Do I need to use the “evohome” integration for that?
Can I reduce the scan_interval to eg: 30?
I also noticed that the attribute ‘temperature’ of the climate entities goes N/A for a minute, then returns a decimal. Is that something that is known? It’s when I change from on to off for a zone, when turning off to on, the setpoint is set to 25°c
@zxdavb is it possible to enable / disable cold weather boost via the API?
It works perfect, with the exception of when we’re at work - it still assigns the boost to zones and causes sky high bills. I’m considering ways around it, like using a custom mode that’s switched on when we leave, or even setting zone temps manually when we leave, but they’re all a little messy
There is a fancy new evohome_rf, and a new evohome_cc to match - ver 0.5.2.
Note that evohome_cc is not yet on HACS, but I’d be pleased to have anyone test it now - just pull the latest commit of either (evohome_rf is also on PyPi) - you will lose access it the F9/FA/FB/FC sensors, but everything else should be as was.
Please only try this only if you are familiar with git, pip & HA custom_components - I do not have the capacity to help you with that side of things.
This is my configuration.yaml file (NB: packet logs are broken):
logger:
default: info
logs:
homeassistant.core: debug
homeassistant.loader: info
homeassistant.setup: info
custom_components.evohome_cc: info
evohome_rf.*: debug
evohome_rf.transport: critical
evohome_rf.protocol: info
evohome_cc:
scan_interval: 60
serial_port: /dev/ttyUSB1
packet_log: /home/user/home-assistant/.config/packet.log
schema:
controller: 01:145038
ignore_list:
- 01:037519
- 04:123456
- 10:132435
Confirm you get a version match:
2021-01-27 21:23:18 WARNING (MainThread) [custom_components.evohome_cc] evohome_cc v0.5.2, using evohome_rf v0.5.2 - versions match (this is good)
At this stage, I am interested only in useful bug reports, thanks.
The latest version of evofw3 is 0.6.5.
If anyone is willing to integrate config flow into evohome_cc, PM me.
Hi, I just got my nanoCUL yesterday and set it up with the newest version of evofw3 and installed evohome_cc 0.5.2 in my HA.
Most things/sensors seem to working fine (although I’m new to this component, so not completely sure what should be there/working). I did notice a bunch of exceptions though and the heat demand of one of my HR90’s doesn’t show up (the temperature does and all the other HR90’s are reporting temperature and heat demand).
Anyway, I’m not sure if this is related of even helpful, but this is an example of the exception being logged:
2021-02-05 16:26:50 ERROR (MainThread) [evohome_rf.message] 056 RP --- 10:015155 01:192614 --:------ 3220 005 00C00500FF < KeyError
2021-02-05 16:26:50 ERROR (MainThread) [evohome_rf] handle_exception(): Caught: Exception in callback SerialTransport._read_ready()
2021-02-05 16:26:50 ERROR (MainThread) [asyncio] Unhandled error in exception handler
context: {'message': 'Exception in callback SerialTransport._read_ready()', 'exception': KeyError('id'), 'handle': <Handle SerialTransport._read_ready()>}
File "/usr/local/lib/python3.8/asyncio/base_events.py", line 1744, in call_exception_handler
self._exception_handler(self, context)
File "/usr/local/lib/python3.8/site-packages/evohome_rf/__init__.py", line 120, in handle_exception
raise exc
File "/usr/local/lib/python3.8/asyncio/events.py", line 81, in _run
self._context.run(self._callback, *self._args)
File "/usr/local/lib/python3.8/site-packages/serial_asyncio/__init__.py", line 119, in _read_ready
self._protocol.data_received(data)
File "/usr/local/lib/python3.8/site-packages/evohome_rf/transport.py", line 388, in data_received
self._data_received(*create_pkt(line))
File "/usr/local/lib/python3.8/site-packages/evohome_rf/transport.py", line 573, in _data_received
