How to access rest-api of a photovoltaic system (documented)?
This is not an error. It means that as there is no unique id, you can only configure it in yaml, not via the UI.
If you want to be able to add some UI capabilities, you have to assign a unique id yourself in the configuration of your sensor. Have a look at the RESTful sensors, there is a unique_id tag you can add.
Thanks, I will have a look :slight_smile:
Now it works for me with the following code. @HycDev : thanks for your help!
#Hycube configuration
  - platform: command_line
    scan_interval: 36000
    command: >-
	 curl --request GET 'http://your_ip/auth/' --header 'Authorization: QmFzaWMgaHljdWJlOmh5Y3ViZQ=='
  - platform: rest
    scan_interval: 5
    headers:
      Authorization : "{{ states('sensor.hycube_token') }}"
      Accept: application/vnd.github.v3+json
      Content-Type: application/json
      User-Agent: Home Assistant REST sensor
    resource: http://your_ip/get_values/
    value_template: Bla
    json_attributes:
          - Battery_C
          - Battery_I
          - Battery_P
          - Battery_V
          - Grid_f
          - Grid_P
          - Grid_V
          - Home_P
          - Inv 1_I
          - Inv 1_P
          - Inv 1_V
          - Solar 1_P
          - Solar 1_I
          - Solar 1_V
          - solar 2_P
          - solar 2_I
          - solar 2_V
          - solar_total_P
    sensors:
      battery_capacity:
        value_template: "{{ state_attr('sensor.hycube_data', 'Battery_C') }}"
        device_class: battery
Hello everyone,
Since updating home assiatnt to version 12.1, my values ​​from the Hycube system are no longer available in home assitant. If I reset the installation to V11, everything is available again as usual. As described above, I inserted the code into my YAML configuration, which worked without any problems until I updated to V12. Any ideas? I am thankful for every help
