Great it works here again as well
It does add some json_loads warnings…see attached.
Also the growing amount of depreciation warnings of hacs…that was there already
Thanks for quick fix!!
2024-08-17 18:39:57.561 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration ramses_cc which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-08-17 18:39:57.565 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-08-17 18:40:08.870 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration 'hacs' calls hass.http.register_static_path which is deprecated because it does blocking I/O in the event loop, instead call `await hass.http.async_register_static_paths([StaticPathConfig("/hacsfiles/frontend", "/config/custom_components/hacs/hacs_frontend", False)])`; This function will be removed in 2025.7 at custom_components/hacs/frontend.py, line 54: hass.http.register_static_path(f"{URL_BASE}/frontend", locate_dir(), cache_headers=False), please create a bug report at https://github.com/hacs/integration/issues
2024-08-17 18:40:08.880 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration 'hacs' calls hass.http.register_static_path which is deprecated because it does blocking I/O in the event loop, instead call `await hass.http.async_register_static_paths([StaticPathConfig("/hacsfiles/iconset.js", "/config/custom_components/hacs/iconset.js", True)])`; This function will be removed in 2025.7 at custom_components/hacs/frontend.py, line 57: hass.http.register_static_path(, please create a bug report at https://github.com/hacs/integration/issues
2024-08-17 18:40:08.889 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration 'hacs' accesses hass.components.frontend. This is deprecated and will stop working in Home Assistant 2024.9, it should be updated to import functions used from frontend directly at custom_components/hacs/frontend.py, line 68: hass.components.frontend.async_register_built_in_panel(, please create a bug report at https://github.com/hacs/integration/issues
2024-08-17 18:40:08.905 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration 'hacs' calls hass.http.register_static_path which is deprecated because it does blocking I/O in the event loop, instead call `await hass.http.async_register_static_paths([StaticPathConfig("/hacsfiles", "/config/www/community", True)])`; This function will be removed in 2025.7 at custom_components/hacs/base.py, line 1162: self.hass.http.register_static_path(, please create a bug report at https://github.com/hacs/integration/issues
2024-08-17 18:40:11.071 WARNING (ImportExecutor_0) [ramses_tx.transport] EXPERIMENTAL: Using pyserial-asyncio-fast in place of pyserial-asyncio
2024-08-17 18:40:11.312 WARNING (MainThread) [custom_components.ramses_cc.broker] The config schema is not minimal (consider minimising it)
2024-08-17 18:40:11.453 WARNING (MainThread) [ramses_rf.gateway] GATEWAY: Restoring a cached packet log...
2024-08-17 18:40:11.812 WARNING (MainThread) [ramses_rf.gateway] GATEWAY: Restored, resuming
2024-08-17 18:40:11.837 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration 'ramses_cc' calls async_forward_entry_setup for integration, ramses_cc with title: RAMSES RF and entry_id: 1e8b3c93bcd3a75eb973a4553c08da4b, which is deprecated and will stop working in Home Assistant 2025.6, await async_forward_entry_setups instead at custom_components/ramses_cc/broker.py, line 217: self._platform_setup_tasks[platform] = self.hass.async_create_task(, please create a bug report at https://github.com/zxdavb/ramses_cc/issues
2024-08-17 18:40:13.470 WARNING (MainThread) [homeassistant.components.climate] Entity climate.37:252531 (<class 'custom_components.ramses_cc.climate.RamsesHvac'>) implements HVACMode(s): auto, off and therefore implicitly supports the turn_on/turn_off methods without setting the proper ClimateEntityFeature. Please create a bug report at https://github.com/zxdavb/ramses_cc/issues
