Hi David!
Can you please explain me what is the difference between the boiler output temperature value in Home Assistant and the boiler water temperature values in the packet log? And how can I forward the value of the boiler water temperature from the packets to Home Assistant?
Below I copied a short part of my packet log. In every 5 minutes the controller queries the OTB about many attributes, included the boiler water temperature. The OTB responds to this query and returns the temperature, but I can’t find this value in Home Assistant. Where should I look for it?
00:01:35.797 || 10:102998 | 01:155672 | RP | opentherm_msg | 19 || {'msg_id': 25, 'msg_type': 'Read-Ack', 'msg_name': 'BoilerWaterTemperature
', 'value': 41.5, 'description': 'Boiler water temperature'}
00:06:39.505 || 01:155672 | 10:102998 | RQ | opentherm_msg | 19 || {'msg_id': 25, 'msg_type': 'Read-Data', 'msg_name': 'BoilerWaterTemperatur
e', 'description': 'Boiler water temperature'}
00:06:39.887 || 10:102998 | 01:155672 | RP | opentherm_msg | 19 || {'msg_id': 25, 'msg_type': 'Read-Ack', 'msg_name': 'BoilerWaterTemperature
', 'value': 41.09, 'description': 'Boiler water temperature'}
00:11:45.752 || 01:155672 | 10:102998 | RQ | opentherm_msg | 19 || {'msg_id': 25, 'msg_type': 'Read-Data', 'msg_name': 'BoilerWaterTemperatur
00:11:46.139 || 10:102998 | 01:155672 | RP | opentherm_msg | 19 || {'msg_id': 25, 'msg_type': 'Read-Ack', 'msg_name': 'BoilerWaterTemperature
', 'value': 40.69, 'description': 'Boiler water temperature'}
00:16:51.999 || 01:155672 | 10:102998 | RQ | opentherm_msg | 19 || {'msg_id': 25, 'msg_type': 'Read-Data', 'msg_name': 'BoilerWaterTemperatur
00:16:52.322 || 10:102998 | 01:155672 | RP | opentherm_msg | 19 || {'msg_id': 25, 'msg_type': 'Read-Ack', 'msg_name': 'BoilerWaterTemperature
', 'value': 40.3, 'description': 'Boiler water temperature'}
00:21:58.247 || 01:155672 | 10:102998 | RQ | opentherm_msg | 19 || {'msg_id': 25, 'msg_type': 'Read-Data', 'msg_name': 'BoilerWaterTemperatur
00:21:58.618 || 10:102998 | 01:155672 | RP | opentherm_msg | 19 || {'msg_id': 25, 'msg_type': 'Read-Ack', 'msg_name': 'BoilerWaterTemperature
', 'value': 46.0, 'description': 'Boiler water temperature'}
00:27:02.893 || 01:155672 | 10:102998 | RQ | opentherm_msg | 19 || {'msg_id': 25, 'msg_type': 'Read-Data', 'msg_name': 'BoilerWaterTemperatur
00:27:03.409 || 10:102998 | 01:155672 | RP | opentherm_msg | 19 || {'msg_id': 25, 'msg_type': 'Read-Ack', 'msg_name': 'BoilerWaterTemperature
', 'value': 44.39, 'description': 'Boiler water temperature'}
00:32:07.140 || 01:155672 | 10:102998 | RQ | opentherm_msg | 19 || {'msg_id': 25, 'msg_type': 'Read-Data', 'msg_name': 'BoilerWaterTemperatur
00:32:07.585 || 10:102998 | 01:155672 | RP | opentherm_msg | 19 || {'msg_id': 25, 'msg_type': 'Read-Ack', 'msg_name': 'BoilerWaterTemperature
', 'value': 43.59, 'description': 'Boiler water temperature'}
00:37:11.587 || 01:155672 | 10:102998 | RQ | opentherm_msg | 19 || {'msg_id': 25, 'msg_type': 'Read-Data', 'msg_name': 'BoilerWaterTemperatur
00:37:11.998 || 10:102998 | 01:155672 | RP | opentherm_msg | 19 || {'msg_id': 25, 'msg_type': 'Read-Ack', 'msg_name': 'BoilerWaterTemperature
', 'value': 42.89, 'description': 'Boiler water temperature'}
00:42:15.634 || 01:155672 | 10:102998 | RQ | opentherm_msg | 19 || {'msg_id': 25, 'msg_type': 'Read-Data', 'msg_name': 'BoilerWaterTemperatur
00:42:16.076 || 10:102998 | 01:155672 | RP | opentherm_msg | 19 || {'msg_id': 25, 'msg_type': 'Read-Ack', 'msg_name': 'BoilerWaterTemperature
', 'value': 42.39, 'description': 'Boiler water temperature'}
