (MainThread) [ramses_rf.dispatcher] RQ --- 18:004628 30:071287 --:------ 3222 001 00 < Invalid code for 30:071287 (FAN) to Rx/Tx: 3222
2023-11-11 17:06:55.904 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 30:071287 | RQ | unknown_3222 | || {}
2023-11-11 17:06:56.533 INFO (MainThread) [ramses_rf.dispatcher] RQ --- 18:004628 30:071287 --:------ 3222 001 00 < Invalid code for 30:071287 (FAN) to Rx/Tx: 3222
2023-11-11 17:06:56.533 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 30:071287 | RQ | unknown_3222 | || {}
2023-11-11 17:06:57.335 ERROR (MainThread) [ramses_rf.gateway] Failed to send 3222|RQ|30:071287: 3222|RQ|30:071287: Other error
2023-11-11 17:07:00.362 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 30:071287 | RQ | filter_change | || {}
2023-11-11 17:07:00.587 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 30:071287 | RQ | filter_change | || {}
2023-11-11 17:07:01.015 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 30:071287 | RQ | filter_change | || {}
2023-11-11 17:07:01.646 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 30:071287 | RQ | filter_change | || {}
2023-11-11 17:07:02.447 ERROR (MainThread) [ramses_rf.gateway] Failed to send 10D0|RQ|30:071287: 10D0|RQ|30:071287: Other error
2023-11-11 17:07:02.474 INFO (MainThread) [ramses_rf.dispatcher] RQ --- 18:004628 30:071287 --:------ 22F1 001 00 < Invalid code for 30:071287 (FAN) to Rx/Tx: 22F1
2023-11-11 17:07:02.474 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 30:071287 | RQ | fan_mode | || {}
2023-11-11 17:07:02.701 INFO (MainThread) [ramses_rf.dispatcher] RQ --- 18:004628 30:071287 --:------ 22F1 001 00 < Invalid code for 30:071287 (FAN) to Rx/Tx: 22F1
2023-11-11 17:07:02.701 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 30:071287 | RQ | fan_mode | || {}
2023-11-11 17:07:03.127 INFO (MainThread) [ramses_rf.dispatcher] RQ --- 18:004628 30:071287 --:------ 22F1 001 00 < Invalid code for 30:071287 (FAN) to Rx/Tx: 22F1
2023-11-11 17:07:03.127 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 30:071287 | RQ | fan_mode | || {}
2023-11-11 17:07:03.760 INFO (MainThread) [ramses_rf.dispatcher] RQ --- 18:004628 30:071287 --:------ 22F1 001 00 < Invalid code for 30:071287 (FAN) to Rx/Tx: 22F1
2023-11-11 17:07:03.760 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 30:071287 | RQ | fan_mode | || {}
2023-11-11 17:07:09.049 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 30:071287 | RQ | unknown_22e5 | || {}
2023-11-11 17:07:09.324 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: media_player.pioneer
2023-11-11 17:07:09.479 INFO (MainThread) [ramses_rf.dispatcher] RQ --- 18:004628 30:071287 --:------ 22E5 001 00 < Invalid code for 30:071287 (FAN) to Rx/Tx: 22E5
2023-11-11 17:07:09.480 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 30:071287 | RQ | unknown_22e5 | || {}
2023-11-11 17:07:10.072 ERROR (MainThread) [homeassistant.components.media_player] Setup of platform pioneer is taking longer than 60 seconds. Startup will proceed without waiting any longer.
