Hi all,
i started with Evofw3 on a Nanocul last night, but eighter iām missing something orā¦
i need some help understanding what iām doing wrong
iāve got the log file in place and receive data .
My setup is :
A bdr as heater relay
evohome controller in livingroom the controller is the sensor , and has a bdr91 for a seperate 2way valve.
8 x hr92
2 zones with 2 hr92
and 4 with a single hr92.
hereās a snippet of the packet log
2024-01-27T15:15:56.335539 # ramses_rf 0.21.40
2024-01-27T15:15:56.439137 ... RQ --- 01:131289 13:239590 --:------ 3EF0 001 00 # 3EF0|RQ|01:131289
2024-01-27T15:15:57.312845 ... I --- 04:158578 --:------ 04:158578 30C9 003 0006BE # 30C9| I|04:158578
2024-01-27T15:15:57.318918 ... RP --- 01:131289 04:205452 --:------ 0100 005 006E6CFFFF # 0100|RP|01:131289
2024-01-27T15:15:57.333323 ... I --- 04:205410 --:------ 04:205410 30C9 003 00062C # 30C9| I|04:205410
2024-01-27T15:15:57.344401 ... I --- 04:158204 --:------ 04:158204 30C9 003 00067A # 30C9| I|04:158204
2024-01-27T15:15:57.429818 ... I --- 04:250553 --:------ 01:131289 12B0 003 010000 # 12B0| I|04:250553|01 (01)
2024-01-27T15:15:57.434248 ... I --- 04:205410 --:------ 01:131289 2309 003 020640 # 2309| I|04:205410|02 (02)
2024-01-27T15:15:57.453497 ... I --- 01:131289 --:------ 01:131289 000A 048 001001F40DAC011001F40898021001F40DAC031001F40DAC041001F40DAC051001F40DAC061001F40DAC071001F40DAC # 000A| I|01:131289 (True)
2024-01-27T15:15:57.456031 ... I --- 04:205512 --:------ 01:131289 3150 002 0400 # 3150| I|04:205512|04 (04)
2024-01-27T15:15:57.658098 ... I --- 04:250553 --:------ 01:131289 2309 003 010640 # 2309| I|04:250553|01 (01)
2024-01-27T15:15:57.769006 ... I --- 01:131289 --:------ 01:131289 0008 002 FC00 # 0008| I|01:131289|FC (FC)
2024-01-27T15:15:57.781068 ... I --- 04:156304 --:------ 01:131289 3150 002 0600 # 3150| I|04:156304|06 (06)
2024-01-27T15:15:57.793028 ... I --- 04:158204 --:------ 01:131289 12B0 003 040000 # 12B0| I|04:158204|04 (04)
2024-01-27T15:15:57.855062 ... I --- 01:131289 --:------ 01:131289 0008 002 0000 # 0008| I|01:131289|00 (00)
2024-01-27T15:15:57.920083 ... I --- 04:234364 --:------ 04:234364 30C9 003 000608 # 30C9| I|04:234364
2024-01-27T15:15:58.563560 ... I --- 04:205512 --:------ 01:131289 12B0 003 040000 # 12B0| I|04:205512|04 (04)
2024-01-27T15:15:58.628550 ... I --- 04:158578 --:------ 01:131289 3150 002 0500 # 3150| I|04:158578|05 (05)
2024-01-27T15:15:58.653574 ... I --- 04:205512 --:------ 01:131289 2309 003 0404B0 # 2309| I|04:205512|04 (04)
2024-01-27T15:15:58.667359 ... I --- 13:239590 --:------ 13:239590 3B00 002 00C8 # 3B00| I|13:239590
2024-01-27T15:15:58.772356 ... I --- 13:239590 --:------ 13:239590 3EF0 003 0000FF # 3EF0| I|13:239590
2024-01-27T15:15:58.786153 ... I --- 01:131289 --:------ 01:131289 3B00 002 FCC8 # 3B00| I|01:131289|FC (FC)
2024-01-27T15:15:58.792393 ... I --- 13:194278 --:------ 13:194278 3EF0 003 0000FF # 3EF0| I|13:194278
2024-01-27T15:15:58.821951 ... I --- 04:234364 --:------ 01:131289 3150 002 0300 # 3150| I|04:234364|03 (03)
2024-01-27T15:15:58.888940 ... I --- 04:234364 --:------ 01:131289 12B0 003 030000 # 12B0| I|04:234364|03 (03)
2024-01-27T15:15:58.895166 ... I --- 04:205512 --:------ 04:205512 30C9 003 00064E # 30C9| I|04:205512
2024-01-27T15:15:58.903231 ... I --- 04:205410 --:------ 01:131289 3150 002 022E # 3150| I|04:205410|02 (02)
