Honeywell CH/DHW via RF - evohome, sundial, hometronics, chronotherm
@peternash I’d be interested if you could try ramses_rf 0.31.18 (on pypi) with the latest ramses_cc - you should be able to simply edit the manifest.json file.
You can try with/without disable_qos: false (i.e. the alternative is not to have disable_qos at all.
@zxdavb I’m now running ramses_cc 0.41.16 with ramses_rf 0.31.18 (confirmed by inspecting version.py) I assume that’s what you meant as I can’t access ramses_cc 0.41.17 now.
I’ve not seen any problems so far and no apparent difference with/without disable_qos: false
I’ve tried temperature overrides and heating mode changes using the Thermostat card and the climate services which were failing in ramses_cc 0.41.17 and they’re working OK.
Nothing unusual in the log either.
I’ll leave it running for a while and see how it behaves.
I have the SSM-D2 but I don’t seem to be able to get Ramses RF to recognise it. (I’m using Hassos on a Raspberry Pi 4B 8GB and want to connect Honeywell and Nuaire devices).
Well I look at the list of hardware in HA , I don’t see a tty01 or similar .
How can I be sure I’ve got the right serial port?
@zxdavb I’ve not seen any significant issues in about 12 hours. I’ve seen two Evohome communication drop outs which is unusual but may be coincidence. There are more warnings in the logs then usual - I’ve attached an hour’s worth below. The ones from ramses_rf.dispatcher about 22:012299 have been occurring for a while but the PacketInvalid messages from ramses_tx.transport are new with this configuration.
This was without disable_qos: false. I’ll try setting that and see if there’s any change in the logs.
2024-04-18 08:07:54.461 WARNING (MainThread) [ramses_tx.transport] 2349 007 02070800FFFF 18:072981 13:042605 --:------ 3E0 RQ --- 1 RQ --- 18:0136 --:------ 322220 005 00C0192270 < PacketInvalid(Bad frame: invalid structure: >>> 007 02070800FFFF 18:072981 13:042605 --:------ 3E0 RQ --- 1 RQ --- 18:0136 --:------ 322220 005 00C0192270<<<)
2024-04-18 08:07:54.642 WARNING (MainThread) [ramses_tx.transport] 067 RP --- 10:064873 01:216136 --:------ 3046 RQ --- 01:216136 10:064873 --:------ 3220 005 00801A0000 < PacketInvalid(Bad frame: invalid structure: >>>RP --- 10:064873 01:216136 --:------ 3046 RQ --- 01:216136 10:064873 --:------ 3220 005 00801A0000<<<)
2024-04-18 08:10:11.147 WARNING (MainThread) [ramses_tx.transport] 9 027 0006C00106FE03070A04071F0507720607360807230905FA0A0685 < PacketInvalid(Bad frame: invalid structure: >>>7 0006C00106FE03070A04071F0507720607360807230905FA0A0685<<<)
2024-04-18 08:12:36.487 WARNING (MainThread) [ramses_rf.dispatcher]  W --- 22:012299 01:216136 --:------ 22C9 006 01076C09F601 < PacketInvalid( W --- 22:012299 01:216136 --:------ 22C9 006 01076C09F601 < Unexpected code for dst to Rx)
2024-04-18 08:31:21.482 WARNING (MainThread) [ramses_rf.dispatcher]  W --- 22:012299 01:216136 --:------ 22C9 006 01076C09F601 < PacketInvalid( W --- 22:012299 01:216136 --:------ 22C9 006 01076C09F601 < Unexpected code for dst to Rx)