self._callback(pkt) # only wanted PKTs up to the MSG transport's handler
File "/usr/local/lib/python3.8/site-packages/evohome_rf/protocol.py", line 139, in _pkt_receiver
[p.data_received(msg) for p in self._protocols]
File "/usr/local/lib/python3.8/site-packages/evohome_rf/protocol.py", line 139, in <listcomp>
File "/usr/local/lib/python3.8/site-packages/evohome_rf/protocol.py", line 368, in data_received
self._callback(msg)
File "/usr/local/lib/python3.8/site-packages/evohome_rf/message.py", line 552, in process_msg
update_entities(msg, msg._gwy._prev_msg) # update the state database
File "/usr/local/lib/python3.8/site-packages/evohome_rf/message.py", line 501, in update_entities
this._gwy.device_by_id[this.src.id]._handle_msg(this)
File "/usr/local/lib/python3.8/site-packages/evohome_rf/devices.py", line 756, in _handle_msg
self._opentherm_msg[msg.payload["id"]] = msg # TODO: these need to expire
KeyError: 'id'
All, if (when upgrading to v0.5.5) you get this error message, Setup failed for evohome_cc: Invalid config:
2021-02-05 23:19:13 ERROR (MainThread) [homeassistant.config] Invalid config for [evohome_cc]: [packet_log] is an invalid option for [evohome_cc]. Check: evohome_cc->evohome_cc->schcema. (See /home/dbonnes/home-assistant/.config/configuration.yaml, line 32). Please check the docs at https://github.com/zxdavb/evohome_cc
2021-02-05 23:19:13 ERROR (MainThread) [homeassistant.setup] Setup failed for evohome_cc: Invalid config.
… or this one:
2021-02-05 23:19:14 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=persistent_notification, service=create, service_data=title=Invalid config, message=The following integrations and platforms could not be set up:
- [evohome_cc](https://github.com/zxdavb/evohome_cc)
Please check your config and [logs](/config/logs)., notification_id=invalid_config>
Please note that the configuration.yamlhas changed to introduce config::
Release v0.5.5 - better logging, so I can fix bugs.
Bellow is a suggested logger: config, for if you’d like help. Please also note the packet_log: parameter in the previous post (which is currently required, but will become optional).
logger:
default: info # don't use debug
logs:
homeassistant.core: debug # Event state_changed
homeassistant.loader: info # You are using a custom integration for evohome_cc...
homeassistant.setup: info # Setting up evohome_cc
custom_components.evohome_cc.*: debug
# evohome_rf.transport: info
There will be no need to enable evohome_rf.transport, unless I specifically request.
Note the latest version of evofw3 is 0.6.6, which is strongly recommended.
I have re-written parts of the parser. I would be grateful fro anyone to send me 24h of packet logs using a HGI80, or a nanoCUL running evofw3 0.6.6 or later to test against …
… it would be great if something happened in the 24h - the more weird, the better (e.g. re-binding a round thermostat to a zone).
with the version 0.5.5 I get the following error although I have alreadybcreated the packet.log file and permissions are ok. Any idea?
File “/usr/src/homeassistant/homeassistant/setup.py”, line 213, in _async_setup_component
result = await task
File “/config/custom_components/evohome_cc/init.py”, line 116, in async_setup
client = evohome_rf.Gateway(serial_port, loop=hass.loop, **kwargs)
File “/config/custom_components/evohome_cc/evohome_rf/init.py”, line 72, in init
set_pkt_logging(
File “/config/custom_components/evohome_cc/evohome_rf/packet.py”, line 126, in set_pkt_logging
handler = logging.FileHandler(file_name)
File “/usr/local/lib/python3.8/logging/init.py”, line 1143, in init
StreamHandler.init(self, self._open())
File “/usr/local/lib/python3.8/logging/init.py”, line 1172, in _open
return open(self.baseFilename, self.mode, encoding=self.encoding)
FileNotFoundError: [Errno 2] No such file or directory: ‘/home/pi/home-assistant/.config/packet.log’
