No faked sensors set up at the time.
I am struggling to get the BDR91 relays for CH and DHW to reconnect to controller. Everything else has gone back after a power cycle
You donāt have any de-ionisers by any chance do you?
The only time I ever had anything similar, and it wiped out z-wave and Hue as well, was when weād just got a new de-humidifier, with a de-ioniser.
ā¦ still not 100% sure this is/was the cause, but electrically charged particles I could see how it might be, as it was returned
No de-ionisers too.
I have changed all the batteries and rebound the relays and all seems good at moment. Hopefully this was just a coincidence.
Remind to all to remember to change your batteries before itās too late.
I use:
(venv) dbonnes@vm-builder ~/c/evohome (master)> cd ~/home-assistant/.config/
(venv) dbonnes@vm-builder ~/h/.config (master)> ls custom_components/evohome_cc/
binary_sensor.py climate.py config_flow.py const.py __init__.py manifest.json __pycache__/ schema.py sensor.py services.yaml version.py water_heater.py
You do not need to install ramses_rf (was called evohome_rf until yesterday) with either method - that is specificed in the manifest.json file.
Perhaps you could provide a log file?
Will have a look.
Yes. I am quite keen for people to have no excuse to stay on Domoticz, when they could be using HA instead
Could you PM me a copy of a packet log, taken when you re-bind your weather sensor to the controller to evohome using Domoticz? You will need to turn any device filtering off in the configuration.yaml.
Or better still - if you can manage:
python client.py -rr listen /dev/ttyACM0 -o packet.log
Ideally, doing this for 24h would be great, to catch all the packets the weather sensor might send - but the binding is the main thing.
I have 100ās of MBs of packet logs, but I donāt have a copy of any of that.
I am sorry, I cannot see how evohome_cc / ramses_rf could cause this.
I have done a lot of crazy things here whilst developing ramses_rf & never saw that behaviourā¦
Do send me packet logs if you have them, and I will take a look.
Hi @zxdavb
Iāve just put in a pull request for a tiny code tweak. It allows users to create an optional configuration parameter:
evohome_cc:
advanced_override: true
If this parameter exists and is set to true, the behaviour of set_temperature in climate.py is ZoneMode.ADVANCED. If the parameter doesnāt exist or is false, previous behaviour is maintained. I see this as a temporary measure until you have completed the development of profiles. It means I donāt have to keep manually editing your code every time I update it. I hope this request is ok for you to approve.
Thatās great! I have made a review. Please install & run pre-commit too.
Ahā¦ I think I may need a little hand-holding with that please? I was pleased with myself for managing to put in a pull request but Iām afraid Iāve no idea how to do what youāre now asking!
Update: After Googling that, Iām assuming pre-commit is something Iād need to install in a development environmentā¦ only issue is I donāt have a development environment with git installed as such! I made the changes manually in my local installation on Home Assistant, tested, then branched your repo on Github and pasted my changes in before making a pull request. I donāt have a local clone or anything like that running.
@zxdavb ok, I figured out pre-commit! It made a few changes in accordance with your policy file so Iāve revoked my original pull request and put a new one in. Hopefully thatās ok for you now?
Well done with pre-commit.
I am not sure why you closed the first PR? You can just commit/push any changes to a PR, without the need for a new one.
Iāll remember that for the next time thenā¦ Iāve no idea what Iām doing, just clicking things until it did what I wanted
I need someone with an evohome external/outside sensor to provide a packet log please.
A real Honeywell sensor, not a Domoticz faked sensor.
Please PM me.
@zxdavb David, 12 zones all being controlled by faked sensors using Xiaomi Mijia temperature and humidity sensors. The uniformity of a rooms temperature is definitely improved versus the HR91ās. Any plans to allow more than one fake sensor to be applied to a zone? This is a great enhancement!!
Thatās great - weād always expect TRV sensors to suffer from their non-optimal location & their proximity to their radiator.
No - evohome expects only one device nominated as the sensor per zone.
You could have multiple sensors, and send the average of those to evohome_cc to fake.
I was thinking in the same way you can have multiple room zone? In this case the bound HR91ās act independently of one another.
Can you explain how you set it up?
I have some aqara zigbee and some sensors attached to an esp with esphome which I can use for this but the above explanation was not really clear for me.
With the Zigbee sensors setup and reporting their values within HomeAssistant:
Now that the āfakeā sensor(s) are bound, you need to write an automation which calls RAMSES RF: set_zone_temp service passing the current value of the Zigbee sensor(s).
In my case, I have an automation running every 4 minutes, which updates the zones.
OkƩ clear, do you have an example of the automation how you use your own sensor?
The given example from a few days ago sets an manually given temperature.