2024-04-18 08:32:49.653 WARNING (MainThread) [ramses_tx.transport] *** sync cycle stats: 0.053, avg: 0.046, lower: 0.011, upper: 0.082, times: ['0.082', '0.053', '0.011', '0.031', '0.053']
2024-04-18 08:42:50.807 WARNING (MainThread) [ramses_tx.transport] 0018:072981 01:216136 --:------ 2349 001 09 < PacketInvalid(Bad frame: invalid structure: >>>:072981 01:216136 --:------ 2349 001 09<<<)
2024-04-18 08:48:39.149 WARNING (MainThread) [ramses_tx.transport] 046 RP --- 01:216136 18:072981 --0000 < PacketInvalid(Bad frame: invalid structure: >>>RP --- 01:216136 18:072981 --0000<<<)
2024-04-18 08:50:06.479 WARNING (MainThread) [ramses_rf.dispatcher]  W --- 22:012299 01:216136 --:------ 22C9 006 01076C09F601 < PacketInvalid( W --- 22:012299 01:216136 --:------ 22C9 006 01076C09F601 < Unexpected code for dst to Rx)
2024-04-18 09:02:26.050 WARNING (MainThread) [ramses_tx.transport] 046 RP --- 01:216136 18:00006 004 00050001 < PacketInvalid(Bad frame: invalid structure: >>>RP --- 01:216136 18:00006 004 00050001<<<)
2024-04-18 09:03:19.321 WARNING (MainThread) [ramses_tx.transport] 06 10:064873 18:072981 --:------ 2401 004 00000924 < PacketInvalid(Bad frame: invalid structure: >>>0:064873 18:072981 --:------ 2401 004 00000924<<<)
2024-04-18 09:04:10.418 WARNING (MainThread) [ramses_tx.transport] 047216136 10:064873 --:------ 3EF0 001 00 < PacketInvalid(Bad frame: invalid structure: >>>16136 10:064873 --:------ 3EF0 001 00<<<)
2024-04-18 09:05:25.706 WARNING (MainThread) [ramses_tx.transport] 057 994 --:------ 04:208994 30C9 003 0006AB < PacketInvalid(Bad frame: invalid structure: >>>994 --:------ 04:208994 30C9 003 0006AB<<<)
And this is a typical hour of log messages with disable_qos: false
2024-04-18 15:02:46.071 WARNING (MainThread) [ramses_tx.transport] 000 RQ --- 18:072981 10:064873 000000000 < PacketInvalid(Bad frame: invalid structure: >>>RQ --- 18:072981 10:064873 000000000<<<)
2024-04-18 15:02:46.093 WARNING (MainThread) [ramses_tx.protocol_fsm] <ProtocolContext state=WantEcho cmd_=3220|RQ|10:064873|00, tx_count=1/4>: Invalid state to receive a reply (expecting echo)
2024-04-18 15:05:06.394 WARNING (MainThread) [ramses_rf.dispatcher]  W --- 22:012299 01:216136 --:------ 22C9 006 01076C09F601 < PacketInvalid( W --- 22:012299 01:216136 --:------ 22C9 006 01076C09F601 < Unexpected code for dst to Rx)
2024-04-18 15:22:25.610 WARNING (MainThread) [ramses_tx.transport] 047  I --- 01:216136 --:-----F04D3 < PacketInvalid(Bad frame: invalid structure: >>> I --- 01:216136 --:-----F04D3<<<)
2024-04-18 15:23:51.390 WARNING (MainThread) [ramses_rf.dispatcher]  W --- 22:012299 01:216136 --:------ 22C9 006 01076C09F601 < PacketInvalid( W --- 22:012299 01:216136 --:------ 22C9 006 01076C09F601 < Unexpected code for dst to Rx)
2024-04-18 15:27:01.914 WARNING (MainThread) [ramses_tx.transport] 060:064873 18:072981 --:------ 2401 004 00000100 < PacketInvalid(Bad frame: invalid structure: >>>064873 18:072981 --:------ 2401 004 00000100<<<)
