I would remove the node and re-add it. Make sure you don’t have a custom version of the config files installed.
Unfortunately, I’ve removed the node and re-added, using standard zwcfg, still unable to read or write Heat Setpoint.
Can you post the entry in zwcfg*.xml?
Running HA Version 0.103.2, here’s the list of entities created by HA and the zwave config entry
I’ve removed and re-added the device multiple times.
<Node id="14" name="" location="" basic="4" generic="8" specific="6" roletype="7" devicetype="4610" nodetype="0" type="General Thermostat V2" listening="false" frequentListening="true" beaming="true" routing="true" max_baud_rate="40000" version="4" query_stage="Complete">
<Manufacturer id="39" name="Honeywell">
<Product type="11" id="8" name="Unknown: type=0011, id=0008" />
</Manufacturer>
<CommandClasses>
<CommandClass id="32" name="COMMAND_CLASS_BASIC" version="1" request_flags="4" mapping="64">
<Instance index="1" />
</CommandClass>
<CommandClass id="49" name="COMMAND_CLASS_SENSOR_MULTILEVEL" version="5" innif="true">
<Value type="decimal" genre="user" instance="1" index="1" label="Temperature" units="C" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="23.8" />
<Value type="decimal" genre="user" instance="1" index="5" label="Relative Humidity" units="%" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="34.0" />
</CommandClass>
<CommandClass id="64" name="COMMAND_CLASS_THERMOSTAT_MODE" version="1" request_flags="4" innif="true">
<Value type="list" genre="user" instance="1" index="0" label="Mode" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="1" size="1">
<Item label="Off" value="0" />
<Item label="Heat" value="1" />
<Item label="Cool" value="2" />
<Item label="Heat Econ" value="11" />
<Item label="Cool Econ" value="12" />
</Value>
<SupportedModes>
<Mode index="0" label="Off" />
<Mode index="1" label="Heat" />
<Mode index="2" label="Cool" />
<Mode index="11" label="Heat Econ" />
<Mode index="12" label="Cool Econ" />
</SupportedModes>
</CommandClass>
<CommandClass id="66" name="COMMAND_CLASS_THERMOSTAT_OPERATING_STATE" version="1" request_flags="4" innif="true">
<Value type="string" genre="user" instance="1" index="0" label="Operating State" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="Heating" />
</CommandClass>
<CommandClass id="67" name="COMMAND_CLASS_THERMOSTAT_SETPOINT" version="1" request_flags="4" innif="true" base="1" typeInterpretation="B">
<Value type="decimal" genre="user" instance="1" index="2" label="Cooling 1" units="C" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="26.0" />
<Value type="decimal" genre="user" instance="1" index="3" label="Unused 3" units="C" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0.0" />
<Value type="decimal" genre="user" instance="1" index="8" label="Dry Air" units="C" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0.0" />
<Value type="decimal" genre="user" instance="1" index="9" label="Moist Air" units="C" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0.0" />
</CommandClass>
<CommandClass id="68" name="COMMAND_CLASS_THERMOSTAT_FAN_MODE" version="1" request_flags="4" innif="true">
<Value type="list" genre="user" instance="1" index="0" label="Fan Mode" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="2" size="1">
<Item label="Auto Low" value="0" />
<Item label="On Low" value="1" />
<Item label="Circulate" value="6" />
</Value>
<SupportedModes>
<Mode index="0" label="Auto Low" />
<Mode index="1" label="On Low" />
<Mode index="6" label="Circulate" />
</SupportedModes>
</CommandClass>
<CommandClass id="69" name="COMMAND_CLASS_THERMOSTAT_FAN_STATE" version="1" request_flags="4" innif="true">
<Value type="string" genre="user" instance="1" index="0" label="Fan State" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="Running" />
</CommandClass>
<CommandClass id="90" name="COMMAND_CLASS_DEVICE_RESET_LOCALLY" version="1" request_flags="4" innif="true">
</CommandClass>
<CommandClass id="94" name="COMMAND_CLASS_ZWAVEPLUS_INFO" version="1" request_flags="4" innif="true">
<Value type="byte" genre="system" instance="1" index="0" label="ZWave+ Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="1" />
<Value type="short" genre="system" instance="1" index="1" label="InstallerIcon" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="4610" />
<Value type="short" genre="system" instance="1" index="2" label="UserIcon" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="4610" />
</CommandClass>
<CommandClass id="112" name="COMMAND_CLASS_CONFIGURATION" version="1" request_flags="4" innif="true">
</CommandClass>
<CommandClass id="113" name="COMMAND_CLASS_ALARM" version="3" request_flags="2" innif="true">
<Value type="byte" genre="user" instance="1" index="0" label="Alarm Type" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
<Value type="byte" genre="user" instance="1" index="1" label="Alarm Level" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
