Thats weird, just deleted all my pycache folders, are you on hassio? Will do a host reboot to see if that fixes it. Thanks for the help so far.
Itâs working fine for me.
I used the files posted in this repo:
https://github.com/teunehv/ha-custom-components/tree/master/lyric
Iâm on hassio as well, 0.89.0 atm.
If itâs still not working try removing lyric folder completely and put the repo back in again.
Could you share your configuration.yaml lyric entry?
Didnât change it ever. Since it was working for you before that canât be the issue. Same error still?
Youâre right⌠just was in doubt where to put it, under climate: or just lyric:
Fresh clone of your repo
Unable to prepare setup for platform lyric.climate: Could not set up all dependencies.
Unable to set up dependencies of lyric.climate. Setup failed for dependencies: lyric
Also still a:
2019-03-09 00:09:03 ERROR (MainThread) [homeassistant.setup] Error during setup of component lyric
File "/usr/local/lib/python3.7/site-packages/homeassistant/setup.py", line 154, in _async_setup_component
component.setup, hass, processed_config) # type: ignore
File "/config/custom_components/lyric/__init__.py", line 116, in setup
import lyric
File "/config/lyric.py", line 17, in
from homeassistant.components.climate import (
ImportError: cannot import name 'STATE_AUTO' from 'homeassistant.components.climate' (/usr/local/lib/python3.7/site-packages/homeassistant/components/climate/__init__.py)
Still seems an old version⌠No clue why
I had my old file in my /config dir as a backupish idea.
see log above
"/config/lyric.py"
Taking it out of there solved it, but exposes climate.liric for some reason⌠weird weird weird.
It works now. Thanks for the help!
Good to hear itâs working now.
Still not working for me my files are located here
/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/homeassistant/components . I replace them with the new ones and HA would not load. After I replaced them with the originals HA came backup but the Honeywell Lyric still did not appear. After I went back to 0.88.2 everything is working again. This is the only thing in the home-assistant.log that seems to be related.
2019-03-09 14:43:33 ERROR (MainThread) [homeassistant.loader] Error loading homeassistant.components.lyric.climate. Make sure all dependencies are installed
File â/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/homeassistant/loader.pyâ, line 147, in _load_file
module = importlib.import_module(path)
File â/srv/homeassistant/homeassistant_venv/lib/python3.5/importlib/init.pyâ, line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
After hours of messing with different setups. i was about to start configuring but right after i select my thermostat on honeywell is gives me
This site canât be reached
192.168.1.185 refused to connect.
- Search Google for [192 168 185 8123 api lyric authenticate]
ERR_CONNECTION_REFUSED
The only error i see in HA is
Log Details (ERROR)
Sat Mar 09 2019 21:33:30 GMT-0600 (Central Standard Time)
Unable to update from sensor: could not convert string to float: âNoneâ
Just to be sure, did you place the files in the components folder? It should be in the custom_components folder which should be present as a subfolder at the location were your configuration.yaml is stored.
Seems to me like you have some config error. I just updated the complete step by step and put it in the repo as well. Perhaps you can check if you did everything ok. See particular Part 1, step 4 and Part 3.
I woke up with fresh eyes and immediately realized i was using the wrong instance of my Home Assistant. so annoyed with myself
lesson is donât mess with this stuff if you have been up for 24 hours
Thanks for the replyâs
I tried everything you suggested but nothing works on HA 0.89.0. There seems to be no reference to the lyric.py files where do they go?
I have the files in my homeassistant directory under:
./custom_components/lyric/init.py
./custom_components/lyric/climate.py
I have 2 lyric.py files
one in components and one in components/climate. Does climate.py replace the lyric.py in components/climate?
make a âlyricâ folder under âcustom_componentsâ folder
The lyric.py that was in the custom_components folder move to custom_components/lyric and rename it to __init__.py
Move the âlyric.pyâ that was under âcustom_components/climateâ to âcustom_components/lyricâ and rename it to âclimate.pyâ
Also after i updated to 0.89.1 I had to change the climate,py file because of some const changes in the update.
Before:
ATTR_TARGET_TEMP_HIGH, ATTR_TARGET_TEMP_LOW, DOMAIN,
ClimateDevice, PLATFORM_SCHEMA, STATE_AUTO,
STATE_COOL, STATE_HEAT, SUPPORT_TARGET_TEMPERATURE,
SUPPORT_TARGET_TEMPERATURE_HIGH, SUPPORT_TARGET_TEMPERATURE_LOW,
SUPPORT_OPERATION_MODE, SUPPORT_AWAY_MODE, SUPPORT_FAN_MODE)
After:
from homeassistant.components.climate import ClimateDevice, PLATFORM_SCHEMA
from homeassistant.components.climate.const import (
STATE_AUTO, STATE_COOL, STATE_HEAT, SUPPORT_TARGET_TEMPERATURE,
See following
This repo contains the files and the location that is needed. Including the step-by-step description.
It shouldnât be components, but custom_components. And the structure of custom components will change in the future. Since 0.88 warnings show up in the logs about the future change. If you make sure the files are present as in the repo you have the correct files/config:
<home-assistant-config-folder>/custom_components/lyric/__init__.py
<home-assistant-config-folder>/custom_components/lyric/climate.py
<home-assistant-config-folder>/custom_components/lyric/services.yaml
I tried but getting the following message:
500 Internal Server Error
Server got itself in trouble
