Then again, the point of ha is to avoid a multitude of apps.
Wledâs app or webserver / esphomeâs webserver + HA means redundancy!! when my HA server was crashing every other day, I had at least these two to rely on.
A lot of people have suggested WLED and itâs a great piece of software. The only issue I have with it is, it basically turns your esp board into a 100% led controller. For some people and some situations, thatâs just fine. For me, I normally always need to use additional gpios or add sensors for different things and a 100% led controller makes that difficult. If you want to use your board for other things and not just for controlling an led strip, you need to look at FastLed or the neopixel bus. You can control dumb or addressable leds just like with wled and use a ton of effects. To individually assign a color to each led, you need to create Light Partitions. Also, do yourself a favor and go have a look around through the esphome docs. This is all part of the light component that you created, you just didnât look hard enough. For your project your doing now, you may find wled works better because you only want a light controller but I highly recommend you try these out. Your going to find there a lots of situations where you want more than just an led controller and these are perfect for those times.
Itâs a $5 board. What is wrong with one dedicated to WLED?
I bought two of these controllers for WLED this year. Mostly because it is in a nice package.
IMO there is nothing wrong with WLED (I have multiple instances of it running throughout my setup). However, there are some benefits to using the esphome built-in led operations. As @Fallingaway24 mentioned above you can use the other pins for various functionality to compose an all-in-one solution without relying on home assistant or some other piece of software. For example I am setting up an esp32 with a nextion display, temp/humidity sensors, and leds. Using the display, I can see the values of the temp/humidity sensors, turn the leds on/off, and set the colors. I can also use the leds to display a different color on the strip if the temperature is too hot or if the humidity is too low. All of this can be done on the board with or without wifi and not being connected to any other systems.
The price of the board is 1 of many factors. Each board needs a psu, microUSB, enclosure, cable glands, more wire management, etc, etc. I donât slap an esp on a breadboard and call it a finished project. Right now, aside from all of those factors. The number of esp boards on my network is close to 50 and it keeps growing. Did I mention I can do the same stuff without tying up a whole board?
Hello Fallingaway, hello folks,
Iâm tryin to upgrade a dumb keypad with an ESP32 and ESPHome, I did manage to succesfully use the Matrixkepad componnent and now I would like to add 3 more RGB leds (on of them should be kind of circular progress bar, so 8 leds for this one) for different status controlls and error handling. I have soldered 3 the stripes pieces to 3 GPIO pins 25,26,27 and used in the first try Fast Led the standard
code:
- platform: fastled_clockless
chipset: WS2812B
pin: GPIO23
num_leds: 1
rgb_order: GRB
# to be repated for the other two stripe pieces
I had issues controling it from HomeAssistant the delay was big and from time to time unresposive.
I found that this is a common issue, even the founder of ESP Home recomended to others to use NeoPixelBus.
I did a try, using the similar code. Pleas see bellow. The entities apeard corectlly in HA, but ony one is working and turning on all the other LEDs as well. So if I activate the âNumPadLeftâ light, all will be turned on. In the case of fast led this was working well.
Any ideas why is this happening? Any sugestions or maybe other componets which I could use to integrate the 3 pcs of WS2812B separatelly into HA and have instant reaction?
Thank you all!
light:
- platform: neopixelbus
type: GRB
variant: WS2812X
pin: GPIO27
num_leds: 8
type: GRB
variant: WS2812X
pin: GPIO26
num_leds: 1
type: GRB
variant: WS2812X
pin: GPIO25
num_leds: 1
if a single light entity is turning on the other ones, youâve likely got a wiring issue. Does each gpio go to a sperate strip? It sounds like youâve got all of your data lines connected and they shouldnât be. You also need to make sure you are using the correct terms. You mention an RGB light in one place but your code suggests your using addressable ledâs. These are 2 different things, one is controlled by a single data(gpio) the other uses a gpio for each color channel, R,G,B so it uses 3 gpioâs.
Thanks Justin for your reply.
Sorry for the bad term usage. I was using RGB as common term. Indeed we speak about Adressable WS2812X led stripe with GRB sequence.
The wiring is correct, because the FASTLed component was adressing the LEDs corettly, it was just the unresponsivess issue in Home Assistant.