2023-11-11 17:07:10.109 INFO (MainThread) [ramses_rf.dispatcher] RQ --- 18:004628 30:071287 --:------ 22E5 001 00 < Invalid code for 30:071287 (FAN) to Rx/Tx: 22E5
2023-11-11 17:07:10.109 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 30:071287 | RQ | unknown_22e5 | || {}
2023-11-11 17:07:10.243 INFO (MainThread) [custom_components.ramses_cc.binary_sensor] Found a Binary Sensor for 18:004628: status
2023-11-11 17:07:10.945 ERROR (MainThread) [ramses_rf.gateway] Failed to send 22E5|RQ|30:071287: 22E5|RQ|30:071287: Other error
2023-11-11 17:07:10.976 INFO (MainThread) [ramses_rf.dispatcher] RQ --- 18:004628 30:071287 --:------ 22E9 001 00 < Invalid code for 30:071287 (FAN) to Rx/Tx: 22E9
2023-11-11 17:07:10.976 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 30:071287 | RQ | unknown_22e9 | || {}
2023-11-11 17:07:11.205 INFO (MainThread) [ramses_rf.dispatcher] RQ --- 18:004628 30:071287 --:------ 22E9 001 00 < Invalid code for 30:071287 (FAN) to Rx/Tx: 22E9
2023-11-11 17:07:11.205 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 30:071287 | RQ | unknown_22e9 | || {}
2023-11-11 17:07:11.632 INFO (MainThread) [ramses_rf.dispatcher] RQ --- 18:004628 30:071287 --:------ 22E9 001 00 < Invalid code for 30:071287 (FAN) to Rx/Tx: 22E9
2023-11-11 17:07:11.632 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 30:071287 | RQ | unknown_22e9 | || {}
2023-11-11 17:07:12.261 INFO (MainThread) [ramses_rf.dispatcher] RQ --- 18:004628 30:071287 --:------ 22E9 001 00 < Invalid code for 30:071287 (FAN) to Rx/Tx: 22E9
2023-11-11 17:07:12.261 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 30:071287 | RQ | unknown_22e9 | || {}
2023-11-11 17:07:13.061 ERROR (MainThread) [ramses_rf.gateway] Failed to send 22E9|RQ|30:071287: 22E9|RQ|30:071287: Other error
2023-11-11 17:07:13.087 INFO (MainThread) [ramses_rf.dispatcher] RQ --- 18:004628 30:071287 --:------ 22F2 001 00 < Invalid code for 30:071287 (FAN) to Rx/Tx: 22F2
2023-11-11 17:07:13.087 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 30:071287 | RQ | unknown_22f2 | || {}
2023-11-11 17:07:13.313 INFO (MainThread) [ramses_rf.dispatcher] RQ --- 18:004628 30:071287 --:------ 22F2 001 00 < Invalid code for 30:071287 (FAN) to Rx/Tx: 22F2
2023-11-11 17:07:13.313 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 30:071287 | RQ | unknown_22f2 | || {}
2023-11-11 17:07:13.483 WARNING (MainThread) [py.warnings] /config/custom_components/ramses_cc/remote.py:202: RuntimeWarning: coroutine 'RamsesBroker.async_update' was never awaited
self._broker.async_update()
2023-11-11 17:07:13.741 INFO (MainThread) [ramses_rf.dispatcher] RQ --- 18:004628 30:071287 --:------ 22F2 001 00 < Invalid code for 30:071287 (FAN) to Rx/Tx: 22F2
2023-11-11 17:07:13.741 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 30:071287 | RQ | unknown_22f2 | || {}
2023-11-11 17:07:14.370 INFO (MainThread) [ramses_rf.dispatcher] RQ --- 18:004628 30:071287 --:------ 22F2 001 00 < Invalid code for 30:071287 (FAN) to Rx/Tx: 22F2
2023-11-11 17:07:14.371 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 30:071287 | RQ | unknown_22f2 | || {}
2023-11-11 17:07:15.172 ERROR (MainThread) [ramses_rf.gateway] Failed to send 22F2|RQ|30:071287: 22F2|RQ|30:071287: Other error
2023-11-11 17:07:15.210 INFO (MainThread) [custom_components.ramses_cc.coordinator] Saving the client state cache (packets, schema)...
