It would appear that the results of your tests are demonstrating the fragility of the workaround proposed in the linked post.
Which wasn’t a reason to instantly remove the Solution tag.
If the proposed solution works but later doesn’t then it means it simply needs refinement and/or more thorough testing.
If you want my continued assistance, I need to see the latest version of all modifications made to the automation or entities it references.
Correct ! When i used Fibaro Home center 2 i had to store all the values power, brightness… for each light in a json table but that worked fine.
In Home center 3 there was an integration to do this but that didn’t work.
I think the communication of the lights is very slow…
Anyway it’s ok now, the scene for the kitchenlights i call in the “Gate closed” automation now is almost always the one i use in the kitchen.
Have a nice day !!
Glad to hear it. Please consider restoring the Solution tag here so that it can help other users find answers to similar questions. Thank you.
Oh, i’m sorry that i removed it.
I thought i had to do that.
Restored now
Thanks again !!!
