How do I actually make a TV Remote Control work well in the GUI
Oh, this is just because when I first set up the Harmony HUB, I chose one set of names, and years later, when I set up Home Assistant integrations, I named the same devices slightly different.
Eventually, when I later decided to integrate the two (HA & Harmony HUB), I didn’t bother to change the names again.
Hi! Had some questions about your remote card. I’ve been using your old version with the tiles card and it still works well but was looking to start trasnsitioning to the button card. How did you get the coloring different between the title at the top and the rest of the card? Is it just a background image? I set up a few buttons to test out. I noticed that it works differrently than the tiles card, The tiles card is very responsive. If I press the button quickly 3 times the command is sent all 3 times to my harmony hub. With the custom button card it needs time between presses. Is there a way to adjust this? Can you use custom icons or only the mdi icons?
Hey Tom,
When you say enter them at the top of raw edit mode, where are you referring to?
When you are editing the card, there is an option in the bottom left called “show code editor” where you can edit the raw yaml that makes the card work:
I see show code editor, but what card are you starting with? Entities card?
Actually the raw editor is accessed by clicking the three dots icon in the top right of your dashboard twice.
First press to get into edit mode:
1
Then when in edit mode press the three dots again to select raw edit mode:
2
You will then see the raw edit mode where you can paste the templates at the top of the existing config:
Press Save when done.
I use custom:button-card
Here’s some code to start you off…
If you used custom:button-card and button card templates you could reduce that code by 80% as it mostly repeats the same thing over and over.
See post here Vizio TV Integration - #35 by 0rchid2434
Most of the code is posted here: https://github.com/kbrown01/Vizio_DirecTV
I finally finished the GUI part of my remote.
Here as an inspiration for some others.
Is there a way to get this as simple as possible in the UI? Like a card that could be configured.
That would be great.
Hi
awesome set up!
I’m trying to extend it with channel button, which should show the channel logo’s (svg or png), however they just turn up als ‘file’ icon
afbeelding
I have set show_entity_picture: true in both the template and the icon_button definition
entity_picture is defined as /local/assets/channels/npo1.svg
afbeelding
What am I missing here?
Nevermind, I used entity-picture instead of entity_picture :man_facepalming:
Could you share the code?
Here’s the remote part itself as the rest is still work in progress. The services is a mix between a media player entity, adb commands and a broadlink remote entity. Planning to clean this up at some point.
  type: entities
  entities:
    - type: custom:hui-entities-card
      entities:
        - type: custom:hui-grid-card
          cards:
            - type: custom:button-card
              tap_action:
                action: call-service
                service: media_player.toggle
                service_data:
                  entity_id: media_player.fernseher_schlafzimmer
              icon: mdi:power
              hold_action:
                action: none
              show_name: false
              color_type: blank-card
              tap_action:
                service: androidtv.adb_command
                service_data:
                  command: >-
                    sendevent /dev/input/event4 4 4 458834 && sendevent
                    /dev/input/event4 1 103 1 && sendevent /dev/input/event4 0 0
                    0 && sendevent /dev/input/event4 4 4 458834 && sendevent
                    /dev/input/event4 1 103 0 && sendevent /dev/input/event4 0 0
                    0
                  entity_id: media_player.fire_tv
              icon: mdi:arrow-up-bold
              hold_action:
                action: none
              show_name: false
              tap_action:
                service: remote.send_command
                service_data:
                  device: lg_tv
                  command: input
                  entity_id: remote.broadlink_schlafzimmer
              show_icon: true
              show_name: false
              icon: mdi:import
              tap_action:
                service_data:
                  command: >-
                    sendevent /dev/input/event4 4 4 458832 && sendevent
                    /dev/input/event4 1 105 1 && sendevent /dev/input/event4 0 0
                    0 && sendevent /dev/input/event4 4 4 458832 && sendevent
                    /dev/input/event4 1 105 0 && sendevent /dev/input/event4 0 0
                    0
              icon: mdi:arrow-left-bold
              hold_action:
                action: none
              show_name: false
              tap_action:
                service_data:
                  command: >-
                    sendevent /dev/input/event4 4 4 458840 && sendevent
                    /dev/input/event4 1 96 1 && sendevent /dev/input/event4 0 0
                    0 && sendevent /dev/input/event4 4 4 458840 && sendevent
                    /dev/input/event4 1 96 0 && sendevent /dev/input/event4 0 0
