Thank you ! I’ve installed the integration and it works, but I would like the same, to add this dashboard that you are using. @wgumaa Can you please share the integration configuration.yaml for this ?
@dondrog for my yaml configuration to work you need to have “card-mod” front end integration installed. You can find it in HACS.
For the first part:
The code:
type: custom:layout-card
layout_type: masonry
cards:
- square: false
type: grid
cards:
- type: vertical-stack
cards:
- type: custom:mushroom-chips-card
chips:
- type: template
icon: |-
{% set state=states(entity) %}
{% if state=='0.0' %}
mdi:heat-pump
{% elif state=='1.0' %}
mdi:heat-pump-outline
{% else %}
mdi:radiator
{% endif %}
entity: number.operating_mode_42744
content: |-
Operating Mode -
{% set d ={
'0.0': 'Auto',
'1.0': 'Manual',
'2.0': 'Add. Heat Only'
{{ d.get(states(entity)) }}
tap_action:
action: more-info
icon_color: |-
green
orange
{% elif state=='2.0' %}
red
{% else %}
grey
{% endif %}
alignment: justify
card_mod: null
style: |
ha-card {
--chip-border-width: 0px;
--chip-box-shadow: none;
--chip-background: none;
chips:
- type: template
entity: binary_sensor.compressor_status_31101
tap_action:
action: more-info
content: |-
Compressor -
{% set d ={
'off': 'Off',
'on': 'On',
icon: |-
{% if state=='off' %}
{% elif state=='on' %}
mdi:heat-pump
{% else %}
mdi:hvac
{% endif %}
icon_color: |-
{% if state=='on' %}
green
{% else %}
grey
{% endif %}
card_mod: null
style: |
ha-card {
chips:
- type: template
entity: switch.shellyplusplugs_d4d4daecdce8_switch_0
tap_action:
action: more-info
content: |-
Circulation Pump -
{% set d ={
'off': 'Off',
'on': 'On',
icon: |-
mdi:pump-off
mdi:pump
{% else %}
mdi:hvac
{% endif %}
icon_color: |-
green
{% else %}
grey
{% endif %}
card_mod: null
style: |
ha-card {
cards:
chips:
- type: template
entity: sensor.priority_31029
icon: |-
{% if state=='OFF' %}
mdi:heat-pump
{% elif state=='HOT WATER' %}
mdi:water-boiler
{% elif state=='HEAT' %}
mdi:radiator
{% elif state=='POOL' %}
mdi:pool
{% elif state=='COOLING' %}
mdi:air-conditioner
{% else %}
mdi:heat-pump
{% endif %}
content: |-
Priority -
{% set d ={
'OFF': 'Off',
'HOT WATER': 'Hot Water',
'HEAT': 'Heat',
'POOL': 'Pool',
'COOLING': 'Cooling'
tap_action:
action: more-info
icon_color: |-
grey
orange
red
yellow
blue
{% else %}
grey
{% endif %}
card_mod: null
style: |
ha-card {
chips:
- type: template
entity: number.heating_offset_climate_system_1_40031
tap_action:
action: more-info
content: |-
Heating Offset -
{% set d ={
'-10.0': '-10°C',
'-9.0': '-9°C',
'-8.0': '-8°C',
'-7.0': '-7°C',
'-6.0': '-6°C',
'-5.0': '-5°C',
'-4.0': '-4°C',
'-3.0': '-3°C',
'-2.0': '-2°C',
'-1.0': '-1°C',
'0.0': '0°C',
'1.0': '+1°C',
'2.0': '+2°C',
'3.0': '+3°C',
'4.0': '+4°C',
'5.0': '+5°C',
'6.0': '+6°C',
'7.0': '+7°C',
'8.0': '+8°C',
'9.0': '+9°C',
'10.0': '+10°C',
icon: |-
{% if state=='-10.0' %}
mdi:snowflake
{% elif state=='-9.0' %}
mdi:snowflake
{% elif state=='-8.0' %}
mdi:snowflake
{% elif state=='-7.0' %}
mdi:snowflake
{% elif state=='-6.0' %}
mdi:snowflake
{% elif state=='-5.0' %}
mdi:snowflake
{% elif state=='-4.0' %}
mdi:snowflake
{% elif state=='-3.0' %}
mdi:snowflake
{% elif state=='-2.0' %}
mdi:snowflake
{% elif state=='-1.0' %}
mdi:snowflake
{% elif state=='0.0' %}
mdi:radiator-disabled
mdi:radiator
mdi:radiator
{% elif state=='3.0' %}
mdi:radiator
{% elif state=='4.0' %}
mdi:radiator
{% elif state=='5.0' %}
mdi:radiator
{% elif state=='6.0' %}
mdi:radiator
{% elif state=='7.0' %}
mdi:radiator
{% elif state=='8.0' %}
mdi:radiator
{% elif state=='9.0' %}
