Yup, I did the same and all good. There are some other warnings that I have not seen before.
Logger: homeassistant.helpers.frame
Source: helpers/frame.py:324
First occurred: 15:11:46 (3 occurrences)
Last logged: 15:11:47
Detected that custom integration 'ramses_cc' calls `device_registry.async_get_or_create` referencing a non existing `via_device` ('ramses_cc', '01:078710_HW'), with device info: {'identifiers': {('ramses_cc', '07:017494')}, 'manufacturer': None, 'model': <DevType.DHW: 'DHW'>, 'name': 'DHW 07:017494', 'serial_number': '07:017494', 'via_device': ('ramses_cc', '01:078710_HW')} at custom_components/ramses_cc/broker.py, line 269: device_registry.async_get_or_create(. This will stop working in Home Assistant 2025.12.0, please create a bug report at https://github.com/zxdavb/ramses_cc/issues
Detected that custom integration 'ramses_cc' registers an entity service with a non entity service schema at custom_components/ramses_cc/climate.py, line 113: platform.async_register_entity_service(k, v, f"async_{k}"). This will stop working in Home Assistant 2025.9, please create a bug report at https://github.com/zxdavb/ramses_cc/issues
Detected that custom integration 'ramses_cc' registers an entity service with a non entity service schema at custom_components/ramses_cc/water_heater.py, line 59: platform.async_register_entity_service(k, v, f"async_{k}"). This will stop working in Home Assistant 2025.9, please create a bug report at https://github.com/zxdavb/ramses_cc/issues
and
Logger: homeassistant.util.loop
Source: util/loop.py:136
First occurred: 15:11:46 (1 occurrences)
Last logged: 15:11:46
Detected blocking call to open with args ('/config/evohome/packet.log', 'a') inside the event loop by custom integration 'ramses_cc' at custom_components/ramses_cc/broker.py, line 146: await self.client.start(cached_packets=cached_packets()) (offender: /usr/local/lib/python3.13/logging/__init__.py, line 1247: return open_func(self.baseFilename, self.mode,), please create a bug report at https://github.com/zxdavb/ramses_cc/issues For developers, please see https://developers.home-assistant.io/docs/asyncio_blocking_operations/#open Traceback (most recent call last): File "<frozen runpy>", line 198, in _run_module_as_main File "<frozen runpy>", line 88, in _run_code File "/usr/src/homeassistant/homeassistant/__main__.py", line 227, in <module> sys.exit(main()) File "/usr/src/homeassistant/homeassistant/__main__.py", line 213, in main exit_code = runner.run(runtime_conf) File "/usr/src/homeassistant/homeassistant/runner.py", line 154, in run return loop.run_until_complete(setup_and_run_hass(runtime_config)) File "/usr/local/lib/python3.13/asyncio/base_events.py", line 707, in run_until_complete self.run_forever() File "/usr/local/lib/python3.13/asyncio/base_events.py", line 678, in run_forever self._run_once() File "/usr/local/lib/python3.13/asyncio/base_events.py", line 2033, in _run_once handle._run() File "/usr/local/lib/python3.13/asyncio/events.py", line 89, in _run self._context.run(self._callback, *self._args) File "/usr/src/homeassistant/homeassistant/config_entries.py", line 788, in async_setup_locked await self.async_setup(hass, integration=integration) File "/usr/src/homeassistant/homeassistant/config_entries.py", line 551, in async_setup await self.__async_setup_with_context(hass, integration) File "/usr/src/homeassistant/homeassistant/config_entries.py", line 640, in __async_setup_with_context result = await component.async_setup_entry(hass, self) File "/config/custom_components/ramses_cc/__init__.py", line 94, in async_setup_entry await broker.async_setup() File "/config/custom_components/ramses_cc/broker.py", line 146, in async_setup await self.client.start(cached_packets=cached_packets())