I between after a lot of googling I have found the issue with neopixelbus. In order to use separate GPIO pins, an adreess needs to be specified for each. Please see bellow. Somebody like me will need it
type: GRB
variant: WS2812X
pin: GPIO26
method:
type: esp32_rmt
channel: 1
num_leds: 1
type: GRB
variant: WS2812X
pin: GPIO25
method:
type: esp32_rmt
channel: 2
num_leds: 1
gotcha. I figured it was a wiring issue or how the lights were set up. I have a similar lighting setup and didnât need to specify channels but I used the Partition integration to declare which gpioâs and how many ledâs were in the light. I aslo used an esp8266 so thatâs probably the difference.
I have one more questions.
When Iâm turning on or off the neopixelbus LEDs ( via Home assistant eintity) by standard i got a dimm-up or a dimm-down effect, would say about 0.5 seconds. Is there a way to just turn the LEDs quickly on or off?
Edit: Found it. By default there is a transition time of 1 sec.
Instant on can be set with: default_transition_length: 0s
type: GRB
variant: WS2812X
pin: GPIO26
method:
type: esp32_rmt
channel: 1
num_leds: 1
Hello everyone. Maybe not the right place to ask (different topic) but I need help with code for 2 ws8212b strips, controlling by one esp32 board. When I leave one strip with one code for on/off itâs work fine, but when I add code for second strip , I have to turn on both switches on to control On/Off for strips. They are on the different GPIOâs. What I am doing wrong?
esphome:
friendly_name: Bed Occupancy Sensor
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: ""
ota:
password: ""
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Bed-Occupancy-Sensor"
password: ""
captive_portal:
binary_sensor:
name: "Bedroom2 Bed Occupied"
lambda: |-
if (id(yevgeniy_side).state < id(trigger_level).state) {
return true;
} else {
return false;
- platform: adc
pin: GPIO34 #Use a different pin for each FRS strip
attenuation: 11db
name: "Yevgeniy Side Sensor"
icon: mdi:bed
update_interval: 0.5s
filters:
- sliding_window_moving_average:
window_size: 10
send_every: 1
- or:
- throttle: 180s
- delta: 0.02
- platform: adc
pin: GPIO35 #Use a different pin for each FRS strip
attenuation: 11db
name: "Irina Side Sensor"
icon: mdi:bed
filters:
window_size: 10
send_every: 1
- or:
- throttle: 180s
- delta: 0.02
- platform: homeassistant
entity_id: input_number.bed_trigger_level
light:
on_turn_on:
then:
- light.turn_on:
brightness: 25%
chipset: WS2812B
pin: GPIO22
num_leds: 151
rgb_order: GRB
color_correct: [50%, 50%, 50%]
restore_mode: ALWAYS_off
on_turn_on:
then:
- light.turn_on:
brightness: 25%
chipset: WS2812B
pin: GPIO4
num_leds: 151
rgb_order: GRB
web_server:
port: 80
Thank you
Looks ok to me. Are you sure itâs not a wiring issue? There are several warnings about issues with fastled in the docs. Is there a reason you arenât just using neopixel which doesnât have all those issues that haunt fastled?
The indentation for the two lights are different.
No itâs not a wiring issue, because itâs even happened when I disconnect one strip from the board but leave my code like it is. I bought this strips from Aliexpress long time ago and decided to use for my night light under the bed with bed sensor. Itâs really good brand, BTF-Lighting. Thank you for your response.
What you mean, please explain
I copy and paste code from #1 to #2 , just change GPIO #
Just look at your yaml. The first is indented 2 spaces, the second is not.
I clean what I see, but still same issue, also itâs not turning my wife side lights on, only my with both triggers in on position
light:
#### My lights##
on_turn_on:
then:
- light.turn_on:
brightness: 100%
chipset: WS2812B
pin: GPIO22
num_leds: 151
rgb_order: GRB
#### Irina's Lights#####
on_turn_on:
then:
- light.turn_on:
brightness: 100%
chipset: WS2812B
pin: GPIO23
num_leds: 151
rgb_order: GRB
Here is my wiring diagram. I use ESP32 and logic shifter ( for LED)
Gpio22 connected to LV4 on Logic shifter, GPIO23 to LV2 and HV4 to Yevgeniy LED, LV2 to Irina LED
I share the ground for both of them . 5v going directly to LED strips ( separately)
For a start restore_mode: ALWAYS_OFF
(not ALWAYS_off
) see Light Component â ESPHome.
And we cannot really see that so called wiring diagram. Please just draw it on a piece of paper. Label the components.
