fspatt
(Frank Spatt)
January 26, 2024, 10:17am
22
Trying to use a Glance card to show the value of the US stock market indices - DJ, S&P, NasDaq. See below:
I’m using the Yahoo Finance HACS integration and it does a fine job except two things.
You see the USD? This is an index and not a dollar amount like a regular stock.
The value is currently set to the overall volume. I would rather see the market change in the value of the sensor. For example +242.
I realize it’s probably a templating in config.yaml file but need two or three attributes to be copied and not the whole thing.
Suggestions??
Card code is:
show_name: true
show_icon: true
show_state: true
type: glance
entities:
- entity: sensor.yahoofinance_dji
- entity: sensor.yahoofinance_gspc
- entity: sensor.yahoofinance_ixic
The sensor has this attributes:
Attributes
CurrencySymbol
Symbol
^DJI
QuoteType
INDEX
QuoteSourceName
Delayed Quote
MarketState
PRE
AverageDailyVolume10Day
337,895,000
AverageDailyVolume3Month
315,533,114
RegularMarketChange
242
RegularMarketChangePercent
0
RegularMarketDayHigh
38,057
RegularMarketDayLow
37,796
RegularMarketPreviousClose
37,806
RegularMarketPrice
38,049
RegularMarketVolume
402,976,676
RegularMarketTime
1,706,219,549
DividendDate
Unknown
FiftyDayAverage
36,720
FiftyDayAverageChange
1,328
FiftyDayAverageChangePercent
3
PreMarketChange
0
PreMarketChangePercent
0
PreMarketTime
0
PreMarketPrice
0
PostMarketChange
0
PostMarketChangePercent
0
PostMarketPrice
0
PostMarketTime
0
TwoHundredDayAverage
34,716
TwoHundredDayAverageChange
3,332
TwoHundredDayAverageChangePercent
9
FiftyTwoWeekLow
31,429
FiftyTwoWeekLowChange
6,619
FiftyTwoWeekLowChangePercent
21
FiftyTwoWeekHigh
38,109
FiftyTwoWeekHighChange
-60
FiftyTwoWeekHighChangePercent
0
Trending
up
Troon
(Troon)
January 26, 2024, 10:34am
23
Please paste this into Developer Tools / Template and paste the output back here, but format it correctly (surround code with three backticks ```).
{{ states['sensor.yahoofinance_dji']['attributes'] }}
Like this (but with the code above):
and I want the equivalent of this:
{'state_class': <SensorStateClass.MEASUREMENT: 'measurement'>, 'unit_of_measurement': '%', 'device_class': 'battery', 'friendly_name': '10DTB42 Battery'}
At a guess, you should be able to set up a template sensor via the UI with a template like:
{{ state_attr('sensor.yahoofinance_dji', 'RegularMarketChange') }}
fspatt
(Frank Spatt)
January 26, 2024, 3:21pm
24
Thanks - I have this which gives me two different variables. 1 with the change and 1 with the icon. How do I make this like the sensor and have both attributes in one sensor?
{% set dow_chg = state_attr('sensor.yahoofinance_dji' , 'regularMarketChange' ) %}
{% set dow_icon = state_attr('sensor.yahoofinance_dji' , 'icon' ) %}
Troon
(Troon)
January 26, 2024, 3:31pm
25
Sensors have:
exactly one state, which is a string up to 255 characters;
zero or more attributes which have a lot more flexibility over what they can store.
You could do this, setting the change value as the state and the icon (whatever that is) as an attribute:
template:
- sensor:
- name: Dow change
state: "{{ state_attr('sensor.yahoofinance_dji', 'regularMarketChange') }}"
attributes:
icon: "{{ state_attr('sensor.yahoofinance_dji', 'icon') }}"
What does your dow_icon
look like? Is it a string, number, or an MDI icon reference? (I’d know if you’d provided the requested information above…)
fspatt
(Frank Spatt)
January 27, 2024, 6:12am
26
Thanks. I’ll give that a try. Icon from the sensor is
icon=mdi:trending-up
which I assume is a string.
Troon
(Troon)
January 27, 2024, 7:58am
27
You could make that the actual icon of the new sensor then. See the template sensor docs.
fspatt
(Frank Spatt)
January 27, 2024, 1:29pm
28
I’ll let you know! Thanks for the help!
fspatt
(Frank Spatt)
January 31, 2024, 9:21am
29
I put this in my yaml file. Not sure if it can go into a helper or not
` - platform: template
sensors:
dji_chg:
friendly_name: DOW
value_template: "{{ state_attr('sensor.yahoofinance_dji', 'regularMarketChange') | int }}"
icon_template: "{{ state_attr('sensor.yahoofinance_dji', 'icon') }}"
snp_chg:
friendly_name: S&P
value_template: "{{ state_attr('sensor.yahoofinance_gspc', 'regularMarketChange') | int }}"
icon_template: "{{ state_attr('sensor.yahoofinance_gspc', 'icon') }}"
nsdq_chg:
friendly_name: NSDQ
value_template: "{{ state_attr('sensor.yahoofinance_ixic', 'regularMarketChange') | int }}"
icon_template: "{{ state_attr('sensor.yahoofinance_ixic', 'icon') }}"
And I have this in my glance card:
Exactly what I wanted! Thank you!
