How @code-in-progress Broke My Foot
Welp, my update came earlier than expected. :sweat_smile: Welcome to what I am now just considering blog-style updates in this thread…
This weekend I spent setting up most of my Zigbee devices. This was so easy, I actually had fun playing with things! Er, well, until yesterday. One thing I ran into immediately (and I am hoping we can improve the documentation for this soon) was that my Green didn’t auto discover my SkyConnect1. The setup documentation doesn’t really go over this scenario, but I decided to jump to Step 52 and see if setting up the Zigbee integration would help me. It did! Following the steps from there got my SkyConnect set up and ready to find more devices! :muscle:
Within an hour, I set up 4 smart plugs to get my mesh network started and have 2 plugs connected to lights. I added in a couple of the Aqara contact sensors and the Third Reality motion sensors to start other projects up. The fairy lights behind me at my desk are plugged into one of the plugs, and then I set up my first automation! It’s just turning them off at night (5pm) and then back on before my work day starts (7am). I was very proud of myself - messing with automations is always fun for me and I look forward to making more. I can now see how automations can be as simple or as complicated as you want them.
One of the sensors I was going to use in the mud room with the two door sensors (to account for having our dog in there when we’re away), but instead I might use a scene to control the light and sensors in there and trigger it with voice. I couldn’t find a good spot for the sensor that wouldn’t risk it getting damaged. The other sensor I have set up in my office in front of the cat litter box where it will not be triggered by me on accident while at my desk. This was to see about setting up the robovac coming in and cleaning up every time the cats use the box.
I learned from overnight data, turns out the cats use that thing entirely too much for a frequent vacuum trips here in the office. :grimacing: This instead helped me determine that I will have the robovac come in the morning before my work day starts to make sure the overnight mess is cleaned up, but also create a counter to clean it up when the cats drag out so much.
Then I spent several hours trying to figure out how to keep the plug on the mesh network while the switch was off. After hitting a wall attempting to use an entity to control the power to the device, I ask in Discord if I am making things too complicated.
I was. Of course. :weary: The best way explained to me was, “If it didn’t have some power, how would you control it?” Duh, Missy. I should have known this…
But there was something wrong with the door sensors I installed in HA that I really needed to fix now. I could not get them to register when the door is open. I press the button on the sensors and they both send it back to HA, and they’re both in my network map. I remove them from my devices and add them back on through the Zigbee integration, directly with the plug they are closest to, directly with the SkyConnect. They just refuse to activate and register when the door is open.
After trying to rule out interference with my gateway by separating devices in my office further, I have an idea to try the 3rd sensor that isn’t installed on a door. I set it up in HA, take the magnet, touch the sensor, pull it away, IT SAYS OPEN. WHAT. THE. HELL. Why does this one work?? I stared at the device for a few minutes thinking about everything up until now. There is no way the 2 on the doors are broken this bad, and my mesh isn’t weak (but it’s also not the strongest, I’ll be using advice from Hedda here to make sure it’s better). I grab the loose magnet and take it downstairs to the mud room where the other sensors are, touch it to one of the sensors while I have the HA app open on its device page then pull it away. OPEN. It suddenly hits me.
Guys. Guys guys guys. I installed the sensors and magnets on the doors too far apart. :woman_facepalming: I even measured to make sure it would be within what the booklet says! Ugh. I pull them off the doors and frames they are stuck to, remove the sticky from the devices, and that is now where I am. Next I will be moving my Green and the SkyConnect to a more central location on my second floor - I have an ethernet cable more than long enough to do this; and setting up the door sensors closer to each other on their respective doors. I now have 6 WiZ lights on their way to me, which means I will be able to automate the mud room light tomorrow! :raised_hands:
…next update TBD. But I will say that I am learning so much about what the best ways to learn this system look like. I am excited to see if I can shape it into something useful for everyone. :3
1 I got my device a couple months before the name change from SkyConnect to ZBT-1. While I talk about my device as being a SkyConnect, the name of the device is now ZBT-1.
2 Step 5 listed as of today’s posting - just in case the steps change in the future, the step is referencing the “Configure the Zigbee Home Automation integration” step.
