Honeywell CH/DHW via RF - evohome, sundial, hometronics, chronotherm
Do you have an advise how to proceed?
Well, destroy zone 1 (which has the OTB bound to it) for a start. Then re-create it with the correct actuators (TRVs, I think, yes?).
Then, you’ll need to reset the OTB, otherwise it will do what zone 1 asks, as well as the controller - this could ‘stop’ any optimizations the controller may choose to make.
Then you’ll need to re-bind the OTB to the controller.
And why did zone 0 go from 3 TRVs to 1?
For all other devices I can see the entities. For the thermostats, I can see the entities for battery and temperature but they are marked as unavailable. As they are were recognized I hoped it’s only a configuration issue why they can’t be read.
Hi David,
Also from my side, thanks for looking into this.
I followed your advice for the moment. I disconnected my thread dongle to free up a USB port and added the RAMSES_ESP.
I only changed the serial setting, and it looks like it picked up on all 4 devices correctly. I was able to set the temperature and sofar the devices haven’t gone missing :-).
Hope I can help figuring out what is the cause, because I want to go back to mqtt at one point.
Do you need more logging?
Bert
Hi All,
Love the work that has been happening here!
I have a request. as I have a MVS-15 ORCON box. And I would love for it to go into home assistant. I shouldn’t be too hard, I’ve figured out what’s the cause.
packet.log
2024-11-03T19:13:56.141016 078 I — 29:211060 --:------ 29:211060 31D9 003 000004
home-assistant.log
2024-11-03 19:13:56.141 INFO (MainThread) [ramses_rf.dispatcher] || 29:211060 | | I | fan_state | 00 || {‘hvac_id’: ‘00’, ‘exhaust_fan_speed’: 0.02, ‘fan_mode’: ‘04’, ‘passive’: False, ‘damper_only’: False, ‘filter_dirty’: False, ‘frost_cycle’: False, ‘has_fault’: False, ‘_flags’: [0, 0, 0, 0, 0, 0, 0, 0]}
The message is an 31D9. And it’s not being translated in the hvac.py in ramses_rf see below.
    @property
    def exhaust_fan_speed(self) -> float | None:  # was from: (Code._31D9, Code._31DA)
        return self._msg_value(Code._31DA, key=SZ_EXHAUST_FAN_SPEED)
    @property
    def exhaust_flow(self) -> float | None:
        return self._msg_value(Code._31DA, key=SZ_EXHAUST_FLOW)
    @property
    def exhaust_temp(self) -> float | None:
        return self._msg_value(Code._31DA, key=SZ_EXHAUST_TEMP)
I changed the code in my home-assistant docker for fan_speed, and it picks it up just fine. Any chance something can be done?
Hi Bert,
Unfortunaly my device running Home Assistant is too far away to do this test myself. But did you also experienced that with the RAMSES_ESP MQTT setup the devices go missing when you change the temperature? And is that gone after connecting the device to USB?
Patrick
Hi Patrick,
Yes, when the device was available to start with, (which often it wasnt), when I set the temperature. most of the times the device bekame unavailable. But 1 or 2 times I was able to set the temperature.
On a related note I now have a serial link via USB. This is stable. But I miss how to set the mode to “Away”, or any of the other overrides. Can I configure that?
Bert
Hi Bert,
Thank you, good to know. Hopefully the issue can be fixed soon.
The presets are available in the thermostat card.
Hi Patrick,
Thanks for the screenshot. I missed the option to select the profile. I found out that you can set that in the options of the card. Solved now.
And I can set away and home now as well. Hurray!
Hi David,
After making the changes you advised the problems stayed the same. Since these problems were gone when Bert changed from MQTT to USB connected I tried the same. Although the distance between my Home Assistant machine and the EvoHome system is a bit too far the integration now works stable. So looking at the results of Bert and myself I think there is an issue with the MQTT communication. Is it possible to further analyse this, so it can be solved and how can I help?
As a complete noob I hope to find some assistance here for my first steps.
Today I’ve installed a Home Assistant Green.
I have HACS installed, and Ramses RF is one of the services that I see when I go to Settings / Devices & Servides.
I have plugged in the SSM-D2 stick from Indalo tech in the HA Green usb port.
