Yes I have seen that, but that’s based on internet API and does not support custom thermostats.
I have to inject custom thermostat into Evohome with the HGI80 on the local network. None of the house appliances are allowed to connect to the internet ever so using API’s to clouds is a big no no.
Yeah, so I don’t think the HGI-80 integration is quite where you want it yet. For now it’s just for watching the TRV temps and zones. It can’t set the thermostat. @zxdavb is doing a great job of adding evohome functionality and he expects to have close to the full functionality supported by HGI-80 by next winter (he gives lots of details in the thread above if you want more), but for now the Domoticz integration is ahead of hass on this point.
If you decided you weren’t opposed to the cloud API for now, you could combine your external temperature sensors and the controls for the individual zones into a single climate entity using this I think.
Can’t help you on the firmware issue, it fired right up on my Ubuntu mac mini running hass.io.
evohome_cc, the HA integration that talks to evohome_rf (which itself is the library that picks up the RF packets) does not yet support custom thermostats in the way that Domoticz does.
In fact, evohome_cc is read-only - all it does at present is eavesdrop.
Much functionality is forthcoming (we could, for example, replace the controller altogether), but that will be for next Winter.
That’s alright, I already noticed this integration was quite new and just starting off. Just the fact that this is now being developed for Home Assistant is awesome! I can wait a bit more before finally adding it all to HA.
About the HGI80 firmware part. This is a problem that’s been around for years and nobody seems to post their solutions anywhere, I want to urge anyone to please please post the fix or supply the firmware file somewhere. You will help a lot of other people! For me it happens on a Raspberry Pi 3B+.
Running raspbian on a Pi, unfortunately that command doesn’t work.
Also, the ti_usb_3410 driver was missing at first, fixed that by downloading it and adding to the firmware location.
Then one error remained which is the ti_usb-v10ac-p0102.fw and is nowhere to be found.
The 3410 is loading fine but is only half of the needed firmware.
Thanks for the help, meanwhile I’ve found the culprit!
Excuse the off-topic but I think a lot of people with a Pi will run into this problem as already many have without solutions showing on the internet. If you have a better fix please tell me I’ll update this.
TL:DR: Need correct Texas Instruments firmware, I extracted it from OpenSuSE RPM and everything worked after reboot. “Direct firmware load for ti_usb-v10ac-p0102.fw failed with error -2” error can be ignored.
The problem is a mix of multiple things which threw me off completely.
Problem 1: Missing the ti_usb_3410.fw firmware/driver.
Problem 2: Missing the ti_usb-v10ac-p0102.fw firmware/driver.
Problem 3: Not mounting to /dev/ttyUSBx.
With Problem 1, I thought I solved it by downloading this exact firmware somewhere from the net. Although dmesg did show it was loading the driver and seems to recognize the HGI80, it didn’t bind to /dev/ttyUSB0 for me(Problem 3). At the same time I was getting an error about still missing the ti_usb-v10ac-p0102.fw (Problem 2).
Logically I assumed that Problem 1 was fixed and Problem 2 was causing Problem 3.
After building a custom kernel with the TI USB 3410 driver explicitly in there, I still ran into Problem 2 and Problem 3. However Problem 2 firmware is nowhere to be found on the internet, even Texas Instruments don’t seem to hand it out, I thought it would be unlikely to be an actual problem as surely someone would have a solution.
Back to the drawing board, I assumed my Problem 1 fix was actually not fixed and I extracted ti_3410.fw and ti_5052.fw from an OpenSuSE RPM package and put those in /lib/firmware.
After a reboot, behold, it activated and bound to /dev/ttyUSB0, HGI80 fully functional!
dmesg still complains about Problem 2, but it appears this isn’t a problem at all.
Exactly, still not sure why “apt-get install linux-firmware” didn’t work - it’s explicit purpose is to install all of the firmware files on the url that I linked to previously - Firmware - Debian Wiki - both ti_3410.fw and ti_5052.fw are listed there.
Seems to work for me on all my RPi running various versions or Raspbian!
The project continues to progress - I am now at the stage of trying create / maintain a state database, and I need help: could as many people as possible send me some packet logs to test against
I am particularly interested in hearing from people with unusual configurations - OTB, DHW, UFH, v1 controller, Hometronics, DTS92/92es, External weather sensors, etc…
I need:
24h of packet logs using the fix_state_data branch of evohome_rf
with no configuration changes (no adding / deleting zones, no adding / deleting devices); however, changing setpoints & modes is encouraged
This will be separate from HA, as this branch of evohome_rf (radio frequency) is not compatible with the HA integration, evohome_cc (custom component)
If you are using a nanoCUL instead of a HGI80, please first upgrade to the latest firmware, which is much more reliable now
Kind of. I have climate.rf_zone_0 though 9, though I have 12 zones defined in my thermostat. Also some of the sensors for the TRV’s report their parent zone as null. Others correctly report it.
I’ve been following your work and let me thank you very much for that, it’s really impressive.
I’m planning to buy the nanocul to be able to get all the information in homeassistant, the HGI80 is not easy to find at this point as it was discontinued, apparently.
My setup will be a Raspberry Pi 3 + nanocul running homeassistant, and my honeywell setup (fully wireless) for underfloor heating is the following:
1 EvoHome controller - which controls the whole setup and one zone
2 HCE80+HRA80 units with 3 zones each and each with a round wireless thermometer
2 BDR91, one for the main heating line and other for another zone.
Will this be an interesting setup for you to get packet logs ?
I’m a developer myself, so I can also try to help either by testing and/or getting hands on if needed.
Yes! Let me know when you have the hardware - the nanoCUL is currently unable to send packets, but that will be changing soon, the hardware guys tell me.
I am currently working on probing rather than eavesdropping - this means sending packets to devices to learn about their abilities and configuration. These are RQ packets rather than W (write) packets, so nothing is changed. For example:
The first BDR91 (which has a 3B00 in the payload) is the TPI relay (it turns the boiler on/off), the 2nd is not.
What I’m really wanting is a system with UFH which is not in zone 1 (what I call zone 00), but anyone who is able to set up my code so I can probe their UFH (or OTB) would be grand!
Good. There is an known issue with HA on Rasp Pi & HGI80s wont work with it currently (no way to load the required USB driver).
Make sure you get an 868Mhz version & not a 433MHz version marked at 868.