mdi:radiator
{% elif state=='10.0' %}
mdi:radiator
{% else %}
mdi-radiator-off
{% endif %}
icon_color: |-
purple
purple
purple
light-blue
light-blue
light-blue
light-green
light-green
light-green
yellow
grey
amber
orange
orange
orange
red
red
red
brown
brown
brown
{% else %}
grey
{% endif %}
alignment: justify
card_mod: null
style: |
ha-card {
chips:
- type: template
entity: number.hot_water_demand_mode_40057
tap_action:
action: more-info
content: |-
Hot Water Demand -
{% set d ={
'0.0': 'Small',
'1.0': 'Medium',
'2.0': 'Large',
'4.0': 'Smart Control',
icon: |-
mdi:size-s
mdi:size-m
mdi:size-l
mdi:head-snowflake
{% else %}
mdi:water-boiler-alert
{% endif %}
icon_color: |-
green
orange
red
blue
{% else %}
grey
{% endif %}
card_mod: null
style: |
ha-card {
columns: 2
layout:
width: 285
@dondrog I am suing mushroom cards and again you can find in HACS
Part 2 is the controls:
Code:
layout:
width: 285
cards:
title: Heat Pump Controls
cards:
icon_color: |-
grey
{% elif state=='127.0' %}
red
{% else %}
grey
{% endif %}
icon: |-
mdi:water-boiler-off
{% else %}
mdi:water-boiler
{% endif %}
secondary: |2-
{% set d ={
'0.0': 'Off',
'127.0': 'On',
primary: More Hot Water
hold_action:
action: none
double_tap_action:
action: call-service
service: script.more_hot_water_on
target: {}
multiline_secondary: false
tap_action:
service: script.more_hot_water_off
target: {}
entity: number.more_hot_water_40698
- type: entities
entities:
- entity: number.hot_water_demand_mode_40057
name: Hot Water Demand
icon: mdi:water-opacity
- type: custom:numberbox-card
border: true
entity: number.max_supply_climate_system_1_40039
step: 1
unit: °C
min: 5
icon: mdi:thermometer-chevron-up
moreinfo: number.max_supply_climate_system_1_40039
max: 80
border: true
entity: number.min_supply_climate_system_1_40035
step: 1
icon: mdi:thermometer-chevron-down
min: 5
max: 80
- type: horizontal-stack
You will have to create scripts for more hot water on and off.
Thank you very much for your help @wgumaa
I’ve managed to configure the dashboard via yaml :
If you may, can you please share Section 3 yaml ?
nibe.yml (dashboard), so far:
title: Nibe Pump
- title: Indicators
cards:
- square: false
title: Indicators
type: grid
cards:
cards:
chips:
- type: template
icon: |-
mdi:heat-pump
{% else %}
mdi:radiator
{% endif %}
content: |-
Operating Mode -
{% set d ={
'0.0': 'Auto',
'1.0': 'Manual',
tap_action:
action: more-info
icon_color: |-
green
orange
red
{% else %}
grey
{% endif %}
alignment: justify
card_mod: null
style: |
ha-card {
chips:
- type: template
tap_action:
action: more-info
content: |-
Compressor -
{% set d ={
'off': 'Off',
'on': 'On',
icon: |-
mdi:heat-pump
{% else %}
mdi:hvac
{% endif %}
icon_color: |-
green
{% else %}
grey
{% endif %}
card_mod: null
style: |
ha-card {
chips:
- type: template
tap_action:
action: more-info
content: |-
Circulation Pump -
{% set d ={
'off': 'Off',
'on': 'On',
icon: |-
mdi:pump-off
mdi:pump
{% else %}
mdi:hvac
{% endif %}
icon_color: |-
green
{% else %}
grey
{% endif %}
card_mod: null
style: |
ha-card {
cards:
chips:
- type: template
icon: |-
mdi:heat-pump
mdi:water-boiler
mdi:radiator
mdi:pool
mdi:air-conditioner
{% else %}
mdi:heat-pump
{% endif %}
content: |-
Priority -
{% set d ={
'OFF': 'Off',
'HEAT': 'Heat',
'POOL': 'Pool',
tap_action:
action: more-info
icon_color: |-
grey
orange
red
yellow
blue
{% else %}
grey
{% endif %}
card_mod: null
style: |
ha-card {
chips:
- type: template
tap_action:
action: more-info
content: |-
Heating Offset -
{% set d ={
'-10.0': '-10°C',
'-9.0': '-9°C',
'-8.0': '-8°C',