I have put the following line in my configuration.yaml
ramses_cc:
serial_port: /dev/serial/by-id/usb-SparkFun_evofw3_atmega32u4-if00
I also tried different values after “/dev/serial/” that I found in differtent topics.
After restarting I open the Logbook and select the Entity Ramses RF. There are no entries.
This is about where I am at the moment. I read and applied the knowledge that I could find across the interweb.
So could anyone point me in the right direction for the next step? Tx!
Unfortunately the wiki is not up-to-date, there is no need to add it to configuration.yaml (that’s deprecated), you need to add the integration through Settings → Devices & Services → + Add Integration button. Search for ramses and then click > on that line. You should then be presented with a dialog.
I am replacing my serial RAMSES RF device with the RAMSES-ESP. The ESP seems to work well. However I am running into an issue with connecting the HA RAMSES integration to MQTT. Is it required to provide a username/password, or I can just use mqtt://[ip address]:1883?
I tried the latter but it does not seem to work.
It works now. It was my mistake in entering the connection string in the wrong box.
I am running into another error now:
2024-11-22 05:23:54.586 WARNING (MainThread) [ramses_tx.protocol_fsm] TOUT.. = <ProtocolContext state=WantEcho cmd_=22E0|RQ|37:211831, tx_count=1/4>: echo_timeout=1.0
2024-11-22 05:23:54.805 ERROR (MainThread) [homeassistant] Error doing job: Exception in callback PortTransport._read_ready() (None)
  File "/usr/local/lib/python3.12/asyncio/events.py", line 88, in _run
    self._context.run(self._callback, *self._args)
  File "/usr/local/lib/python3.12/site-packages/ramses_tx/transport.py", line 935, in _read_ready
    self._frame_read(
  File "/usr/local/lib/python3.12/site-packages/ramses_tx/transport.py", line 744, in _frame_read
    super()._frame_read(dtm_str, self._regex_hack(frame, self._inbound_rule))  # type: ignore[misc]
  File "/usr/local/lib/python3.12/site-packages/ramses_tx/transport.py", line 611, in _frame_read
    self._pkt_read(pkt)
  File "/usr/local/lib/python3.12/site-packages/ramses_tx/transport.py", line 421, in wrapper
    fnc(self, pkt)
  File "/usr/local/lib/python3.12/site-packages/ramses_tx/transport.py", line 950, in _pkt_read
    super()._pkt_read(pkt)
  File "/usr/local/lib/python3.12/site-packages/ramses_tx/transport.py", line 622, in _pkt_read
    raise exc.TransportError("Transport is closing or has closed")
ramses_tx.exceptions.TransportError: Transport is closing or has closed
This error appears almost every second.
About every 20 minutes I see that the Ramses-esp disconnects from the mqtt broker.
Any suggestions?
Update:
When I enabled the serial USB stick on home assistant again and enabled the other HGI everything seems to work again, so it seems related as expected to the MQTT connection.
Sofar I only noticed that the time synchronisation in the Ramses-esp does not seem to work.
Update 2:
I set the ntp server again, as well as the timezone and the timestamp is correct now.
However when enable the Ramses-esp I get the same error messages as before.
Update 3:
I finally solved the issue by clearing the cache and restarting home assistant.
All,
I am looking for someone with the relevant skills to take over ramses_rf and ramses_cc as I no longer have the time to contribute at the necessary intensity.
Nor do I have honeywell/resideo evohome kit any more (although the majority of users are now HVAC).
Please PM me.
David,
A real shame to see this, firstly a massive thank you for all the work that you’d done on this project (your project). Hopefully someone is willing and able to take this on.
Can I ask what you’ve moved to from Evohome ?
I have switched to a heat pump.
I just don’t have time to work on it any more, either.
I is a large project (three large projects, really), and still needs some work.
Yes! Please PM me - I am happy to help someone as they take this on.
yes thank you for all your work David. I’m happy to help though believe it will need several people to keep it going - while I have time, I don’t have all the skills though i do have evohome.
Heatpump with traditional TRVs?
Thanks for ramses_cc! Without it I wouldnt be able to find undersized radiators and so on.
David! Massive thanks for the blood, sweat and tears you have put into this. Sad to see you go, but such is life. Good luck with your future endeavours.