<Value type="byte" genre="user" instance="1" index="2" label="SourceNodeId" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
<Value type="byte" genre="user" instance="1" index="11" label="Power Management" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="254" />
</CommandClass>
<CommandClass id="114" name="COMMAND_CLASS_MANUFACTURER_SPECIFIC" version="1" request_flags="4" innif="true">
</CommandClass>
<CommandClass id="115" name="COMMAND_CLASS_POWERLEVEL" version="1" request_flags="4" innif="true">
<Value type="list" genre="system" instance="1" index="0" label="Powerlevel" units="dB" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
<Item label="Normal" value="0" />
<Item label="-1dB" value="1" />
<Item label="-2dB" value="2" />
<Item label="-3dB" value="3" />
<Item label="-4dB" value="4" />
<Item label="-5dB" value="5" />
<Item label="-6dB" value="6" />
<Item label="-7dB" value="7" />
<Item label="-8dB" value="8" />
<Item label="-9dB" value="9" />
</Value>
<Value type="byte" genre="system" instance="1" index="1" label="Timeout" units="seconds" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
<Value type="button" genre="system" instance="1" index="2" label="Set Powerlevel" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
<Value type="byte" genre="system" instance="1" index="3" label="Test Node" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
<Value type="list" genre="system" instance="1" index="4" label="Test Powerlevel" units="dB" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
</Value>
<Value type="short" genre="system" instance="1" index="5" label="Frame Count" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="0" />
<Value type="button" genre="system" instance="1" index="6" label="Test" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
<Value type="button" genre="system" instance="1" index="7" label="Report" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
<Value type="list" genre="system" instance="1" index="8" label="Test Status" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
<Item label="Failed" value="0" />
<Item label="Success" value="1" />
<Item label="In Progress" value="2" />
</Value>
<Value type="short" genre="system" instance="1" index="9" label="Acked Frames" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="0" />
</CommandClass>
<CommandClass id="128" name="COMMAND_CLASS_BATTERY" version="1" request_flags="4" innif="true">
<Value type="byte" genre="user" instance="1" index="0" label="Battery Level" units="%" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="55" />
</CommandClass>
<CommandClass id="129" name="COMMAND_CLASS_CLOCK" version="1" request_flags="4" innif="true">
<Value type="list" genre="user" instance="1" index="0" label="Day" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="3" size="1">
<Item label="Monday" value="1" />
<Item label="Tuesday" value="2" />
<Item label="Wednesday" value="3" />
<Item label="Thursday" value="4" />
<Item label="Friday" value="5" />
<Item label="Saturday" value="6" />
<Item label="Sunday" value="7" />
</Value>
<Value type="byte" genre="user" instance="1" index="1" label="Hour" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="12" />
<Value type="byte" genre="user" instance="1" index="2" label="Minute" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="8" />
</CommandClass>
<CommandClass id="133" name="COMMAND_CLASS_ASSOCIATION" version="1" request_flags="4" innif="true">
<Associations num_groups="1">
<Group index="1" max_associations="1" label="Group 1" auto="true">
<Node id="1" />
</Group>
</Associations>
</CommandClass>
<CommandClass id="134" name="COMMAND_CLASS_VERSION" version="1" request_flags="4" innif="true">
<Value type="string" genre="system" instance="1" index="0" label="Library Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="6" />
<Value type="string" genre="system" instance="1" index="1" label="Protocol Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="4.61" />
<Value type="string" genre="system" instance="1" index="2" label="Application Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="1.03" />
</CommandClass>
</CommandClasses>
</Node>
In your case, honeywell_unknown_type_0011_id_0008
shows that you aren’t using the HA provided config files. In 0.103.0 the T6 thermostat config file was added to the HA fork of OZW. The config file for the T6 has a setting the affect the setpoints.
Make sure you don’t have config_path
configured in your configuration.yaml. Also make sure that you don’t have any other config files installed. If using Docker or Hass.io, that shouldn’t be the case, but if you are using a venv it’s possible if you’ve installed system packages.
The easiest way after that is settled is to just Remove the node and Add it again. You can also remove entities and delete the thermostat entry from zwcfg*.xml if you want to do that.
@freshcoast thanks for the help! Tried to remove node , deleted entity, and made sure removed from zwcfg, still not working.