2023-11-11 17:07:15.228 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 63:262142 | I | puzzle_packet | || {'datetime': '2023-11-11T17:07:13.483', 'impersonating': '22F1| I|32:205847', 'parser': 'v0.30.0'}
2023-11-11 17:07:15.417 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 63:262142 | I | puzzle_packet | || {'datetime': '2023-11-11T17:07:13.483', 'impersonating': '22F1| I|32:205847', 'parser': 'v0.30.0'}
2023-11-11 17:07:15.620 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 63:262142 | I | puzzle_packet | || {'datetime': '2023-11-11T17:07:13.483', 'impersonating': '22F1| I|32:205847', 'parser': 'v0.30.0'}
2023-11-11 17:07:15.761 ERROR (MainThread) [ramses_rf.gateway] Failed to send 22F1| I|32:205847: 7FFF| I|18:000730: Other error
2023-11-11 17:07:15.813 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 63:262142 | I | puzzle_packet | || {'datetime': '2023-11-11T17:07:13.483', 'impersonating': '22F1| I|32:205847', 'parser': 'v0.30.0'}
2023-11-11 17:07:15.995 INFO (MainThread) [ramses_rf.dispatcher] RQ --- 18:004628 30:071287 --:------ 22F4 001 00 < Invalid code for 30:071287 (FAN) to Rx/Tx: 22F4
2023-11-11 17:07:15.995 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 30:071287 | RQ | unknown_22f4 | || {}
2023-11-11 17:07:16.229 INFO (MainThread) [ramses_rf.dispatcher] RQ --- 18:004628 30:071287 --:------ 22F4 001 00 < Invalid code for 30:071287 (FAN) to Rx/Tx: 22F4
2023-11-11 17:07:16.229 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 30:071287 | RQ | unknown_22f4 | || {}
2023-11-11 17:07:16.669 INFO (MainThread) [ramses_rf.dispatcher] RQ --- 18:004628 30:071287 --:------ 22F4 001 00 < Invalid code for 30:071287 (FAN) to Rx/Tx: 22F4
2023-11-11 17:07:22.998 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 30:071287 | RQ | unknown_3222 | || {}
2023-11-11 17:07:23.626 INFO (MainThread) [ramses_rf.dispatcher] RQ --- 18:004628 30:071287 --:------ 3222 001 00 < Invalid code for 30:071287 (FAN) to Rx/Tx: 3222
2023-11-11 17:07:23.626 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 30:071287 | RQ | unknown_3222 | || {}
2023-11-11 17:07:24.428 ERROR (MainThread) [ramses_rf.gateway] Failed to send 3222|RQ|30:071287: 3222|RQ|30:071287: Other error
2023-11-11 17:07:27.458 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 30:071287 | RQ | filter_change | || {}
2023-11-11 17:07:27.687 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 30:071287 | RQ | filter_change | || {}
2023-11-11 17:07:28.113 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 30:071287 | RQ | filter_change | || {}
2023-11-11 17:07:28.741 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 30:071287 | RQ | filter_change | || {}
2023-11-11 17:07:29.546 ERROR (MainThread) [ramses_rf.gateway] Failed to send 10D0|RQ|30:071287: 10D0|RQ|30:071287: Other error
2023-11-11 17:07:29.573 INFO (MainThread) [ramses_rf.dispatcher] RQ --- 18:004628 30:071287 --:------ 22F1 001 00 < Invalid code for 30:071287 (FAN) to Rx/Tx: 22F1
2023-11-11 17:07:29.573 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 30:071287 | RQ | fan_mode | || {}
2023-11-11 17:07:29.802 INFO (MainThread) [ramses_rf.dispatcher] RQ --- 18:004628 30:071287 --:------ 22F1 001 00 < Invalid code for 30:071287 (FAN) to Rx/Tx: 22F1
2023-11-11 17:07:29.802 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 30:071287 | RQ | fan_mode | || {}
2023-11-11 17:07:30.230 INFO (MainThread) [ramses_rf.dispatcher] RQ --- 18:004628 30:071287 --:------ 22F1 001 00 < Invalid code for 30:071287 (FAN) to Rx/Tx: 22F1
2023-11-11 17:07:30.230 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 30:071287 | RQ | fan_mode | || {}
2023-11-11 17:07:42.915 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 30:071287 | RQ | unknown_3222 | || {}
2023-11-11 17:07:43.548 INFO (MainThread) [ramses_rf.dispatcher] RQ --- 18:004628 30:071287 --:------ 3222 001 00 < Invalid code for 30:071287 (FAN) to Rx/Tx: 3222
2023-11-11 17:07:43.549 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 30:071287 | RQ | unknown_3222 | || {}
2023-11-11 17:07:44.350 ERROR (MainThread) [ramses_rf.gateway] Failed to send 3222|RQ|30:071287: 3222|RQ|30:071287: Other error
2023-11-11 17:07:47.378 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 30:071287 | RQ | filter_change | || {}
