How I installed ESPHome on the wt32-eth01
Thank you for this tutorial.
I’ve fallen at the first hurdle!
Terminal is giving me this:
Successfully installed bitstring-3.1.9 cffi-1.15.0 cryptography-36.0.1 ecdsa-0.17.0 esptool-3.2 pycparser-2.21 pyserial-3.5 reedsolo-1.5.4 six-1.16.0 tornado-6.1
WARNING: You are using pip version 19.2.3, however version 22.0.3 is available.
You should consider upgrading via the 'pip install --upgrade pip' command.
asht@MacBook-Pro ~ % esphome dashboard config/
zsh: command not found: esphome
Installation seems to be successful.
Why would the esphome command not be found?
