Hello i have this plugin and i want a automation that a switch turns on the lowest price en turn of after a few hours.
Is it posibble to do this in the UI?
FYI, we are currently working on a solution to request hourly price data via a service call in the core integration, so that you have the option to put this in a template sensor. This makes it possible to map all prices into a nice Apexchart again
Can you share your card config?
I like the coloring and the min and max value
(is ‘now’ label running correct? mine looks a bit weird when it is a little later than a half hour past the hour running in (than it is already in the next bar))
@ceriel , I’m not familiar with this yet, and quite new to home assistant.
I have installed grafana, influxdb, node-red.
In node-red I used your query, which created a nice flow.
Not sure how to add data to influxdb, and where to put the query you used. (because it get’s red lines in configuration.yaml)
Can you help me out?
Yes please
Hey hello can you share this code. i think node red would be to difficult for me. do you or anybody else has the latest one. i tried few of those here with no luck.
