How do I see which Home Assistant instance I am upgrading when using Remote Home Assistant?
I have my main HA instance, but also an RPi running just to have a Bluetooth radio close to some Airthings Wave Radon monitors and some Mi Flora sensors (passed by using Remote Home Assistant).
With the notice that HA 2022.7 would break Bluetooth, I don’t want to upgrade the HA instance running on the RPi. But I do want to upgrade my main instance running in a VM. But how can I be sure which is which?
This is from the UI when accessing the main HA.
I’m assuming that one is the main HA, the other is the “remote”. But I see no difference, whatsoever, in the UI. How would I know which is which, to avoid upgrading the “wrong” one?
Upgrade via the commandline.
That works. Thanks for the suggestion (ha core update).
Would still be nice to be able to see what’s what in the UI.
That may not be a situation that was contemplated, I suggest a feature request.
