should be:
config/custom_components/lyric/init.py
config/custom_components/lyric/climate.py
Thank you druknmonkey ,
So I presume that the post of Bram_kragten on Jan â17 is not the correct place to start.
Can you tell me where in this topic I should start reading to set this up working?
So I had to change my thermostat from a honeywell TCC ( which integrated well) to a lyric-based T6-wifi pro. I have been trying to add this to my custom_components and I get Configuration invalid CHECK CONFIG
Integration not found: lyric
I am on ver 0.94.2
I have custom_components/lyric folder structure in my config folder.
I downloaded the files located here and placed them in custom_components/lyric/ and have restarted homeassistant multiple times and cannot get it to find/load the lyric integration. I am running hassio on a pi3.
I find this line in the log file,
ERROR (MainThread) [homeassistant.setup] Setup failed for lyric: Integration not found.
For the life of me, I cannot get it to see the new integration. I feel as though there is something missing from my setup, but I am not finding it.
In my configuration.yaml I have
http:
base_url: http://100.75.1.22:8123/
and
lyric:
client_id: redacted
client_secret: redacted
At this time I am abandoning this approach to integrating my honeywell T6 wifi pro. I have successfully implemented the thermostat using the HomeKit controller support. The only issue I had with this integration is you must have the pairing code off of the box the thermostat comes in and I am 900 miles away. Fortunately, I was able to contact my installer who found the code for me.
Has anyone had any success getting this to work with the new HACS (home assistant community store) component? I had it all working great for last several months while running hassio 92.? and custom_components. Then i had to do a fresh hassio install due to another issue and upgraded to 0.94.4 and installed the HACS component and installed lyric from there. Every thing went really smooth it installed and rebooted and got the authenticate alert. But this is where the problem started, when i click âconfigureâ then âRequest Authorizationâ the login page for Honeywell pops up and i login then it finds my thermostat, i select it then click âconnectâ and i get an error stating â500 Internal Server Errorâ . I have tried several times with the same result, i have updated my ip on honeywells site and even added this to my config.
http: base_url: http://192.168.1.111:8123
All with no joy.
Any ideas would be greatly appreciated!!!
Update:
I just noticed this in the hassio log , not sure what it means though.
Error handling request
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_protocol.py", line 418, in start
resp = await task
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_app.py", line 458, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_middlewares.py", line 119, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/real_ip.py", line 33, in real_ip_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 67, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 216, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 115, in handle
result = await result
File "/usr/local/lib/python3.7/asyncio/coroutines.py", line 120, in coro
res = func(*args, **kw)
File "/config/custom_components/lyric/__init__.py", line 199, in get
data = request.GET
AttributeError: 'Request' object has no attribute 'GET'
Update:
I got it working! Not sure what exactly fixed it but i had a backup of my previous âlyricâ folder from custom_updater so just for giggles i swapped the entire lyric folder out with my old one from before i installed HACS and whala it finished the auth process and is working great. So maybe the "Lyric " folder that is being installed with the plugin from HACS has a problem or maybe it was something i did but i did swap them back and it would not work so i am not sure what the difference is but it works fine with my old âlyricâ folder.
I been getting the same problem. I like the âstatâ and i really think it should work with HASSIO
Update: I never was able to get the lyric integration used with the old Honeywell 'stat but the Homekit controller support has been working fine EXCEPT there seems to be no support to show the fan status. There is support for the current operating mode, (Cool, Heat, Idle) but nothing to indicate the current status of fan-only operations.
Donât I need a Mac for Homekit?
I donât think you need the Apple Homekit, I think the plugin emulates it, but I know when I tired this way I didnât have luck.
Since itâs summer probably not a lot of people monitoring this thread right now. I know Iâve had my Lyric off since early May so have needed to us HA with it right now as I donât use it for AC.
latest updates to the Climate component(s) breaks the current version of Lyric, FYI. Wait to update if you rely on this custom component.
Are you saying 0.96.1 breaks it?
Are you looking into it? Or can you post the error log?
Just tried upgrading saw this in the error log
> 2019-07-19 18:53:24 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform lyric.climate: Platform not found (cannot import name 'STATE_AUTO' from 'homeassistant.components.climate.const' (/usr/src/homeassistant/homeassistant/components/climate/const.py)).
Thatâs correct.
âClimate 1.0â is a major effort to to redesign the climate component (all climate platforms are based on this âparentâ component). Several things have changed including the names of various constants. STATE_AUTO
was a constant in the previous version of the climate component but no longer in the new one.
List of climate component constants.
This Honeywell Lyric component will require revision to have it meet the new standards set by the âClimate 1.0â initiative.
Darn, just finished the 0.96.1 update and saw this, guess Iâll be reverting to a snapshot. Hopefully @teunehv can make some changes to support the new climate structure.
Since it seems to me like a big change Iâm not sure if I can fix it since Iâm not that experienced in programming.
The full pull request of the change in. 96 is here:
https://github.com/home-assistant/home-assistant/pull/23899
I hope to find some time during the weekend to look into it. But all help is appreciated.
Edit: based on a first analyse I think itâs fixable by replacing all removed contants by the new ones. Will check this weekend when Iâm near my computer.
I canât say I have a complete understanding of all the changes but Iâll share what I do know:
There is now a clear separation between the operation mode (the task it will perform: auto, heat, cool, off, etc) and the operating state (the task it is actively performing: heating, cooling, idle). The componentâs state
continues to represent the operation mode but now it has a new attribute to represent its operating state. The History Chart used to graph the climate componentâs state
but now it graphs the new attribute. That means the shaded area on the graph will correctly indicate when the HVAC system is actually heating or cooling.
To support this new ability (distinguishing between operation mode and operating state), several constants have been removed and replaced by new ones.
The ability to hold a temperature has been incorporated into a broader concept known as âpresetsâ. Presets can be as simple as âholdâ (meaning to ignore the schedule and hold this temperature indefinitely) to more complex situations like âawayâ, âvacationâ, etc. There is now a new service call set_preset_mode
which replaces previous ones like set _away_mode
Too bad, itâs more then just replacing the constants. Got locally another message now about not implemented hvac_mode. Hope to find time for further analyse, but as mentioned Iâm not a programmer so itâs all just trial and error.
Update July 22:
got rid of a lot of different errors with help from other climate related forum posts. But itâs not working yet. Will continue tomorrow with the hope it will be fixed then.
Good news, Iâve got the custom component up-and-running again. See the repo for the updated climate.py
Two notes:
- I saw already an error in one of my automations. The operation mode is replaced by hvac mode. So perhaps updates on automations is needed int this case.
- I didnât had time to test the changes. I didnât change functionality as far as Iâm aware, but I canât oversee all consequences of the update. If you experience problems please post them here so we are al aware.