'-7.0': '-7°C',
'-6.0': '-6°C',
'-5.0': '-5°C',
'-4.0': '-4°C',
'-3.0': '-3°C',
'-2.0': '-2°C',
'-1.0': '-1°C',
'0.0': '0°C',
'1.0': '+1°C',
'2.0': '+2°C',
'3.0': '+3°C',
'4.0': '+4°C',
'5.0': '+5°C',
'6.0': '+6°C',
'7.0': '+7°C',
'8.0': '+8°C',
'9.0': '+9°C',
'10.0': '+10°C',
icon: |-
mdi:snowflake
mdi:snowflake
mdi:snowflake
mdi:snowflake
mdi:snowflake
mdi:snowflake
mdi:snowflake
mdi:snowflake
mdi:snowflake
mdi:snowflake
mdi:radiator
mdi:radiator
mdi:radiator
mdi:radiator
mdi:radiator
mdi:radiator
mdi:radiator
mdi:radiator
mdi:radiator
mdi:radiator
{% else %}
mdi-radiator-off
{% endif %}
icon_color: |-
purple
purple
purple
light-blue
light-blue
light-blue
light-green
light-green
light-green
yellow
grey
amber
orange
orange
orange
red
red
red
brown
brown
brown
{% else %}
grey
{% endif %}
alignment: justify
card_mod: null
style: |
ha-card {
chips:
- type: template
tap_action:
action: more-info
content: |-
Hot Water Demand -
{% set d ={
'0.0': 'Small',
'1.0': 'Medium',
'2.0': 'Large',
icon: |-
mdi:size-s
mdi:size-m
mdi:size-l
mdi:head-snowflake
{% else %}
{% endif %}
icon_color: |-
green
orange
red
blue
{% else %}
grey
{% endif %}
card_mod: null
style: |
ha-card {
columns: 2
layout:
width: 285
- title: Heat Pump Controls
layout:
width: 285
cards:
cards:
icon_color: |-
grey
red
{% else %}
grey
{% endif %}
icon: |-
{% else %}
mdi:water-boiler
{% endif %}
secondary: |2-
{% set d ={
'0.0': 'Off',
'127.0': 'On',
hold_action:
action: none
double_tap_action:
target: {}
tap_action:
target: {}
- type: entities
entities:
border: true
step: 1
unit: °C
min: 5
max: 80
border: true
step: 1
min: 5
max: 80
@dondrog for the graphs:
The code:
cards:
- square: false
columns: 2
type: grid
title: Temperatures & Consumption
cards:
- type: gauge
name: Heat Supply Line
unit: °C
max: 65
min: 20
entity: sensor.supply_line_bt2_30006
needle: false
severity:
green: 0
yellow: 20
red: 35
card_mod:
style:
ha-card {
background-color: transparent;
box-shadow: none;
border: 0px;
- type: gauge
unit: °C
name: Heat Return Line
min: 20
max: 60
entity: sensor.return_line_bt3_30008
severity:
green: 0
yellow: 20
red: 35
card_mod:
style:
ha-card {
box-shadow: none;
border: 0px;
- type: gauge
name: Hot Water (Top)
max: 55
min: 18
unit: °C
severity:
green: 25
yellow: 35
red: 45
needle: false
entity: sensor.display_hot_water_sensor_eb100_bt7_31690
card_mod:
style:
ha-card {
box-shadow: none;
border: 0px;
- type: gauge
name: Hot Water Charging
max: 55
min: 18
unit: °C
severity:
green: 30
yellow: 40
red: 50
needle: false
entity: sensor.hot_water_charging_bt6_30010
card_mod:
style:
ha-card {
box-shadow: none;
border: 0px;
- type: gauge
entity: sensor.brine_in_bt10_30011
unit: °C
min: -10
max: 15
card_mod:
style:
ha-card {
box-shadow: none;
border: 0px;
- type: gauge
entity: sensor.brine_out_bt11_30012
unit: °C
min: -10
max: 15
card_mod:
style:
ha-card {
box-shadow: none;
border: 0px;
cards:
- type: custom:mini-graph-card
entities:
- entity: sensor.instantaneous_used_power_32167
name: Heat Pump Power Consumption
unit: w
color_thresholds:
- value: 0
color: '#9B59B6'
- value: 25
color: '#3498DB'
- value: 250
color: '#27AE60'
- value: 500
color: '#F1C40F'
- value: 750
color: '#F39C12'
- value: 1000
color: '#E74C3C'
hours_to_show: 24
card_mod:
style:
ha-card {
box-shadow: none;
border: 0px;
points_per_hour: 1
update_interval: 30
line_width: 2
entities:
- entity: sensor.hot_water_charging_bt6_30010
unit: °C
color_thresholds:
- value: 0
color: '#6BBCD1'
- value: 10
color: '#002947'
- value: 20
color: '#002947'
- value: 30
color: '#3498DB'
- value: 40