2023-11-11 17:07:47.608 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 30:071287 | RQ | filter_change | || {}
2023-11-11 17:07:48.044 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 30:071287 | RQ | filter_change | || {}
2023-11-11 17:07:48.673 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 30:071287 | RQ | filter_change | || {}
2023-11-11 17:07:49.474 ERROR (MainThread) [ramses_rf.gateway] Failed to send 10D0|RQ|30:071287: 10D0|RQ|30:071287: Other error
2023-11-11 17:07:49.502 INFO (MainThread) [ramses_rf.dispatcher] RQ --- 18:004628 30:071287 --:------ 22F2 001 00 < Invalid code for 30:071287 (FAN) to Rx/Tx: 22F2
2023-11-11 17:07:49.503 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 30:071287 | RQ | unknown_22f2 | || {}
2023-11-11 17:07:49.730 INFO (MainThread) [ramses_rf.dispatcher] RQ --- 18:004628 30:071287 --:------ 22F2 001 00 < Invalid code for 30:071287 (FAN) to Rx/Tx: 22F2
2023-11-11 17:07:49.730 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 30:071287 | RQ | unknown_22f2 | || {}
2023-11-11 17:07:50.158 INFO (MainThread) [ramses_rf.dispatcher] RQ --- 18:004628 30:071287 --:------ 22F2 001 00 < Invalid code for 30:071287 (FAN) to Rx/Tx: 22F2
2023-11-11 17:07:50.158 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 30:071287 | RQ | unknown_22f2 | || {}
2023-11-11 17:07:50.784 INFO (MainThread) [ramses_rf.dispatcher] RQ --- 18:004628 30:071287 --:------ 22F2 001 00 < Invalid code for 30:071287 (FAN) to Rx/Tx: 22F2
2023-11-11 17:07:50.784 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 30:071287 | RQ | unknown_22f2 | || {}
2023-11-11 17:07:51.585 ERROR (MainThread) [ramses_rf.gateway] Failed to send 22F2|RQ|30:071287: 22F2|RQ|30:071287: Other error
2023-11-11 17:07:51.613 INFO (MainThread) [ramses_rf.dispatcher] RQ --- 18:004628 30:071287 --:------ 22F4 001 00 < Invalid code for 30:071287 (FAN) to Rx/Tx: 22F4
2023-11-11 17:07:51.613 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 30:071287 | RQ | unknown_22f4 | || {}
2023-11-11 17:07:51.843 INFO (MainThread) [ramses_rf.dispatcher] RQ --- 18:004628 30:071287 --:------ 22F4 001 00 < Invalid code for 30:071287 (FAN) to Rx/Tx: 22F4
2023-11-11 17:07:51.843 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 30:071287 | RQ | unknown_22f4 | || {}
2023-11-11 17:07:52.273 INFO (MainThread) [ramses_rf.dispatcher] RQ --- 18:004628 30:071287 --:------ 22F4 001 00 < Invalid code for 30:071287 (FAN) to Rx/Tx: 22F4
2023-11-11 17:07:52.273 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 30:071287 | RQ | unknown_22f4 | || {}
2023-11-11 17:07:52.905 INFO (MainThread) [ramses_rf.dispatcher] RQ --- 18:004628 30:071287 --:------ 22F4 001 00 < Invalid code for 30:071287 (FAN) to Rx/Tx: 22F4
2023-11-11 17:07:52.905 INFO (MainThread) [ramses_rf.dispatcher] || 18:004628 | 30:071287 | RQ | unknown_22f4 | || {}
Hi Guys,
I’m new in this topic and I used the search function, but I couldn’t find what bit_3_7 and bit_6_6 means, coming from a R8810A OpenTherm Bridge. These are binary sensors in Home Assistant.
The OTB controls a Viessmann Vitodens 100-W furnace which does the heating and if someone opens the tap stops the heating and starts creating the DHW. I found the boiler output temperature for the DWH. But is there a way to monitor the waters temperature if the furnace is in heating mode? It would be nice to monitor the temperature of the water going into the heating pipes.
My device came from smart-home-komponente back in Oct 2020. It was the one recommended but I just got around to installing, It’s the following:
G7-N66B-BXR0 nanoCUL USB Stick FTDI CC1101 868MHz FW
1.67 Knick-Antenne FHEM CUL 868+ Adapter
It has not ever picked anything up that ive identified in HA.
I do NOT have access to Linux CLI.
As mentioned I dont believe I can run the CAT command as I’m running HA OS.
Yes, there is - but your boiler may not expose this information to the OTB. Look for a sensor called something similar to:
10:123456 boiler_output_temp
10:123456 boiler_return_temp
10:123456 dhw_temp
You can do this - install one of the two Terminal add-ons (or the log viewer add-on, or the Studio-code server add-on).
From smart-home-komponente I have nanocul, and initially had the wrong firmware. I refreshed with Arduino GUI, and it’s all good.
Did you manage to reflash? My used baud rate were 115200
Do you have any packets in ur ramsespacket log ?