2024-04-18 15:28:01.911 WARNING (MainThread) [ramses_tx.transport] 000 RQ --- 18:072981  2401 001 00 < PacketInvalid(Bad frame: invalid structure: >>>RQ --- 18:072981  2401 001 00<<<)
2024-04-18 15:28:02.391 WARNING (MainThread) [ramses_tx.protocol_fsm] TOUT = <ProtocolContext state=WantEcho cmd_=2401|RQ|10:064873, tx_count=1/4>: echo_timeout=0.5
2024-04-18 15:42:36.387 WARNING (MainThread) [ramses_rf.dispatcher]  W --- 22:012299 01:216136 --:------ 22C9 006 01076C09F601 < PacketInvalid( W --- 22:012299 01:216136 --:------ 22C9 006 01076C09F601 < Unexpected code for dst to Rx)
2024-04-18 15:48:13.827 WARNING (MainThread) [ramses_tx.transport] 0 RQ --- 72981 --:------  RQ --- 01: I --- 04:208---- 13:042605 3EF001:216136 --72981 10:06487310:064873 --:--------- 18:072981 10:064873 --:------ 2401 001 00 < PacketInvalid(Bad frame: invalid structure: >>> --- 72981 --:------  RQ --- 01: I --- 04:208---- 13:042605 3EF001:216136 --72981 10:06487310:064873 --:--------- 18:072981 10:064873 --:------ 2401 001 00<<<)
2024-04-18 15:48:13.854 WARNING (MainThread) [ramses_tx.transport] 000 RQ 065 RP --- 10:064873 18:072981 --:------ 2401 004 00000100 < PacketInvalid(Bad frame: invalid structure: >>>RQ 065 RP --- 10:064873 18:072981 --:------ 2401 004 00000100<<<)
2024-04-18 15:48:14.305 WARNING (MainThread) [ramses_tx.protocol_fsm] TOUT = <ProtocolContext state=WantEcho cmd_=2401|RQ|10:064873, tx_count=1/4>: echo_timeout=0.5
2024-04-18 15:56:07.421 WARNING (MainThread) [ramses_tx.transport] 047 RQ --- 01:216136 10:001 00 < PacketInvalid(Bad frame: invalid structure: >>>RQ --- 01:216136 10:001 00<<<)
2024-04-18 15:56:27.291 WARNING (MainThread) [ramses_tx.transport] --:------ 2349 00748 RQ ---- 01:216136 1F09 003 F070730000 < PacketInvalid(Bad frame: invalid structure: >>>----- 2349 00748 RQ ---- 01:216136 1F09 003 F070730000<<<)
2024-04-18 15:56:45.991 WARNING (MainThread) [ramses_tx.transport] 065 RP --- 10:064873 01:216136 --:------ 3220 005 0040  I --- 04:036068 --:------ 01:216136 3150 002 0700 < PacketInvalid(Bad frame: invalid structure: >>>RP --- 10:064873 01:216136 --:------ 3220 005 0040  I --- 04:036068 --:------ 01:216136 3150 002 0700<<<)
2024-04-18 16:01:21.383 WARNING (MainThread) [ramses_rf.dispatcher]  W --- 22:012299 01:216136 --:------ 22C9 006 01076C09F601 < PacketInvalid( W --- 22:012299 01:216136 --:------ 22C9 006 01076C09F601 < Unexpected code for dst to Rx)
@zxdavb Update: After rebooting HA for other reasons I’m no longer seeing as many warnings in the logs. Previously I’d only done a restart after making changes. I’m still running ramses_cc 0.41.16 with ramses_rf 0.31.18 without disable_qos: false on Home Assistant Blue with an SSM-D2. I believe a reboot cycles the power on the SSM-D2 whereas a restart does not so maybe that was significant.
The only warnings I’m seeing at the moment are the same as on recent ramses_cc versions which I think relate to my DT4R thermostat.