Would manually updating in zwcfg settings correct? If so, what is the appropriate zwcfg entry for this?
Try
<Value type="decimal" genre="user" instance="1" index="1" label="Heating 1" units="C" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="26.0" />
</CommandClass>
That’s interesting because I am using the default configs from HA in docker. I don’t have config_path
in my configuration.yaml
I’ll try the remove node, then I’ll clean out the .xml file since that’s basically the only thing I haven’t tried when removing and re-adding the node.
This appears at first glance to have worked. But I did have to follow adjust the xml a little to reflect the changes here in order to allow decimal setpoints for this thermostat:
Also, now the set point disappears if I put the thermostat into “Away” or “Heat Econ” mode. Which honestly is pretty trivial at this point.
Not sure why it would disappear the set point for away mode but it’s interesting nonetheless.
From what I understand “Away Mode” should be a preset in the Climate 1.0 changes therefor whatever setpoint mode you have it set to Heat or Cool changing to “Away” preset should just adjust the setpoint kind of like a scene.
Either way, it’s working better than it was so thank you! I can now set the heat/cool temperature from the couch!
I’ll take that as a win!
Thank you for the help! After reviewing what you sent, it all make sense now!
Original zwcfg entry for Setpoint:
<CommandClass id="67" name="COMMAND_CLASS_THERMOSTAT_SETPOINT" version="2" request_flags="2" innif="true" base="1" typeInterpretation="B">
<Value type="decimal" genre="user" instance="1" index="2" label="Cooling 1" units="F" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="65.0" />
</CommandClass>
Appears that it was missing the Heating feature for Set Point.
Added:
<Value type="decimal" genre="user" instance="1" index="1" label="Heating 1" units="F" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="65.0" />
And now the updated zwcfg with Heating and confirmed working!
</CommandClass>
Hello All,
Know this is an old thread but hopefully someone sees this Post,
i am using the same thermostat… just migrated over from ST… Painful but well worth it.
i have tried a few recommendations in this thread but for the likes of me i cannot get control of the thermostat. please seepic im at odds how to get it t show the correct set points let alone set them.
any assistance is appreciated.
Are you using the old Zwave integration? ZwaveJS2MQTT has worked very well for me for a while now.
Hello thank you for the prompt reply.
Yes I am using the old c-wave integration Z-Wave beta.
I just finished setting it all up and having it running. I was looking at the conversion from Z-Wave beta to Z-Wave js… I just don’t have the amount of time it takes to convert all that over at the moment.
Sorry, but I don’t have experience with the Zwave beta (which should be OpenZWave 1.6 if I’m not mistaken). I had issues with the now deprecated version of OpenZwave 1.4, to which I needed to add certain lines to make it work.
I don’t know about 1.6 but 1.4 creates a xml file in the root directory of the Home Assistant config folder. If you could post the device xml file, that might help in diagnosing. Just post the section for the thermostat, that all we would need for now.
Hello
walrus_parka.
thanks again for your assistance.
in /config directory the only zwave config xml file present has the information as follows:
no mention of the thermostat.
<?xml version="1.0" encoding="utf-8" ?>
<Driver xmlns="http://code.google.com/p/open-zwave/" version="3" home_id=********** node_id="1" api_capabilities="0" controller_capabilities="40" poll_interval="60000" poll_interval_between="true">
<Node id="1" name="" location="" basic="2" generic="2" specific="1" type="Static PC Controller" listening="true" frequentListening="false" beaming="true" routing="true" max_baud_rate="40000" version="4" query_stage="Complete">
<Manufacturer id="0" name="Z-Wave (Sigma Designs)">
<Product type="1" id="1" name="UZB Z-Wave USB Adapter" />
</Manufacturer>
<CommandClasses>
<CommandClass id="32" name="COMMAND_CLASS_BASIC" version="1" after_mark="true">
<Value type="byte" genre="basic" instance="1" index="0" label="Basic" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
</CommandClass>
</CommandClasses>
</Node>
</Driver>
I second this. This thermostat works flawlessly with zwavejs2mqtt. My whole zwave network is much more responsive than with either of the older integrations.
So coming in from samsung ST to HA all my Z-Wave devices ran very responsive some even less than a second.
And you are saying that Z-Wave Js is even snapper…Now your just bragging…and it’s causing me to want to jump ship to Z-Wave Js.
Your card has the option to enable auto mode! I can’t get that to show up for the life of me, despite enabling auto change over mode via Z-Wave configuration. Any idea how you got that option to be available?
