How do i use home assistant and add functions?
I got it to work a little bit, and i used pin 2, the pinout on my picture is ther than yours…
xiao_esp32c3_pinout_top (1)
I have mine dht connected to the first pin left side, (in picture adc 2)
and i cant add the devices nothing there!
GUYS! i got this:
Now I Just need it so when the humidity is lower than 30%, it starts another thing…
@ticsyboy
Glad you got it to work.
But was the problem that you couldn’t communicate with Bluetooth? You didn’t mention that problem.
I assumed that you only wanted to communicate via WiFi with your DHT22 sensor.
Are you using a BlueTooth sensors as well?
no i dont care or need the bluetooth i use wifi…-
but why are the pinouts different on the exact same model?
But then why do you show a picture with BlueTooth problems???
No, the pinouts are exactly the same on both images, but they are shown in slightly different ways.
i use port nr in adc (nr 2. and when i write 2 in code it works to find the sensor
