That is the plan.
Not yet - you (hometronics) should set max zones to 16, and enable eavesdropping.
Well, itâs up now - you should be able to try it.
I updated yesterday morning to the version from 5 days ago, after that thet status of the climate entities are getting after a few hours te status unknown.
Yesterdag evening i updated to the version that came out yesterday, but stil the same problem, after reboot i have a good status but after a few hours i get the unknown status.
What could be the problem, the temperature entities are still getting updates.
I see no errors in the log.
Updated to 0.8.6 last night and its stopped working.
Tried a reboot this morning, check device link to whatâs in my configuration.yaml and all looks good there.
Logger: homeassistant.setup
Source: custom_components/evohome_cc/__init__.py:220
First occurred: 9:20:16 AM (1 occurrences)
Last logged: 9:20:16 AM
Error during setup of component evohome_cc
File "/usr/src/homeassistant/homeassistant/setup.py", line 242, in _async_setup_component
result = await task
File "/config/custom_components/evohome_cc/__init__.py", line 106, in async_setup
await broker.async_update()
File "/config/custom_components/evohome_cc/__init__.py", line 220, in async_update
_LOGGER.info("Schema = %s", evohome.schema)
File "/usr/local/lib/python3.8/site-packages/evohome_rf/systems.py", line 572, in schema
return {**super().schema, ATTR_ZONES: {z.idx: z.schema for z in self._zones}}
File "/usr/local/lib/python3.8/site-packages/evohome_rf/systems.py", line 572, in <dictcomp>
File "/usr/local/lib/python3.8/site-packages/evohome_rf/zones.py", line 809, in schema
elif not self._sensor._30C9_faked:
AttributeError: 'Controller' object has no attribute '_30C9_faked'
@zxdavb Hi David. With the latest building seeing this error appearing on HA start-up.
Source: helpers/entity.py:455
First occurred: 12:31:21 (1 occurrences)
Last logged: 12:31:21
Error doing job: Exception in callback async_track_point_in_utc_time.<locals>.run_action() at /usr/src/homeassistant/homeassistant/helpers/event.py:1172
File "/usr/local/lib/python3.8/asyncio/events.py", line 81, in _run
self._context.run(self._callback, *self._args)
File "/usr/src/homeassistant/homeassistant/helpers/event.py", line 1191, in run_action
hass.async_run_hass_job(job, utc_point_in_time)
File "/usr/src/homeassistant/homeassistant/core.py", line 428, in async_run_hass_job
hassjob.target(*args)
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 455, in async_schedule_update_ha_state
self.hass.async_create_task(self.async_update_ha_state(force_refresh))
AttributeError: 'NoneType' object has no attribute 'async_create_task'
Have exactly the same error occuringâŠ
Just commented out the relevant elif statement in zones.py and now works again. I guess the Controller device does not (yet) have the fake device codeâŠ
do you have the problem that the status goes away?
normaly i see this:
but after an hour i get this:
Yeah, hvac_action disappears after about an hour. HA restart doesnât help
OkĂ© thx for the conformation, than i donât have to look further in my config.
Sorry - I guess I broke a few things, despite testing.
No it does not. You shouldnât be seeing this - if you did something (i.e. called one of the new service calls), could you PM me with the specific steps you took to get that error message?
Only fake sensors can be impersonated - not real sensors. Impersonating a real sensor wonât be useful, unless that device if turned off (otherwise, you / it will be sending different temperatures & the controller will just react to the latest one it sees.
Try changing the code thus:
elif not hasattr(self._sensor, "_30C9_faked") or not self._sensor._30C9_faked:
sensor_schema = self._sensor.id
I will have a look when I get home.
Could be related - will have a look too.
Cheers! fixed it, error has gone. Still the weird thing with the preset_mode, hvac_mode, hvac_action going blank after an hour or so. Havenât found anything useful in the logs yetâŠ
So the _30c9_faked
has been fixed - the issue is well-understood: I didnât test for when the controller is the zone sensor (for those using eavesdropping, or those who manually set it in their schema).
Will push an update soon.
I believe I have identified/fixed this bug too - will push an update soon.
@Spaco can you confirm:
hvac_action
disappears after an hour- that it comes back if you change the zone mode
- if
restore_state: true
, reboooting doesnât help - if
restore_state: false
, rebooting does help?
David. I tried restore state (false) and it cleared for me, but has subsequently lost the status again.
