At one point, I noticed there was a duplicate of ping2_is_available in Overview.
In Entities, I also see two: one have Entity ID = ping2_is_available and second have Entity ID = ping2_is_available_2. I cannot remove this duplicate from Entities, but it is also not in my .yaml.
How do I delete this false duplicate of binary_sensor?
When updating the HA version, this duplicate disappears for a while, but after 10-15 minutes it appears from somewhere again.
All binary_sensor that are defined through yaml in Entities are displayed with Status Read-only.
If you try to do as you write, there will be a message:
This entity ('binary_sensor.ping2_is_available_2') does not have a unique ID, therefore its settings cannot be managed from the UI. See the documentation for more detail.
After upgrading to version 2023.9.1, this problem has disappeared!
Unfortunately, after a while, this false binary_sensor reappeared.
The problem is still relevant.
I completely restarted the computer with HA and this problem is not there. I’ll hope she doesn’t happen again.
I also changed he MQTT version number for Z2M from 4 to 5.
I don’t know what affected more, but now there is no problem.
The same problem with statistics sensors. I created these sensors with unique_id and still can’t remove them from Entities.
If you make a new user, then this is not visible to it. This problem is for owner only
