Johanf
(Johan)
February 27, 2022, 10:27am
21
I get that too. I first execute the command
export PATH=“/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin:/Users/username /Library/Python/3.7/bin”
And then esphome command.
This works for me. I struggle with “command not found” sometimes too. I don’t know anymore why I used this exact path, guess I googled it. I don’t use terminal a lot.
There are several sources on Google about Command not found for terminal commands.
EDIT: You probably have to install Esphome. The esptool is needed for running the dashboard locally, but you do have to have Esphome seperately installed. This can be done, on mac, with:
pip3 install esphome
See: Installing ESPHome Manually — ESPHome
ashscott
(Ash)
February 27, 2022, 10:57am
22
Thanks for that.
Still the same ‘not found’ result.
I’ll give ESPHome flasher .bin upload a try and go from there.
EDIT:
It’s working! Just had to restart after flashing to see the logs.
wkchick
(wkchick)
February 28, 2022, 12:28am
23
I experienced the same like you did. It’s something like after flashing the first time with ESPhome-Flasher, OTA works for the 1st time but not any more. I don’t understand what you meant by peer resetting. How can peer resetting be done (thru reset switch, jumper or software)? I don’t mind to do it for OTA as loong as it is not necessary to pull the WT32-ETH01 from my setup and reconnect the 6 wires for flashing.
pashdown
(Pete Ashdown)
March 16, 2022, 10:11pm
24
"Connection reset by peer"
The board has 4MB of flash, why is it reporting that it has only 1835008? I can see a problem trying to upload new firmware if the size of the firmware.bin is larger than the free space (1106608 > (1835008 - 1106498)).
Johanf
(Johan)
April 1, 2022, 6:44pm
25
Nicko1
(Nick)
June 29, 2022, 7:21am
26
I’ve used these and are great has not missed a beat for 2 years
aceindy
(Aceindy)
June 29, 2022, 10:35am
27
Little late, but thanks…
mine didn’t skip a beat either for the last 6 months
Could you help me which gpio pin I can use as an OUTPUT (apart from gpio14 as it’s working fine but i need one more)? According to the datasheet 39, 36, 35 are inputs only, 2, 4, 12, 15 are labelled as strapping and not recommended to use.
cubertt
(Cubertt)
September 9, 2022, 3:25pm
29
i am using this config for windows sensors:
esphome:
platform: ESP32
board: esp-wrover-kit
ethernet:
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO0_IN
phy_addr: 1
power_pin: GPIO16
mqtt:
broker: 192.168.1.12
username:
password:
discovery: False
discovery_retain: False
birth_message:
topic: $devicename/status
payload: online
will_message:
payload: offline
on_message:
- topic: $devicename/ota_mode
payload: 'ON'
then:
- mqtt.publish:
topic: $devicename/ota_mode_status
payload: "active"
- topic: $devicename/sleep_mode
payload: 'ON'
then:
- mqtt.publish:
payload: "disabled"
logger:
level: WARN
ota:
password: password
binary_sensor:
- platform: gpio
pin:
number: 14
mode: INPUT_PULLDOWN
inverted: True
device_class: window
- platform: gpio
pin:
number: 15
inverted: True
- platform: gpio
pin:
number: 5
inverted: True
- platform: gpio
pin:
number: 3
inverted: True
- platform: gpio
pin:
number: 4
inverted: True
- platform: gpio
pin:
number: 2
inverted: True
- platform: gpio
pin:
number: 33
inverted: True
- platform: gpio
pin:
number: 32
inverted: True
# Enable Home Assistant API
api:
and it seems to work (i get a warning about gpios when compiling…thats all)
EDIT: You want to use thema as “output”, i have no idea…sorry
If you have a look at the strapping pin description (e.g. Boot Mode Selection - ESP32 - — esptool.py latest documentation ), you might still be able to use some of them, depending on your use-case.
I for myself use GPIO2 and GPIO4 for SDA and SCL, both are strapping pins. For download mode, GPIO2 needs to be pulled low while it doesn’t care in regular boot mode. So I’m fine with this, if I have to flash it via serial cable, I have to take out the module anyway (mine sits in a socket).
There is a note regarding GPIO4: It’s unused for any boot mode, so you can use it freely.