2024-01-27T15:15:58.907523 ... I --- 04:205410 --:------ 01:131289 12B0 003 020000 # 12B0| I|04:205410|02 (02)
2024-01-27T15:15:58.919929 ... I --- 04:250553 --:------ 04:250553 30C9 003 00068A # 30C9| I|04:250553
2024-01-27T15:15:58.922874 ... I --- 04:250553 --:------ 01:131289 3150 002 0114 # 3150| I|04:250553|01 (01)
2024-01-27T15:15:58.927251 ... I --- 01:131289 --:------ 01:131289 2309 024 00073A0106400206400303E80404B00505DC0604B00701F4 # 2309| I|01:131289 (True)
2024-01-27T15:15:58.936876 ... I --- 01:131289 --:------ 01:131289 30C9 024 0007F501068A02062C03060804064E0506BE06062A077FFF # 30C9| I|01:131289 (True)
when i go into HA Entities i see several , and several climates, but none are responsive.
I see a temperature , and i see the setpoint, but cant control them,
hereās a snippet of grep schema
2024-01-27 15:15:56.332 WARNING (MainThread) [custom_components.ramses_cc.schemas] Using a merged schema (cached schema is not a superset of config schema), if required, use 'restore_cache: restore_schema: false'
2024-01-27 15:15:56.345 INFO (MainThread) [custom_components.ramses_cc.coordinator] Success initialising with a merged (config/cached) schema: {'main_tcs': '01:113289', '01:113289': {'system': {'appliance_control': '13:239590'}, 'orphans': [], 'stored_hotwater': {}, 'underfloor_heating': {}, 'zones': {}}, '01:131289': {'system': {'appliance_control': '13:194278'}, 'orphans': [], 'stored_hotwater': {}, 'underfloor_heating': {}, 'zones': {'00': {'_name': None, 'class': None, 'sensor': None, 'actuators': []}, '01': {'_name': None, 'class': None, 'sensor': '04:250553', 'actuators': ['04:250553']}, '02': {'_name': None, 'class': None, 'sensor': '04:205410', 'actuators': ['04:205410']}, '03': {'_name': None, 'class': None, 'sensor': '04:234364', 'actuators': ['04:234364']}, '04': {'_name': None, 'class': None, 'sensor': None, 'actuators': ['04:158204', '04:205512']}, '05': {'_name': None, 'class': None, 'sensor': None, 'actuators': ['04:158578']}, '06': {'_name': None, 'class': None, 'sensor': None, 'actuators': ['04:156304']}, '07': {'_name': None, 'class': None, 'sensor': '01:131289', 'actuators': []}}}, '01:011289': {'system': {'appliance_control': None}, 'orphans': [], 'stored_hotwater': {}, 'underfloor_heating': {}, 'zones': {}}, '01:001128': {'system': {'appliance_control': None}, 'orphans': [], 'stored_hotwater': {}, 'underfloor_heating': {}, 'zones': {}}, '01:001182': {'system': {'appliance_control': None}, 'orphans': [], 'stored_hotwater': {}, 'underfloor_heating': {}, 'zones': {}}, 'orphans_heat': ['13:194278'], 'orphans_hvac': []}
2024-01-27 15:16:15.007 INFO (MainThread) [custom_components.ramses_cc.binary_sensor] Found a Binary Sensor for 01:113289: schema
hereās my config
serial_port: /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A50285BI-if00-port0
restore_cache: true
packet_log: packet.log
ramses_rf:
enable_eavesdrop: true
enforce_known_list: true
01:131289:
system:
appliance_control: 13:194278 # an OTB
zones:
"00": {sensor: 01:131289} # controller is the sensor
known_list:
01:131289: #controller
04:250553: #02
04:234364: #03
04:158204: #04-1
04:205512: #04-2
04:158578: #05
04:156304: #06
18:262143: {class: HGI} #gateway_interface
13:194278: # relay floor
13:239590: # relay
