I wanted to do this in NodeRed hooked into HA rather than using the HA scrape - just for the hell of it really, I use NodeRed hooked into HA via the NR companion (home-assistant-websocket) but sure people can adjust accordingly.
Here is the flow - the URL is coded into the triggers (I’ve mangled my location - but left the long lat in the URL so it’s obvious where it goes) - just thought may be useful if anyone stumbles on this thread in the future.
[{"id":"71c2975b48b5dda9","type":"inject","z":"babcd6f0d89239b1","name":"AstroData Trigger","props":[{"p":"url","v":"https://www.timeanddate.com/astronomy/@50.0000000,-0.8000000","vt":"str"},{"p":"timestamp","v":"","vt":"date"}],"repeat":"","crontab":"00 01 * * *","once":false,"onceDelay":0.1,"topic":"","x":130,"y":260,"wires":[["397d944e8e0e381a"]]},{"id":"397d944e8e0e381a","type":"http request","z":"babcd6f0d89239b1","name":"Get Page","method":"GET","ret":"txt","paytoqs":"ignore","url":"","tls":"","persist":false,"proxy":"","authType":"","senderr":false,"x":180,"y":200,"wires":[["86ff838afb194ddf","02e8d453e2f9f0f1"]]},{"id":"02e8d453e2f9f0f1","type":"html","z":"babcd6f0d89239b1","name":"Daylight Times","property":"payload","outproperty":"payload","tag":"table[id=lm-key]>tbody>tr[id=lm-leg-4]","ret":"html","as":"single","x":400,"y":200,"wires":[["fc056fb3333bd74f"]]},{"id":"fc056fb3333bd74f","type":"function","z":"babcd6f0d89239b1","name":"Handle String","func":"function extract_target(s) {\n let r = {};\n const extRegexp = /(\\d\\d:\\d\\d)/g;\n const m = [...s.matchAll(extRegexp)];\n\n if (m.length) {\n r['start'] = m[0][1];\n r['end'] = m[1][1];\n }\n return r;\n}\n\nmsg.payload = extract_target(msg.payload[0]);\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":640,"y":200,"wires":[["3b583fb66759cb20"]]},{"id":"86ff838afb194ddf","type":"html","z":"babcd6f0d89239b1","name":"Daylight Length","property":"payload","outproperty":"payload","tag":"div[id=cs-dl]","ret":"html","as":"single","x":400,"y":240,"wires":[["9a2d6c8687b13174"]]},{"id":"9a2d6c8687b13174","type":"function","z":"babcd6f0d89239b1","name":"Handle String","func":"function extract_target(s) {\n let r = {};\n const extRegexp = /<span id=\"cs-daylength\">([^\\(]+)\\(.*?<p>([^\\(]+)/g;\n const m = [...s.matchAll(extRegexp)][0].map( e => e.trim() );\n const t = m.shift();\n let H = 0;\n let M = 0;\n let S = 0;\n \n if (m.length == 2) {\n if (/\\d+h/.test(m[0])) {\n H = /(\\d+)h/.exec(m[0])[1];\n }\n if (/\\d+m/.test(m[0])) {\n M = /(\\d+)m/.exec(m[0])[1];\n }\n if (/\\d+s/.test(m[0])) {\n S = /(\\d+)s/.exec(m[0])[1];\n }\n r['duration'] = (parseInt(H)*60*60 + parseInt(M)*60 + parseInt(S));\n r['human_length'] = m[0];\n r['human_delta'] = m[1];\n }\n return r;\n}\n\nmsg.payload = extract_target(msg.payload[0]);\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":640,"y":240,"wires":[["3b583fb66759cb20"]]},{"id":"3b583fb66759cb20","type":"merge","z":"babcd6f0d89239b1","name":"","timeout":"","x":830,"y":220,"wires":[["d46b3948f9bb5704"]]},{"id":"d46b3948f9bb5704","type":"function","z":"babcd6f0d89239b1","name":"Blend","func":"let np = {};\nfor (let ml1 in msg.payload) {\n for (let ml2 in msg.payload[ml1].payload) {\n np[ml2] = (msg.payload[ml1].payload[ml2]);\n }\n}\n\n// Preserve some values\nmsg['timestamp'] = msg.payload[0].timestamp;\nmsg['url'] = msg.payload[0].url;\nmsg['statusCode'] = msg.payload[0].statusCode;\n\nmsg.payload = np;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":970,"y":220,"wires":[["41cfaa3b97ad3766"]]},{"id":"41cfaa3b97ad3766","type":"ha-entity","z":"babcd6f0d89239b1","name":"AstroData Daylight","server":"2d3371bf08f58b58","version":2,"debugenabled":false,"outputs":1,"entityType":"sensor","config":[{"property":"name","value":"AstroData Daylight"},{"property":"device_class","value":"sensor"},{"property":"icon","value":"mdi:sun-clock"},{"property":"unit_of_measurement","value":"seconds"},{"property":"state_class","value":"total"},{"property":"last_reset","value":""}],"state":"payload.duration","stateType":"msg","attributes":[{"property":"start_daylight","value":"payload.start","valueType":"msg"},{"property":"end_daylight","value":"payload.end","valueType":"msg"},{"property":"text_daylight_length","value":"payload.human_length","valueType":"msg"},{"property":"text_daylight_delta","value":"payload.human_delta","valueType":"msg"},{"property":"updated","value":"timestamp","valueType":"msg"},{"property":"url","value":"url","valueType":"msg"},{"property":"statusCode","value":"statusCode","valueType":"msg"}],"resend":true,"outputLocation":"payload","outputLocationType":"none","inputOverride":"allow","outputOnStateChange":false,"outputPayload":"","outputPayloadType":"str","x":1170,"y":220,"wires":[[]]},{"id":"3b428d8ac24a63d7","type":"inject","z":"babcd6f0d89239b1","name":"AstroData Trigger","props":[{"p":"url","v":"https://www.timeanddate.com/astronomy/@50.0000000,-0.8000000","vt":"str"},{"p":"timestamp","v":"","vt":"date"}],"repeat":"","crontab":"00 06 * * *","once":false,"onceDelay":0.1,"topic":"","x":130,"y":140,"wires":[["397d944e8e0e381a"]]},{"id":"2d3371bf08f58b58","type":"server","name":"HA","version":2,"addon":false,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":"30"}]