color: '#FD9415'
- value: 50
color: '#E23201'
- value: 60
color: '#E23201'
hours_to_show: 24
points_per_hour: 1
update_interval: 30
line_width: 2
card_mod:
style:
ha-card {
box-shadow: none;
border: 0px;
layout:
width: 285
Enjoy playing around and come back with questions as I am sure you will have some!
I could post it because the forum does not allow more than 3 consecutive posts!
@dondrog You can get rid of the circulation pump as that is a device external to the Nibe system. I have separate Hot water circulation pump that circulates hot water in the pipes.
Thank you, @wgumaa !
I’m still getting my head around. The struggle is to find the right sensors in the Entities provided by the integration. Your config helped me a lot, basically it did everything.
Do you know which entities are behind this two numbers below ?
I’ve tried adding a few of them, but with no luck.
Edit: I just saw that it was an open ticket for this :
I’m trying to change the heating offset, but everytime I change it, either from the dashboard either from the integration, the heat pump will set it to 0 after a few seconds.
Do you have the same problem ?
For the total energy consumption I’ve used Integration - Riemann sum integral with the sensor.instantaneous_used_power_32167 and added the device in the Energy dashboard.
No i am not experiencing that.
indeed, this one: number.heating_offset_climate_system_1_40031 . But as I mentioned on the edit, I saw that you reported it on github and it’s a known bug which will be fixed with, hopefully, the upcoming release of the core version.
@dondrog that wasn’t for the heating offset but the Hot Water Demand which broke after the last update. Basically numerical values have become words.
For me the heating offset is working fine. I just tested between our messages and it stays.
Strange, for me still doesn’t work. Did you test is with negative values ?
Indeed I’ve confused them, this one was raised by m-wo :
@dondrog just tried now.
and yes you are right! it jumped back to 0!
I am not using heating offset that much. But good to know. Another broken entity!
Look here: Update nibe heatpump to 2.5.0 by elupus · Pull Request #103788 · home-assistant/core · GitHub
@dondrog the beta is out in HA beta core, but the full core would be out on the 6th Dec where the integration has been update to include the fixes but also the changes discussed.
That’s good news. I think I will give it a try tomorrow maybe to see how it works.
I don’t know if you already have scripts for more hot water, but I’ve created some:
###Card:
icon_color: |-
{% set state=states(entity)|int(0) %}
{% if state<=0 %}
grey
{% else %}
red
{% endif %}
icon: |-
{% if state<=0 %}
{% else %}
mdi:water-boiler
{% endif %}
secondary: |2-
{% set d ={
'0.0': 'Off',
'2.0': 'On',
hold_action:
action: none
double_tap_action:
action: more-info
tap_action:
service: script.switch_hot_water
###Script (goes in the scripts.yaml )
switch_hot_water:
sequence:
- choose:
- conditions:
- condition: state
entity_id: number.more_hot_water_40698
state: '0.0'
sequence:
- service: number.set_value
value: '2.0'
- conditions:
- condition: state
state: '2.0'
sequence:
value: '0.0'
default: []
@dondrog how did you get your more hot water to work with a value of 2.0?
I have a slider with that goes from -128 (which does nothing) to 0 (Off) to 127 (On)
I did a test first from the menu of the pump and turned on and off the more hot water and see the values which I got in HA logs, and for me it was : 0 for off and 2 for on, and that’s why I putted them 0 and 2.