2024-08-17 18:40:20.154 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration 'hacs' accesses hass.helpers.event. This is deprecated and will stop working in Home Assistant 2024.11, it should be updated to import functions used from event directly at custom_components/hacs/base.py, line 630: self.hass.helpers.event.async_track_time_interval(, please create a bug report at https://github.com/hacs/integration/issues
2024-08-17 18:40:20.349 WARNING (MainThread) [homeassistant.util.json] json_loads was called from hacs, this is a deprecated function which will be removed in HA Core 2025.8. Use homeassistant.util.json.json_loads instead, please create a bug report at https://github.com/hacs/integration/issues
2024-08-17 18:40:20.553 WARNING (MainThread) [homeassistant.util.json] json_loads was called from hacs, this is a deprecated function which will be removed in HA Core 2025.8. Use homeassistant.util.json.json_loads instead, please create a bug report at https://github.com/hacs/integration/issues
2024-08-17 18:40:20.575 WARNING (MainThread) [homeassistant.util.json] json_loads was called from hacs, this is a deprecated function which will be removed in HA Core 2025.8. Use homeassistant.util.json.json_loads instead, please create a bug report at https://github.com/hacs/integration/issues
2024-08-17 18:40:20.590 WARNING (MainThread) [homeassistant.util.json] json_loads was called from hacs, this is a deprecated function which will be removed in HA Core 2025.8. Use homeassistant.util.json.json_loads instead, please create a bug report at https://github.com/hacs/integration/issues
2024-08-17 18:40:20.803 WARNING (MainThread) [homeassistant.util.json] json_loads was called from hacs, this is a deprecated function which will be removed in HA Core 2025.8. Use homeassistant.util.json.json_loads instead, please create a bug report at https://github.com/hacs/integration/issues
2024-08-17 18:40:21.994 WARNING (MainThread) [homeassistant.util.json] json_loads was called from hacs, this is a deprecated function which will be removed in HA Core 2025.8. Use homeassistant.util.json.json_loads instead, please create a bug report at https://github.com/hacs/integration/issues
2024-08-17 18:40:22.130 WARNING (MainThread) [homeassistant.util.json] json_loads was called from hacs, this is a deprecated function which will be removed in HA Core 2025.8. Use homeassistant.util.json.json_loads instead, please create a bug report at https://github.com/hacs/integration/issues
2024-08-17 18:40:22.143 WARNING (MainThread) [homeassistant.util.json] json_loads was called from hacs, this is a deprecated function which will be removed in HA Core 2025.8. Use homeassistant.util.json.json_loads instead, please create a bug report at https://github.com/hacs/integration/issues
2024-08-17 18:40:22.154 WARNING (MainThread) [homeassistant.util.json] json_loads was called from hacs, this is a deprecated function which will be removed in HA Core 2025.8. Use homeassistant.util.json.json_loads instead, please create a bug report at https://github.com/hacs/integration/issues
2024-08-17 18:40:22.410 WARNING (MainThread) [homeassistant.util.json] json_loads was called from hacs, this is a deprecated function which will be removed in HA Core 2025.8. Use homeassistant.util.json.json_loads instead, please create a bug report at https://github.com/hacs/integration/issues
2024-08-17 18:40:22.424 WARNING (MainThread) [homeassistant.util.json] json_loads was called from hacs, this is a deprecated function which will be removed in HA Core 2025.8. Use homeassistant.util.json.json_loads instead, please create a bug report at https://github.com/hacs/integration/issues
2024-08-18 00:40:20.432 WARNING (MainThread) [homeassistant.util.json] json_loads was called from hacs, this is a deprecated function which will be removed in HA Core 2025.8. Use homeassistant.util.json.json_loads instead, please create a bug report at https://github.com/hacs/integration/issues