                    0
              icon: mdi:checkbox-blank-circle
              hold_action:
                action: none
              show_name: false
              tap_action:
                service_data:
                  command: >-
                    sendevent /dev/input/event4 4 4 458831 && sendevent
                    /dev/input/event4 1 106 1 && sendevent /dev/input/event4 0 0
                    0 && sendevent /dev/input/event4 4 4 458831 && sendevent
                    /dev/input/event4 1 106 0 && sendevent /dev/input/event4 0 0
                    0
              icon: mdi:arrow-right-bold
              hold_action:
                action: none
              show_name: false
              tap_action:
                service_data:
                  command: >-
                    sendevent /dev/input/event4 4 4 458833 && sendevent
                    /dev/input/event4 1 108 1 && sendevent /dev/input/event4 0 0
                    0 && sendevent /dev/input/event4 4 4 458833 && sendevent
                    /dev/input/event4 1 108 0 && sendevent /dev/input/event4 0 0
                    0
              icon: mdi:arrow-down-bold
              hold_action:
                action: none
              show_name: false
          columns: 5
          square: true
          cards:
              tap_action:
                service_data:
                  command: >-
                    sendevent /dev/input/event4 4 4 458993 && sendevent
                    /dev/input/event4 1 158 1 && sendevent /dev/input/event4 0 0
                    0 && sendevent /dev/input/event4 4 4 458993 && sendevent
                    /dev/input/event4 1 158 0 && sendevent /dev/input/event4 0 0
                    0
              icon: mdi:arrow-u-left-bottom
              hold_action:
                action: none
              show_name: false
              tap_action:
                service_data:
                  command: >-
                    sendevent /dev/input/event4 4 4 786979 && sendevent
                    /dev/input/event4 1 172 1 && sendevent /dev/input/event4 0 0
                    0 && sendevent /dev/input/event4 4 4 786979 && sendevent
                    /dev/input/event4 1 172 0 && sendevent /dev/input/event4 0 0
                    0
              icon: mdi:home-outline
              show_name: false
              tap_action:
                service_data:
                  command: >-
                    sendevent /dev/input/event4 4 4 786496 && sendevent
                    /dev/input/event4 1 139 1 && sendevent /dev/input/event4 0 0
                    0 && sendevent /dev/input/event4 4 4 786496 && sendevent
                    /dev/input/event4 1 139 0 && sendevent /dev/input/event4 0 0
                    0
              show_name: false
              show_icon: true
              icon: mdi:menu
              tap_action:
                service: media_player.volume_down
                service_data:
              icon: mdi:volume-minus
              show_name: false
              tap_action:
                service_data:
                  device: lg_tv
                  command: mute
              icon: mdi:volume-variant-off
              show_name: false
              tap_action:
                service: media_player.volume_up
                service_data:
              icon: mdi:volume-plus
              hold_action:
                action: none
              show_name: false
              tap_action:
                service: media_player.media_previous_track
                service_data:
              icon: mdi:rewind
              hold_action:
                action: none
              show_name: false
              tap_action:
                service: media_player.media_play_pause
                service_data:
              icon: mdi:play-pause
              hold_action:
                action: none
              show_name: false
              tap_action:
                service: media_player.media_next_track
                service_data:
              icon: mdi:fast-forward
              hold_action:
                action: none
              show_name: false
              tap_action:
                service: media_player.media_stop
                service_data:
              show_name: false
              icon: mdi:stop
              hold_action:
                action: none
              tap_action:
                service: scene.turn_on
                service_data:
                  entity_id: scene.fernsehszene_schlafzimmer
              show_name: false
              icon: mdi:lightbulb
              hold_action:
                action: none
          columns: 3
          square: false
      card_mod:
        style: |
          ha-card {
            --ha-card-background: white;
            --ha-card-border-width: 0px;
Bear in mind that there were design changes in the HA frontend since I posted the screenshot, so the border will look different.
Thanks, looks good :ok_hand::sunglasses:
What is the code you used to display the picture buttons at the bottom. I have a picture displayed but it isn’t taking up the full button.
I made up two remote using ha-floorplan. You can see them over here Share your Floorplan - #714 by OzGav
Just standard picture cards in a grid. You can define actions in picture cards, so no need for a button.