I use some other pins as output without problems:
IO12 → Relay
IO14 → Relay
IO17 → Tx
IO33 → Resets another module, so output
IO32 → DTR, so output
Thanks for the answer, I was able to use GPIO14 and GPIO4 as output and GPIO2 as input in pulldown mode.
My smart siren project has finally been completed
I need your help to do the same thing. Would you show me the code?
Thank you so much for your great explanation
Daarn
(David Arnshelm)
October 23, 2022, 1:02am
35
Hi
I need help i try to use MCP23017 expander but
when i Scan i2c Im getting this
[02:52:30][C][i2c.arduino:038]: I2C Bus:
[02:52:30][C][i2c.arduino:039]: SDA Pin: GPIO12
[02:52:30][C][i2c.arduino:040]: SCL Pin: GPIO15
[02:52:30][C][i2c.arduino:041]: Frequency: 50000 Hz
[02:52:30][C][i2c.arduino:050]: Recovery: failed, SDA is held low on the bus
[02:52:30][I][i2c.arduino:054]: Results from i2c bus scan:
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x08
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x09
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x0A
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x0B
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x0C
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x0D
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x0E
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x0F
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x10
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x11
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x12
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x13
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x14
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x15
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x16
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x17
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x18
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x19
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x1A
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x1B
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x1C
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x1D
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x1E
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x1F
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x20
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x21
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x22
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x23
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x24
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x25
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x26
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x27
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x28
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x29
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x2A
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x2B
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x2C
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x2D
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x2E
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x2F
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x30
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x31
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x32
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x33
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x34
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x35
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x36
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x37
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x38
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x39
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x3A
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x3B
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x3C
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x3D
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x3E
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x3F
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x40
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x41
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x42
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x43
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x44
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x45
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x46
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x47
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x48
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x49
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x4A
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x4B
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x4C
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x4D
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x4E
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x4F
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x50
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x51
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x52
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x53
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x54
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x55
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x56
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x57
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x58
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x59
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x5A
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x5B
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x5C
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x5D
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x5E
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x5F
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x60
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x61
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x62
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x63
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x64
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x65
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x66
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x67
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x68
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x69
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x6A
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x6B
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x6C
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x6D
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x6E
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x6F
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x70
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x71
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x72
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x73
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x74
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x75
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x76
[02:52:30][E][i2c.arduino:062]: Unknown error at address 0x77
I have try use pin GPIO02 and GPIO04 also but sam result and I have connected A1 A2 A3 to GND for adress 0x20.
But nothing work
I only have simplex code
esphome:
'name: wt32
platform: ESP32
ethernet:
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO0_IN
phy_addr: 1
power_pin: GPIO16
ota:
password:
# Enable logging
logger:
api:
i2c:
sda: GPIO12
scl: GPIO15
scan: true
rmeekers
(Rutger)
December 26, 2022, 1:35pm
36
did you succeed? If so, can you help me out?
Waz-Cpt
(Warwick Davison)
January 24, 2023, 12:25pm
37
However from what I can see is that these do not use 802.3af PoE standard. They appear to use passive PoE. Would be interested to know if I am wrong about that.
pepeEL
(pepeEL)
January 27, 2023, 12:11pm
38
Anybody tell me what pins is for SDA and SCL in this module WT32-ETH01 ?
I have ESP32 POE TTGO in post HOLDESMADE in this thread and i define
i2c:
- id: bus_a
sda: 14
scl: 02
scan: true
but i dont know it is correct. It works but i have a problem with delay on expander MCP23017 and use it for controll my lights in my home. Some module ESP32 like OLIMEX has descripe pins whis is for i2C but this and my has no describe. WHat pin i must use ?
GobblerGuy
(Gobbler Guy)
January 30, 2023, 1:18am
39
And does anyone know if the WT32-ETH01 has ADC capability? I cannot see any indication of this on the pin outs that I can find but I can only see pins labelled input with no details beyond that. Maybe It looks like not……
Daarn
(David Arnshelm)
February 3, 2023, 7:15pm
40
Hi
this are my config for sda and scl and it works witout delay for mcp23017
sphome:
esp32:
framework:
type: arduino
ethernet:
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO0_IN
phy_addr: 1
power_pin: GPIO16
Enable logging
logger:
api:
encryption:
key:
ota:
password:
i2c:
sda: 14
scl: 15
scan: true
mcp23017:
address: 0x20
