OK, when I get home I’ll try and put together an option for you.
Just a note: i have one Tuya presence sensor ( don’t know which model though, bought on aliexpress), i converted it to esphome (i changed original non-supported control module inside with esp), and if i change any setting module always restarts after that - this is, as it seems, normal behaviour of sensor module and not a bug. It seems that module itself is made in a way that it requires reboot to work with new settings.
Sure, thanks. I’m fine with it rebooting. The bug is that it reports absence in the presence of a human. Tuya should check its sensors first before reporting a wrong status.
If it was a hardware problem which cannot be rectified, the sensor should not report for X seconds after a reboot. Pretty sure there is a reasonable way to fix this upstream, but gets extremely complicated here in HA.
So is a 3 second delay when you leave the area too long? To me for a light that is super fast.
alias: presence in room (Advanced)
description: ""
mode: restart
- type: occupied
platform: device
device_id: xxxx_mmwave
entity_id: xxxx_occupancy
domain: binary_sensor
- type: not_occupied
platform: device
for: '00:00:05'
choose:
- conditions:
condition: trigger
sequence:
- type: turn_on
device_id: xxxx_switch
entity_id: xxxx_light
domain: light
- device_id: xxxx_mmwave
domain: number
entity_id: xxxx_sensitivity
type: set_value
value: 4
- conditions:
condition: trigger
sequence:
- type: turn_off
domain: light
domain: number
type: set_value
value: 1
You don’t need two automations for light control, just two triggers and a choose:
I would be fine for a minute
Yes, I was already able to make it faster with high sensitivity, except that it gets false alarms from activities outside the room.
We are dealing with lights today, so I understand that asking for less than 3 seconds is not reasonable. But my aim is also to see how far we can push it without comparing with current norms. Being accurate at less than 1 second can open up other possiblities.
Hope that explains.
I see your automation is handling the bug on the absence side but has restart
. Let me see how it behaves. Thanks!
That just helps with the dual triggers and for: command. It’s how I create pretty much all of my automations. This way if you re-trigger the automation during the 5 second cool-down, it will keep you light on for you (ie: if you are actually still in the room).
Having said that, with my automation you could probably simply adjust your sensor sensitivity to a median point and not need all this stuff making settings changes.
It works. I even have for:
down 1 second. But overall, it doesn’t seem to have improved the speed at which the lights turn off. I have to fiddle more with it when I have some time.
Nonetheless, it doesn’t go on and off continuously anymore and I have them both in 1 script. It is definitely progress for me. Thank you.
Just to explain,
- I did try to find a median sensitivity, but wasn’t able to
- In the end I decided to adjust the sensitivity and that was when I found the bug
- That bug led me to write my OP
