Toggled the healing to on and off now i have a State, i Will monitor it if it stays this way otherwise i can try the logging maybe tomorrow.
@zxdavb I can confirm the create_sensor call is fixed as well! Great work!
Beware using this - I should really have taken it out until it is ready for use.
This morning i had still a status, so looking good.
I did turn on the heating but than i had no status but i think this comes because the zones need no heat so the are not sending the status so this plugin canāt pick it up?
0.10.2 seems to fix my issues, many thanks:
- evohome_cc.set_zone_mode works as expected
- Boost on Hot Water works (didnāt for me in 0.9)
- UI updates immediately after making a change
- Climate entities can be updated/nudged and the respective change makes it to the evohome controller
ā¦ Canāt comment on state expiring, only just updated, but should be able to later today.
Perhaps one issue, I think the UI used to say āheatingā when it was actively heating? It doesnāt seem to, so far, (might be the issue referenced above by @TheMystery)
EDIT: Oh, it does, pulled the trigger too earlyā¦
Iāll update later, but so far things have remained available. I stopped HA, deleted the evohome_cc file and my packet logs, then restarted HA and after that itās been stable for several hours. I had tried that process with 0.9.15 too but it made no difference. Iāll monitor for another day or so (or until it fails) and update you then.
Sometimes I find you need to set:
restore_state: false
Restart, then hash it out and save so it restores state the next time. Has resolved a few random issues between upgrades for me before.
To put this into context :
- restore_state is false by default,
- if restore_state is true, during startup it will load the contents of the .storage/evohome_cc file if one is available,
- regardless of the above, it will always overwrite the evohome_cc file with an up-to-date state every sync interval
Iāll PM you a log for the unavailable states. using version 0.10.2
I have the next error:
Logger: ramses_rf.message
Source: /usr/local/lib/python3.8/site-packages/ramses_rf/message.py:714
First occurred: 10:35:03 (3 occurrences)
Last logged: 10:36:04
061 I --- --:------ --:------ 10:078099 1FD4 003 00F077 < AssertionError
058 I --- --:------ --:------ 10:078099 1FD4 003 00F078 < AssertionError
058 I --- --:------ --:------ 10:078099 1FD4 003 00F079 < AssertionError
File "/usr/local/lib/python3.8/site-packages/ramses_rf/message.py", line 706, in process_msg
create_devices(msg) # from pkt header & from msg payload (e.g. 000C)
File "/usr/local/lib/python3.8/site-packages/ramses_rf/message.py", line 545, in create_devices
[this._gwy._get_device(d) for d in (this.src, this.dst)]
File "/usr/local/lib/python3.8/site-packages/ramses_rf/message.py", line 545, in <listcomp>
File "/usr/local/lib/python3.8/site-packages/ramses_rf/__init__.py", line 186, in _get_device
assert dev_addr.type != "--", "invalid device type"
AssertionError: invalid device type
When i donāt add 10:078099 in the allowlist i get the message that he is in the scheme but not in the allow list
Donāt report this as an issue - it is a very simple fix, I will just remove:
I doubt if it will cause you any issues (please let me know if I am wrong).
I noticed that i have 5 orphaned devices at the end of the evohome_cc file.
These 5 devices are in my allow list and are hr92 devices.
1 device from my office that has a fake sensor and 4 in my main zone (living room) where the evohome controller is.
i have already set the parameter restore_state: false to rebuild the evohome_cc file.
this gave a problem with my fake sensor because in the evohome_cc file this was missing in the zone: āis_fakedā: true, after manualy adding it back i could sent a temp update.
the orphans came back after a while.
@TheMystery Please send me a packet log
- from startup, with
- restore_state: false
ā¦ and weāll see whatās going on.
Send you a pm with the packet.log
@TheMystery could you rebind one of the orphans and generate a new schema pls?
At the moment, it looks like your system is simply misconfigured.
But why is the schema good after a fresh reboot? Only after adding the fake is true for the fake sensor and reboot the it Goes wrong.
Send us your evohome_cc section of your configuration.yaml file. Do you have eavesdropping turned on?
evohome_cc:
scan_interval: 300
serial_port: /dev/ttyUSB1
packet_log: /home/homeassistant/packet.log
advanced_override: true
# restore_state: false
config:
max_zones: 6
schema:
controller: 01:155341
allow_list:
- 01:155341
- 04:008512
- 04:070150
- 04:070154
- 04:070160
- 04:073460
- 04:108167
- 04:108169
- 04:108171
- 04:108173
- 13:189740
- 03:256005
@TheMystery Ah, my mistake. I couldnāt have a good look before (was at work), but have done nowā¦
First: having to manually add is_faked
is expected behaviour if you delete the evohome_cc file, or donāt load it - the controller simply does not / cannot know itās faked - this solution is not elegant, but Iāll address that in time.
From what you sent me, this is the packet that exposes the TRVs:
2021-06-22T16:54:14.708696 048 RP --- 01:155341 18:203293 --:------ 000C 024 00000011121000000011A68900000011A68D00000011A68B
It translates into:
16:54:14.708 || CTL:155341 | HGI:203293 | RP | zone_devices | 00000... || {'zone_idx': '00', 'device_class': 'zone_actuators', 'devices': ['04:070160', '04:108169', '04:108173', '04:108171']}
ā¦ or:
"zones": {
"00": {
"heating_type": "radiator_valve",
"sensor": null,
"devices": [
"04:070160",
"04:108169",
"04:108173",
"04:108171"
So we know the controller has this information (i.e. there is no need to re-bind), and that it will provide the answer when asked.
Why it didnāt do it under the circumstances you describe is not clear to me, but - if pushed - Iād say it was simply a dropped packet?
However, if the behaviour is reproducible, then Iād love to know whyā¦
There is no way to tell unless you provide me with a log file that is taken when this behaviour occurs. The best logging config may be:
logger:
default: warn
logs:
homeassistant.core: debug
custom_components.evohome_cc: warn
ramses_rf.transport: info
Can people report any other bugs - all I have so far is from:
@cinnamon:
@TheMystery:
AttributeError: 'NoneType' object has no attribute 'encode'
These have both been fixed and will be āreleasedā soon.
Before I push another release - are there any more?