2024-08-18 00:40:20.444 WARNING (MainThread) [homeassistant.util.json] json_loads was called from hacs, this is a deprecated function which will be removed in HA Core 2025.8. Use homeassistant.util.json.json_loads instead, please create a bug report at https://github.com/hacs/integration/issues
2024-08-18 00:40:20.465 WARNING (MainThread) [homeassistant.util.json] json_loads was called from hacs, this is a deprecated function which will be removed in HA Core 2025.8. Use homeassistant.util.json.json_loads instead, please create a bug report at https://github.com/hacs/integration/issues
2024-08-18 00:40:20.483 WARNING (MainThread) [homeassistant.util.json] json_loads was called from hacs, this is a deprecated function which will be removed in HA Core 2025.8. Use homeassistant.util.json.json_loads instead, please create a bug report at https://github.com/hacs/integration/issues
2024-08-18 06:40:20.408 WARNING (MainThread) [homeassistant.util.json] json_loads was called from hacs, this is a deprecated function which will be removed in HA Core 2025.8. Use homeassistant.util.json.json_loads instead, please create a bug report at https://github.com/hacs/integration/issues
2024-08-18 06:40:20.422 WARNING (MainThread) [homeassistant.util.json] json_loads was called from hacs, this is a deprecated function which will be removed in HA Core 2025.8. Use homeassistant.util.json.json_loads instead, please create a bug report at https://github.com/hacs/integration/issues
2024-08-18 06:40:20.433 WARNING (MainThread) [homeassistant.util.json] json_loads was called from hacs, this is a deprecated function which will be removed in HA Core 2025.8. Use homeassistant.util.json.json_loads instead, please create a bug report at https://github.com/hacs/integration/issues
2024-08-18 06:40:20.463 WARNING (MainThread) [homeassistant.util.json] json_loads was called from hacs, this is a deprecated function which will be removed in HA Core 2025.8. Use homeassistant.util.json.json_loads instead, please create a bug report at https://github.com/hacs/integration/issues
2024-08-18 07:18:08.943 WARNING (MainThread) [ramses_tx.transport] *** sync cycle stats: 0.095, avg: 0.095, lower: 0.095, upper: 0.095, times: ['0.095']
2024-08-18 12:40:20.411 WARNING (MainThread) [homeassistant.util.json] json_loads was called from hacs, this is a deprecated function which will be removed in HA Core 2025.8. Use homeassistant.util.json.json_loads instead, please create a bug report at https://github.com/hacs/integration/issues
2024-08-18 12:40:20.435 WARNING (MainThread) [homeassistant.util.json] json_loads was called from hacs, this is a deprecated function which will be removed in HA Core 2025.8. Use homeassistant.util.json.json_loads instead, please create a bug report at https://github.com/hacs/integration/issues
2024-08-18 12:40:20.451 WARNING (MainThread) [homeassistant.util.json] json_loads was called from hacs, this is a deprecated function which will be removed in HA Core 2025.8. Use homeassistant.util.json.json_loads instead, please create a bug report at https://github.com/hacs/integration/issues
2024-08-18 12:40:20.462 WARNING (MainThread) [homeassistant.util.json] json_loads was called from hacs, this is a deprecated function which will be removed in HA Core 2025.8. Use homeassistant.util.json.json_loads instead, please create a bug report at https://github.com/hacs/integration/issues
2024-08-18 14:51:08.798 WARNING (MainThread) [ramses_tx.transport] *** sync cycle stats: 0.021, avg: 0.058, lower: 0.021, upper: 0.095, times: ['0.095', '0.021']
2024-08-18 16:10:25.276 WARNING (MainThread) [ramses_tx.transport] *** sync cycle stats: 0.105, avg: 0.074, lower: 0.021, upper: 0.105, times: ['0.095', '0.021', '0.105']
2024-08-18 16:25:31.271 WARNING (MainThread) [ramses_tx.transport] *** sync cycle stats: 0.094, avg: 0.079, lower: 0.021, upper: 0.105, times: ['0.095', '0.021', '0.105', '0.094']
2024-08-18 17:14:35.763 WARNING (MainThread) [ramses_tx.transport] *** sync cycle stats: 0.033, avg: 0.070, lower: 0.021, upper: 0.105, times: ['0.095', '0.021', '0.105', '0.094', '0.033']
