Something like this?
And then use the entity_id sensor.office_temperature in front end?
sensors:
office_temperature:
friendly_name: Office Temperature
value_template: '{{ states.climate.office_thermo.attributes.current_temperature}}'
entity_id:
- sensor.office_temperature
Should be - climate.office_thermo
no not working, the entity_id has a value of âunknownâ âŚ
mmhhh ok, but I want just the value current_temperature shown
Yes, then this should work.
sensors:
office_temperature:
entity_id:
thanks I will continue tomnorrow!
Nope this is not working. The entity_id sensor.anna_bedroom_temperature gives UNKNOWN value
and the entity_id climate.anna_current_temperature is non existant ⌠??
sensors:
anna_bedroom_temperature:
friendly_name: Anna Bedroom Temperature
value_template: '{{ states.climate.anna_thermo.attributes.current_temperature}}'
entity_id:
- climate.anna_current_temperature
but you use
sensor.target_temp_stue or
climate.termostat_stue
to give you the states.climate.termostat_stue.attributes.temperature ???
Go to Your_IP:8123/dev-template and add {{ states.climate.anna_thermo.attributes}}
Then you see all the attributes you have access to. Then you should choose the attribute you are interested in.
I have this
{âfriendly_nameâ: âTermostato Annaâ, âmin_tempâ: 7, âaway_modeâ: âoffâ, âoperation_modeâ: âidleâ, âtemperatureâ: 0, âcurrent_temperatureâ: 14.1, âunit_of_measurementâ: â°Câ, âmax_tempâ: 35}
I am interested in getting current_temperature (the value 14.1) in front end and for automation. How to get it?
Use the Your_IP:8123/dev-template page and try
yes yes that works. But how to use it (showing the value and a name like Anna Current Temperature) for example in front end?
Make template sensor as I suggested before:
I did, but either I did not understand or I did something wrong.
In your settings which is the entity _id with the states.climate.termostat_stue.attributes.temperature value
I use climate.termostat_stue as the entity_id in my case.
entity_id (Optional): Add a list of entity IDs so the sensor only reacts to state changes of these entities. This will reduce the number of times the sensor will try to update itâs state.
entity_id is optional, so you can try without.
Yes without is working, with was NOT working ⌠go figure âŚ
sensors:
#entity_id:
#- climate.anna_current_temperature
before climate.anna_current_temperature was NOT created (non existant)
now I use sensor.anna_bedroom_temperature
and is giving the state correctly
Your entity id is climate.anna_thermo
but that is giving all the values (I think), not only current_temperature.
climate is for me Netatmo
No, you are misunderstand it. Read the documentation again:
