Yah, I’ve learned to never assume when it comes to the resolver. I.e. I always assume wrong
Love you guys Used this solution:
aspirar:
fields:
divisao:
description: "Divisão a aspirar"
sequence:
- variables:
rooms:
corredor: "1,11"
pais: "3"
sala: "6"
meninos: "7"
gonçalo: "8"
cozinha: "9"
escritório: "12"
- service: xiaomi_miot.call_action
entity_id: vacuum.viomi_v18_e271_robot_cleaner
siid: 4
aiid: 13
params: [0, 1, "{{ rooms.get(divisao, '') }}"]
@petro the “battle room” is wherever the wife wants it to be
Now, the only problem I have is with “corredor” since it passes 2 room ids.
While testing the service call, this works:
siid: 4
aiid: 13
params: [0,1,"1,11"]
But for some reason, when using the script above, it doesn’t.
This shows up on the logs:
Viomi S9(viomi.vacuum.v18): Call miot action {'did': '329449566', 'siid': 4, 'aiid': 13, 'in': [{'piid': 36, 'value': 0}, {'piid': 37, 'value': 1}, {'piid': 38, 'value': (1, 11)}]} failed: {'code': -9999, 'message': 'user ack timeout'}
are you 100% sure that the 3rd param is a string of separated numbers?
well… it works on the service call directly just not via script
can you show what you use as a service call?
^^ this one
can you give this script a try then
I would have said that Home Assistant native typing converted the string "1,11"
into a tuple (1, 11)
. However, I hesitate to say that because I can’t explain why it only happens when the script executes the service call versus when the service call is executed from Developer Tools > Services.
I see it now.
The direct service call uses this:
whereas the script uses this:
The result of the template within the list is this string '1,11'
and to native typing that looks like a tuple and so it gets converted to a tuple.
That would explain the appearance of the tuple in the error message:
Yeah, it was my first thought too, but since I’m a n00b on this I wanted to be sure here.
@petro
The metioned script is missing a “>” after div:
right? (otherwise it just has a ton of errors)
Anyway, with the “>” I have this error when it executes:
aspirar: Error executing script. Error rendering template for variables at pos 1: TypeError: can only concatenate list (not "str") to list
that’s possible
that’s not possible, there are no string + [] concatenations. Are you using the one I linked or a previous one
ah ok, then use this config instead. Apparently it does not type corredor
aspirar:
fields:
divisao:
sequence:
- variables:
rooms:
corredor: [1, 11]
pais: 3
sala: 6
meninos: 7
gonçalo: 8
cozinha: 9
escritório: 12
div:
{% set which = divisao if divisao is iterable and divisao is not string else [ divisao ] %}
{% set ns = namespace(ret=[]) %}
{% for x in rooms.items() | list | selectattr('0', 'in', which) | map(attribute='1') | list %}
{% set v = [ x ] if x is is_number else x %}
{% set ns.ret = ns.ret + v %}
{% endfor %}
{{ ns.ret }}
siid: 4
aiid: 13
params: [0, 1, "{{ div | join(', ') }}"]
Home Assistant’s native typing is based on “If it looks like a duck, it’s a duck” and 1,11
looks like a tuple so it’s a tuple.
oh shit… so i’m doomed on this one?
back to the same error message (coverted to a tuple)
Try petro’s suggestion.
… and the same result. Native typing made it a duck again.
ok, i know how to fix it gimme a minute
Ok, to get around the typing applied by templates you have to force a complex structure through the template and it won’t adjust the internal items.
aspirar:
fields:
divisao:
sequence:
- variables:
rooms:
corredor: [1, 11]
pais: 3
sala: 6
meninos: 7
gonçalo: 8
cozinha: 9
escritório: 12
div:
{% endfor %}
{{ ns.ret }}
siid: 4
aiid: 13
params: "{{ [0, 1, div | join(', ')] }}"
fyi @123 you can do this too with the entire data field if you try to force a number to be a string…
data: "{{ {'foo': '123'} }}"
foo will be templateable and still be a string and the entire service data field is templated.
It’s the only way to circumvent the typing from the template engine.
