Should be fixed now.
Yes…it works now. Thanks for the quick fix
Hats off to you @Bram_Kratgen for taking this on and adding this component to HA.
I would very much like to integrate my Lyric T5 into HA.
I have followed the instructions above and have placed the files in \custom_components and \climate and added lyric component to configuration.yaml
with my key and secret.
Running HA 59.1
Set up a developer acct with url: http://my.local.ha.ip:8123/api/lyric/authenticate
Unfortunately, HA is having trouble activating the component.
I have included debug output below. I am hoping you or others can help explain this error (OAith2Session import error?) to me and help me remedy it.Thanks in advance.
Logging mode set to debug.
2017-12-04 15:26:28 ERROR (MainThread) [homeassistant.setup] Error during setup of component lyric
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/setup.py", line 193, in _async_setup_component
component.setup, hass, processed_config)
File "/usr/lib/python3.5/asyncio/futures.py", line 380, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.5/asyncio/tasks.py", line 304, in _wakeup
future.result()
File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
raise self._exception
File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run
File "/home/homeassistant/.homeassistant/custom_components/lyric.py", line 116, in setup
import lyric
File "/srv/homeassistant/lib/python3.5/site-packages/lyric/__init__.py", line 6, in <module>
from requests_oauthlib import OAuth2Session
File "/srv/homeassistant/lib/python3.5/site-packages/requests_oauthlib/__init__.py", line 9, in <module>
if requests.__version__ < '2.0.0':
TypeError: unorderable types: module() < str()
My work around until OAuth2Session requests.version TypeError gets fixed,is commenting out lines 9-12 in
. Lyric component seems to be running great now.
Bram_Kragten, you are the man. I’ve got the T5 working and reporting perfectly. Thank you so much. I wouldn’t have gotten it working if you hadn’t taken the time to help other people who asked questions that I had.
I had the same oauth errors and the edit worked. I was able to configure the thermostat but the Lyric device no longer appears in the UI. Did you need to do anything else to get this working again?
Hi Bram! I have Hassbian installed on my RPi and thus I do not see the components folder in /home/homeassistant/.homeassistant. I tried to manually create a components folder and checked the config file but it said ‘component lyric not found’. Any idea what I’m doing wrong? Thanks in advance!
I have upgraded to HA version 0.60.0 and have also lost Lyric in my UI: I deleted lyric.conf and made the connection to Honeywell with no issues but still did not see Lyric in the UI. I think it is time to stop upgrading HA!! Since the last 2 updates I have lost my Amcrest Cameras and my T5 thermostat. What good do updates do if everything else keeps breaking. I am including my HA log if that will help.
2017-12-23 08:09:05 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File “/usr/lib/python3.5/asyncio/tasks.py”, line 241, in _step
result = coro.throw(exc)
File “/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/homeassistant/components/device_tracker/init.py”, line 332, in async_update_config
dev_id, device)
File “/usr/lib/python3.5/asyncio/futures.py”, line 380, in iter
File “/usr/lib/python3.5/asyncio/tasks.py”, line 304, in _wakeup
future.result()
File “/usr/lib/python3.5/asyncio/futures.py”, line 293, in result
File “/usr/lib/python3.5/concurrent/futures/thread.py”, line 55, in run
File “/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/homeassistant/components/device_tracker/init.py”, line 740, in update_config
with open(path, ‘a’) as out:
PermissionError: [Errno 13] Permission denied: ‘/home/homeassistant/.homeassistant/known_devices.yaml’
2017-12-23 08:10:02 ERROR (Thread-18) [homeassistant.components.lyric] Connection error logging into the Lyric web service.
2017-12-23 08:10:02 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File “/usr/lib/python3.5/asyncio/tasks.py”, line 239, in _step
result = coro.send(None)
File “/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/homeassistant/helpers/entity_component.py”, line 399, in async_process_entity
new_entity, self, update_before_add=update_before_add
File “/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/homeassistant/helpers/entity_component.py”, line 247, in async_add_entity
yield from entity.async_update_ha_state()
File “/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/homeassistant/helpers/entity.py”, line 231, in async_update_ha_state
attr)
File “/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/homeassistant/helpers/entity.py”, line 333, in _attr_setter
value = getattr(self, name)
File “/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/homeassistant/components/climate/init.py”, line 736, in supported_features
raise NotImplementedError()
NotImplementedError
Just a update. Moved back to 0.58.1 and everything is working great!! Thanks for all of you work!!
This issue is already fixed. Just scroll up a few posts please.
Thanks it works!! Sorry I jumped to conclusions. Seems like every time I do a update something breaks.
This has been 100% flawless for me for months, plus this thread has gotten relatively quiet. When might this component get pushed to the main tree? I suspect it is as well tested as it’s gonna get with this sub-selection of the community testing it.
@Bram_Kragten I will be visiting the Honeywell plant where I think these thermostats are developed. I am being interviewed in connection with the app and would like to show them your component if that is OK.
Hey,
I’ve got a problem. I installed and configured the lyric component. It reads out the current temperature and the desired heating temperature.
But I can’t set a different temperature. It keeps giving me this error:
`HTTP Error Lyric API: 400 Client Error: User Input Error for url: https://api.honeywell.com/v2/devices/thermostats/LCC-00D02DB7AE7E?locationId=456812&apikey=xxx`
What am I missing?
Setup was very easy and it is working great except for a couple of things that may be Lyric related. I have the lyric round.
I notice the operation_mode is showing heat or cool when the thermostat is set to auto mode. Is it possible to report back auto-heat or auto-cool, or something similar to indicate the difference between auto and manual modes?
My other issue is that if someone manually changes the thermostat it takes a long time for the temperature attribute to update in HA. Is there a way to increase the poll rate?
A little background on what I am doing:
I have 2 automations setup to make a custom slider work. One triggers if you adjust the slider in HA and sets the temperature attribute. The other triggers when the temperature attribute changes value and sets the slider value.
I am still working on setting the value of the slider to the current thermostat value on HA startup.
Yeah sure
Can you share your logs when you put the climate.lyric on debug?
You should create a custom_components
folder.
Honeywell has a limit on the polling:
By default, it is now set a scan interval of 270s (4,5 minutes)
you can change this if you want:
lyric:
client_id: hwkehkjwekhkwjehkhjwe
client_secret: jkwhekjwhekjhkw
scan_interval: 60
If you change something through the component the cache is busted, so then it will change immediately.
I will see if I can add this.
I will try to find time to create an official PR early next year, sorry for the delay. Busy, busy, busy!