2024-04-19 03:16:21.228 WARNING (MainThread) [ramses_rf.dispatcher]  W --- 22:012299 01:216136 --:------ 22C9 006 01076C09F601 < PacketInvalid( W --- 22:012299 01:216136 --:------ 22C9 006 01076C09F601 < Unexpected code for dst to Rx)
2024-04-19 03:35:06.225 WARNING (MainThread) [ramses_rf.dispatcher]  W --- 22:012299 01:216136 --:------ 22C9 006 01076C09F601 < PacketInvalid( W --- 22:012299 01:216136 --:------ 22C9 006 01076C09F601 < Unexpected code for dst to Rx)
2024-04-19 03:53:51.220 WARNING (MainThread) [ramses_rf.dispatcher]  W --- 22:012299 01:216136 --:------ 22C9 006 01076C09F601 < PacketInvalid( W --- 22:012299 01:216136 --:------ 22C9 006 01076C09F601 < Unexpected code for dst to Rx)
2024-04-19 04:12:36.212 WARNING (MainThread) [ramses_rf.dispatcher]  W --- 22:012299 01:216136 --:------ 22C9 006 01076C09F601 < PacketInvalid( W --- 22:012299 01:216136 --:------ 22C9 006 01076C09F601 < Unexpected code for dst to Rx)
2024-04-19 04:31:21.209 WARNING (MainThread) [ramses_rf.dispatcher]  W --- 22:012299 01:216136 --:------ 22C9 006 01076C09F601 < PacketInvalid( W --- 22:012299 01:216136 --:------ 22C9 006 01076C09F601 < Unexpected code for dst to Rx)
2024-04-19 04:50:06.206 WARNING (MainThread) [ramses_rf.dispatcher]  W --- 22:012299 01:216136 --:------ 22C9 006 01076C09F601 < PacketInvalid( W --- 22:012299 01:216136 --:------ 22C9 006 01076C09F601 < Unexpected code for dst to Rx)
This is a little odd… I like to hear about any Unexpected code for... messages.
They weren’t in any test suite, so I have added this:
[EDIT] They were in the test suite:
2024-04-18 08:12:36.487000 ...  W --- 22:012299 01:216136 --:------ 22C9 006 01076C09F601      # {'ufh_idx': '01', 'mode': 'heat', 'setpoint_bounds': (19.0, 25.5)}
… but that won’t test the slug (device type), only the payload parsers.
Sadly, the test suite is not geared up to validating device slug detection, so I have changed the error message for future releases, e.g.:
raise exc.PacketInvalid(f"{msg!r} < Unexpected code for dst ({slug}) to Rx")
… and we’ll see where that takes us!
Actually, I just read your comment about a DT4R (I see so many systems, I forget each person’s detailed config).
… and so, we have this: DT4R - Unexpected code for dst to Rx · Issue #93 · zxdavb/ramses_rf · GitHub
The answer is:
  • the slug is being detected correctly (i.e. the CTL)
  • ramses_rf is not able to stop itself from throwing an exception for this message, even though it should not be doing so
Fixing this issue would require re-writing a portion of the code that is deep within it’s core logic - a risky business that I won’t take on at the moment.
I may need to address this in the future…
I’ve been playing with writing schedules and it was working. I’ve written a script that I intend to use to restore the default schedule. It seems to fail now that I have service calls for 4 zones one after the other. This caused a complete loss of Ramses RF last night and I’ve tried it again this morning, with the following errors appearing in my logs:
Logger: homeassistant.components.script.normal_heating_script
Source: helpers/script.py:507
integration: Scripts (documentation, issues)
First occurred: 10:04:44 (2 occurrences)
Last logged: 10:05:41
Normal heating schedule: Error executing script. Unexpected error for call_service at pos 4: 'NoneType' object has no attribute 'src'
Normal heating schedule: Error executing script. Unexpected error for call_service at pos 1: 'NoneType' object has no attribute 'src'
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 507, in _async_step
    await getattr(self, handler)()
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 736, in _async_call_service_step
    response_data = await self._async_run_long_action(
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 699, in _async_run_long_action
    return await long_task
  File "/usr/src/homeassistant/homeassistant/core.py", line 2543, in async_call
    response_data = await coro
  File "/usr/src/homeassistant/homeassistant/core.py", line 2580, in _execute_service
    return await target(service_call)
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 971, in entity_service_call
    single_response = await _handle_entity_call(
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 1043, in _handle_entity_call
    result = await task
  File "/config/custom_components/ramses_cc/climate.py", line 487, in async_set_zone_schedule
    await self._device.set_schedule(json.loads(schedule))
  File "/usr/local/lib/python3.12/site-packages/ramses_rf/system/zones.py", line 156, in set_schedule
    await self._schedule.set_schedule(schedule)
  File "/usr/local/lib/python3.12/site-packages/ramses_rf/system/schedule.py", line 373, in set_schedule
    self._global_ver, _ = await self.tcs._schedule_version(force_io=True)
  File "/usr/local/lib/python3.12/site-packages/ramses_rf/system/heat.py", line 630, in _schedule_version
    self._msg_0006 = Message(pkt)
  File "/usr/local/lib/python3.12/site-packages/ramses_tx/message.py", line 64, in __init__
    self.src: Address = pkt.src
AttributeError: 'NoneType' object has no attribute 'src'
This error originated from a custom integration.
Logger: ramses_rf.gateway
Source: custom_components/ramses_cc/climate.py:487
integration: RAMSES RF (documentation, issues)
First occurred: 10:04:33 (8 occurrences)
Failed to send 0404| W|01:065252|0202: <ProtocolContext state=WantEcho cmd_=0404| W|01:065252|0202, tx_count=4/4>: Exceeded maximum retries
Failed to send 0404| W|01:065252|0203: <ProtocolContext state=WantEcho cmd_=0404| W|01:065252|0203, tx_count=4/4>: Exceeded maximum retries
Failed to send 0006|RQ|01:065252: <ProtocolContext state=WantEcho cmd_=0006|RQ|01:065252, tx_count=4/4>: Exceeded maximum retries
Failed to send 0404| W|01:065252|0601: <ProtocolContext state=WantEcho cmd_=0404| W|01:065252|0601, tx_count=4/4>: Exceeded maximum retries
Failed to send 0404| W|01:065252|0602: <ProtocolContext state=WantEcho cmd_=0404| W|01:065252|0602, tx_count=4/4>: Exceeded maximum retries
I’m about to drop a new released that should address this issue.
Perfect. Thanks
I am very interested in doing this too, can you share the script or write a Wiki article on how you’ve achieved it?
Adventurous people can try the latest release:
  • 0.31.19 - ‘stable’ release, with no config_flow
  • 0.41.19 - pre-release with config_flow
If there are any issues, you should be able to downgrade to 0.x.16.
Please report back.
Just a heads up that the release notes on GH for 0.14.19 state “does not utilize config flow” a couple of times which I know is just a copy-paste error but could lead to confusion!
I’ve fixed it - thanks.
I’m trying to get my HGI80 to work based on a ser2net connection. I’ve setup ser2net.yaml as told in the wiki. But I don’t see any information from my EvoHome system.
In HA log I see this message:
“Detected blocking call to sleep inside the event loop by custom integration ‘ramses_cc’ at custom_components/ramses_cc/broker.py, line 127: await self.client.start(cached_packets=cached_packets()), please create a bug report at Issues · zxdavb/ramses_cc · GitHub
Do you have any clue what is wrong?
Upgraded to 0.31.19 and 0.41.19 on a separate system. Both were running fine for about 8 hours until I got a fatal crash on both. I am wondering whether the broken schedule service (worked previously) is causing it as I have an automation that runs on the hour to retrieve schedules. I’ll disable it for now to see whether it is the cause.
Error doing job: Task exception was never retrieved
  File "/usr/local/lib/python3.12/site-packages/ramses_rf/gateway.py", line 616, in async_send_cmd
    assert pkt  # mypy
AssertionError
Sorry, ser2net got deprecated & I hadn’t updated the wiki because I am always tempted/intending to put it back in…
But these use cases will really best solved with a ramses ESP dongle, which is over MQTT, and will be released soon…
Hmmm… Is there nothing more logged than that?
I will push a work-around today.
OK, I need more information…
Thank you, I will wait for the ramses ESP and use in the meantime the Honeywell cloud.
